View Full Version : Plumbing Forum Discussion & Blog
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67 68 69 70 71
  1. Pressure Test
  2. DWV Toilet to Sanitary t
  3. Size of dishwasher supply???????
  4. GPM a little low
  5. Ball Valve Shutoff Missing Handle
  6. leaky shutoff valve
  7. Is my bathroom vent designed properly??
  8. Tub and shower vent
  9. Advice on Garbage Disposal + P-Trap
  10. Where is the water coming from?
  11. Getting a snug fit for my shower faucet
  12. Running plumbing in the attic
  13. Rusty Water in Bathroom Tub Only
  14. Someone please tell me why this patio drain is a bad idea?
  15. tightening widespread valve bodies on granite
  16. Toilet draining completely, no leak found
  17. Can vent go downward below the highest fixture?
  18. How to install a metal hose bib when you have PVC piping???
  19. a few camp plumbing questions
  20. Newbie Question about slip joints.
  21. Smell From Faucet?
  22. Kitchen faucet comes loose at base
  23. Pipe length
  24. Drains on Water Supply
  25. Seasonal septic drain field ground saturation?
  26. Is this an S-Trap? Please help!!
  27. Laundry drain overflowing
  28. filtration system
  29. Weil-McLain Heater CG-5-PIDN Problem
  30. pipe threading tool
  31. Can we talk about trap seal primers in residential use?
  32. Sweating near pipe dope
  33. Which way is the cold water handle supposed to turn?
  34. RO Faucet Drip Under Sink.
  35. Main stack
  36. pipe from house to street in city sewer
  37. auto vent/air gap guidance
  38. Hot water from hose bib when I drain water lines
  39. Blowing water out of filter tanks
  40. Need new hot water heater - suggestions?
  41. help running sewer line
  42. sewer pipe cast iron replaced with pvc
  43. Dishwasher replacement and air gap
  44. Light Green PVC use
  45. Curb box - number of turns = size of valve????
  46. Faint Gas Smell
  47. Shower Diverter not diverting fully
  48. Odd hot water behavior in bathroom & washing machine - Help!
  49. AAV Venting questing, tee direction
  50. What most plumbers won't tell you.
  51. Are Drum Traps less prone to siphoning?
  52. Will PVC bond to CPVC?
  53. Toilet supply rough-in questions
  54. New Tank Install Now Pressure Won't Hold........
  55. Sump Pump Gurgles when it shuts off (It has a good check valve installed)
  56. brass elbow leaking inside my wall
  57. Drilled a couple holes in vent pipe - remove and replace or caulk
  58. Do remote / inline pressure balance valves work well? Alternatives?
  59. Why does the vent have to be above the flood level rim?
  60. Needing to splice into a water line in the attic. a little help please?
  61. re: bathroom sink leak on new installation -picture included-
  62. Water pressure Problem
  63. DWV remodel issue...??
  64. Slow leaky and plumber wants to replace the whole pipe
  65. Cast Iron Stack Leaking
  66. ABS, ABS fittings, UV Resistance and Vanity...
  67. Bidet Toto deck mount rim holes
  68. Drying out iron bacteria to kill it
  69. In Floor Hydronics
  70. Jetted tub
  71. LINX Evolution vs traditional RO systems
  72. Toilet rough in Question
  73. Condensate Drain revisited: Plan Check before I fire up the torch?
  74. Proper way to tie into mid run of a under slab main.....?
  75. new moen faucet problem
  76. Leaking water service in front yard. What are my repair options?
  77. How to diagnose where septic odor is coming from ?
  78. tool rental
  79. Squealing Moen Tub Spout or Shower Valve
  80. Filter Fabric Disagreement on French Drain…
  81. Proper Venting for a Shower Drain
  82. How to replumb this for disposer?
  83. Sump pump alarm recommendations
  84. I'd like to use flexible hose to connect my trap primers...
  85. a leaky connection solder + thread question
  86. Water shuts off by itself when valve is fully opened
  87. Propex LF manifolds
  88. New Sinks won't line up with P-trap
  89. Rough in plumbing clarification needed
  90. ABS and hot air ducting
  91. hot water knocking
  92. adding bar sink
  93. How to add Utility Sink and Washer Drain to existing 4"
  94. Need Help on Plumbing a Sanitary Tee into a Septic Tank
  95. adding a sink and drain to house circa 1900
  96. What's a Good Lint Trap Filter Unit for a Washing Machine?
  97. Converting single bathroom sink to double sinks
  98. Minimum distance from trap to sani-tee
  99. Bad odor in units
  100. Washing Machine hoses
  101. How can I convert a threaded 90 rough-in behind tile into a slip-on for showerhead?
  102. Bathtub overflow rusted away
  103. Thanks!
  104. Buying a house with CSST? Opinions needed
  105. Moving sink drain pipe
  106. Laundry/bath on slab - drainage
  107. Pot Filler on an outside wall
  108. Help - converting 2 pc basement rough-in to a 3 pc.
  109. Oh, dear. Where can I find a European-size faucet aerator???
  110. Basement washer/utility sink drain problem
  111. Sleeving PVC for concrete pour?
  112. need help finding a selenoid actuated ball valve to control "circulation line on HWH
  113. piping for flushometer???
  114. What if sewerage backs up into tub?
  115. 90 Deg out of trap?
  116. Moen Posi-Temp....almost but not quite
  117. How to remove Grohe Sinfonia Faucet
  118. Basement toilet question
  119. Main water valve replacement
  120. Proper disposal of empty propane bottles
  121. Re-Doing Upstairs Shower
  122. Venting questions
  123. What's the max size of drain/vent pipe that I can I can put thru a 2x4 stud?
  124. Use Clay pipe or cast iron pipe for overhead sewer (50-60ft underground in yard)??
  125. sludge/build up in drain line
  126. Plumber's Preference?
  127. Difficulty factor? Sweating pipes
  128. Water Pressure
  129. When to Redo a PVC joint
  130. How to seal kitchen sink to countertop?
  131. PEX, or not?
  132. Disposal Question
  133. SOMEBODY is in deep doo-doo!
  134. A few pex questions and Sharkbite brand pex questions.
  135. Supply Lines to Separate Showers
  136. Water hammer issues? or freeze damage.
  137. How can water drain and leak like this??!!!
  138. Is this plumbing setup ok?
  139. Septic not pumping
  140. How much trouble am I in? This may make your eyes bleed.
  141. Uponor vs Viega (Propex Expansion vs Pureflow Crimp)
  142. Dielectric Union Application
  143. Second Floor Pressure/Flow Problem or Maybe I'm over thinking this a bit
  144. Not your usual S-trap question
  145. Water Well Line - Sediment Filter - Expansion Tank - Water Softener - H2O Htr. Order?
  146. High Spout Faucet for Bathroom Sink ??
  147. Had to reuse a compression collar and nut
  148. Chrome P-traps
  149. need advice on drum trap
  150. Clay Pipe tie in
  151. Installing Clawfoot tub in roughed in bathroom
  152. Hose bib wiggles : how to fix ?
  153. Bringing plumbing to an outdoor shed?
  154. pex rings
  155. Tub drain leak in wall
  156. Toilet not flushing correctly, bubbles coming up, other toilets are fine
  157. American Standard Max 1.5 gpm shower heads
  158. water main line
  159. Sink Rough In Height
  160. Questions about using a Watt's compression fitting with Pex
  161. Dishwasher does not roll-out
  162. Gas line sizing .. can someone confirm?
  163. washer plumbing problems
  164. Can't get aerator out of a Kohler
  165. Lavatory drain size mismatch
  166. Bathtub/Shower Valve distance to Tub Spout
  167. Vent a Basement Floor Drain with an AAV?
  168. 8.5" Rough In
  169. Drywell for washing machine discharge okay?
  170. Oatey #5 vs. Oatey #95
  171. Flat venting
  172. Sewer/Drain Field problems
  173. Help: Replace Main Shut Off Valve
  174. Attach SS Sink to new Granite Countertop
  175. Hot & Cold Lines Crossed?
  176. Length from sink drain opening to p trap
  177. $5800.00 to replace the well pump and wiring
  178. will NPT fitting work with IPS fitting?
  179. Leaky Mansfield Anti-Syphon Wall Hydrant
  180. Looking for a small triangle corner sink
  181. Main Drain Pipe Leaking
  182. main water line
  183. coupler on Main drain line with crack + - 1/4 "
  184. sump and no floor drain
  185. wanting to get rid of cleanout
  186. hose spigot
  187. Can't divert water to hand held feature of shower.
  188. Just a comment on Polybutylene
  189. walk in shower
  190. Price Pfister Kitchen Faucet Installation
  191. New Delta faucet..hook up
  192. Cracked cast iron 4-way Tee in Vent stack/sewer drain in bathroom
  193. Kitchen Faucet Pull-Out Hose Won't Retract
  194. Kitchen Sink without U Channel
  195. Seat for American Standard 4040 toilet
  196. New tub to old drain
  197. Aerobic septic tank smells inside house
  198. Shower drain between, then under floor joists...
  199. faucet adaptors
  200. Hooking up Pex pipe? Have questions... Please help.
  201. 2½" 12-point socket fits on 4" cleanout square plug?
  202. Pfister Roman Tub Stem Extension
  203. Any idea what this is?
  204. Sewer camera
  205. Installing 1/2" NTP Grundfos recircultion pump on 3/4" NPT Water Heater
  206. "Standard" tub / drain / spout
  207. Double wye question
  208. Deposits in water heater
  209. Bar sink drain pump or tie into existing ejector pump
  210. What kind of union fitting is this? Ford Fitting
  211. P-Trap into floor drain? Or is that an S-Trap? (and not good)
  212. 6" CI x 4" PVC
  213. Pedestal sinks. Standard mount dimensions?
  214. remodeling bathroom and have some questions
  215. Can I leave over tightened headless screw in ss band?
  216. prier faucet sticking
  217. Removing this type of supply line from bathroom faucet?
  218. Replacing old p trap - new vanity
  219. Too high water50 pressure?
  220. PRV Adjustments
  221. Kitchen SS Stainless Steel Sink to Granite
  222. Installing new cabinet -- need to move kitchen drain line
  223. Electrolysis question
  224. Chrome cover for ABS
  225. single handle delta kitchen faucet
  226. Kitchen vent question
  227. Need to redo or not?
  228. Copper to PEX for future remodel
  229. "T" Fittings for DWV System
  230. Shorter Power Pipe?
  231. Utility Pump Hook Up Question
  232. Are American Standard sinks worth buying?
  233. Tub & toilet backing up
  234. What size vents?
  235. Copper Pressure Adapters
  236. Layperson needs advice on house repipe and old galvanized pipes
  237. Rust on exterior of galvanized pipes = sign of imminent fail?
  238. Any disadvantages to horizontal repipe now and vertical later?
  239. Location of shower arm from mixer valve--can it have a dog leg?
  240. PVC repair irrigation water supply line from the street
  241. Running copper piping along the outside wall of my house
  242. In a world of hurt...drain broken under house...
  243. Sulfur smell from bacerial infection of pex tubing?
  244. PEX fitting reliability
  245. Trivial question about hot water supply
  246. 3/4" Sched40 under slab repair
  247. Feedback on Drain Design
  248. Pipe Insulation
  249. Moving Glued PVC P trap
  250. Ridgid 535 pipe threader
