View Full Version : Plumbing Forum, Professional & DIY Advice, Tips & Tricks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77
  1. DWV testing and mysterious leak- solved
  2. Electric Water Heater Side and Back Wall Clearances?
  3. Venting in Garage
  4. Replacing bathroom sinks
  5. Zone valve or its own circulator for an indirect water heater?
  6. Check Pipe Pitch?
  7. Did my pipe break, or did someone try to steal it?
  8. using old washer outlet box for wet bar use?
  9. Main service ~250' run, what size/type of pipe
  10. Vent location when it would end up in a open area of the room...
  11. Toilet drain/vent question
  12. Vent Size Question
  13. standpipe overflow
  14. Kitchen mop sink rough in codes
  15. no water, no sound when I turn spigot
  16. Slip-on Coupling vs No-Hub Connection for Vent
  17. search function broken
  18. Washer / Icemaker connection timing
  19. how many fixtures on a 3" stack?
  20. Basement Drain half-full with water.
  21. Homerun to shower /tub ok 1/2" Wirsbo pex?
  22. Water Heater Expansion Tank Revisited
  23. PCV to C.I. joints
  24. Questions about bathroom renovation
  25. Vent Pipe in the way
  26. Mr. Rooter "Waste King" brand garbage disposal is frozen
  27. Nipple size for 2x4 wall w/ dog ear 90
  28. What determines hose bibb size?
  29. Pressure gauge: what kind to get?
  30. T-wye or Sani-t on 3" secondary stack
  31. Solder Ball Valves(3) Confused about Open/Close and Where to Heat?
  32. Frozen Pipes... or something else?
  33. Missing vent?
  34. check valve question
  35. Sanitary Tee orientation in vent
  36. Frozen/Burst Outdoor Pipe Question
  37. Weil mclain boiler hi low limit problem
  38. is this water hammer or air in the pipes?
  39. Air in the system - heating system, please help
  40. Please recommend a moisture detection tool.........
  41. Moen Kitchen Faucet Install Question
  42. Vent Tie In
  43. How to remove Kohler cover faceplate and lever in shower?
  44. Replacing cast iron waste pipes
  45. Extra long dishwasher air gap connection
  46. Basement Bathroom vent issues
  47. How do you get off these freaking handles?
  48. Brown / orange ring around drain in new Kohler sink
  49. Gerber Diverter Valve Question
  50. Goofy dishwasher drain help
  51. Laundry/Utility sink drain size.
  52. shower suddenly stopped
  53. Pex Modified Homerun System Design
  54. Replacing a leaking Instant Hot tank, Property Inspector LLC, Woodinville
  55. Sink strainer flange for kitchen sink (flat vs funnel)
  56. Plumber Opportunity?
  57. Hot water problem - Found the cause, but not sure how to fix - Please help!
  58. Help with 1970's Premier Lift and Turn Drain Removal [PIC]
  59. Really SLLOOOOW Draining Toilet...any suggestions/advice?
  60. do i need septic pumped?
  61. Transitioning from PVC outside to PEX inside the house
  62. What type of shower faucet valve is this?
  63. Ooops, wrong place
  64. Shower Steam Generator Pipe in Contact with "Pink" Insulation
  65. Sewer problem question.
  66. Water test w/ lead roof vent flashing (aka roof jack) causes indoor shower
  67. If an ABS connection looks poor but passes water test: leave alone or ??
  68. No water out of faucets?
  69. Small leak fix I found on another forum... what say y'all?
  70. How to extend a CO?
  71. Leaky CO's
  72. kitchen sink problem: sprayer jumps every time the faucet is turned on
  73. Fernco Multi-tite donut won't seat 100%
  74. Question About a 1946 Septic System
  75. How to have the proper leveling device?
  76. Questions about pressurized water tanks
  77. Weenies!
  78. Garden tub set below sub floor!
  79. Rear or concealed spud urinal installation
  80. New Bathtub Stems
  81. Dead Disposal. Can I remove it?
  82. Best plumbing (roof) vent repair kit?
  83. Relocating Closet Flange Help
  84. How to design drainage for basement bathroom
  85. WTF is a 'hy-set" or "hy-ear" elbow?
  86. Heater Tank Temp too hot!!!
  87. tapping when water is being run
  88. Designing copper bathroom piping routes for winter- northern michigan cottage
  89. problem adjusting chain length of an actuator valve for an American Standard toilet
  90. Leaking cold water valve
  91. Above the floor drain
  92. 90 degree sweep vs. two 45s
  93. Pipe bursts...very small holes...advice?
  94. Water comes up both sink after garbage disposal - Freezing and Pressure Vacuum Break
  95. Piping in block wall
  96. Plastic vs brass inserts for pex
  97. Carcinogens in brass fittings?
  98. frozen pipe or valve/cartridge problem???
  99. Critical distances for toilet, bath & kitchen sinks and shower from vent
  100. Supply line preference
  101. Washing Machine Outlet Box HELP!
  102. acid neutralizer soda ash and cold weather
  103. old toilet flange lining?
  104. Pipe scraps, good uses for them
  105. manabloc hot water problem
  106. "weir must not be above trap opening"
  107. On Demand Hot Water and HomeRun Manifold Systems
  108. Do I need expansion tank on domestic side of new HW heater?
  109. No hot water to bathubs...still works in other parts of the house...
  110. Copper pipe around corner
  111. Septic system
  112. Bathroom sink drain and vent
  113. Sweating Tips?
  114. Brand-New 1/2" PVC ball valve is leaking
  115. Instant Hot Water Dispenser Problem
  116. New Kitchen Sink Wall Bend Extension?
  117. Kohler Rialto trip lever problems
  118. Toilet Supply Size From Wall...
  119. Copper pipe ends oxidized inside near joint after soldering
  120. Toilet flapper still leaking after 2 replacements?
  121. Floodchek washing machine hoses
  122. Best sealant for connection to in-wall drop ear elbow - Teflon tape or thread sealant
  123. Dishwasher not draining properly
  124. copper nipple coming out of wall just a hair short
  125. trap tailpiece minimum length
  126. Short on hot water but increased water pressure...related ???
  127. Copper pipe through concrete foundation
  128. PVC to ABS
  129. horizontal wet vent
  130. Sink Pump Plumbing
  131. Slow draining waste line
  132. Fixing bathtub drain leak
  133. Wingtite vs. BruCo
  134. Fixing a badly rusted drain pipe
  135. Cleaning a Munchkin MC120 Contender Wall Hung Boiler. Boston, Ma.
  136. I messed up - how to fix it?
  137. Dishwasher & garbage disposal - for septic field drains
  138. Radiant floor Heating - Pex, etc.
  139. Hot water circulation no longer working effectively
  140. basement venting
  141. Rerouting a vent
  142. Replacing an old 3 handle tub shower faucet
  143. Moving water heater in system
  144. supporting vertical vent pipe
  145. Gas Light Installation - Running Vertical Gas line in Outside Wall
  146. Can I use PEX in Illinois?
  147. Cutting Old Painted Cast Iron Radiators
  148. 4" DWV done in ABS in underground garage in a highrise
  149. Vanity drain assembly installation method?
  150. Connect wet bar drain into sewer line cleanout?
  151. air in hot water pipe
  152. new 1200' polyethylene water line questions
  153. Toilet Drain relocation question
  154. Houzer Sinks?
  155. Spa pit sump pump recommendations?
  156. Material for replacement buried main water line from the curb?
  157. Adding second floor bathroom
  158. Water heater inlet corrosion
  159. Problem reinstalling shower faucet stem assembly - LONG
  160. I think this is a challenging question (maybe not LOL)
  161. How to angle ABS
  162. Basment bathroom renovation - Can I use an internal coupling on a vent
  163. Pressure Regulating Valve before one tap with Instant Hot tank
  164. Rough In for clawfoot tub faucet from floor
  165. Anything to add while slab is open?
  166. manifold system
  167. 3" trap arm - horizontal drain height change
  168. old clay sewer pipe nightmare
  169. Septic system without d box and without manifold.
  170. aluminum pipe for water?
  171. Kitchen Sink Hole Repair Help.
  172. PVC to copper coupler wont seal
  173. Pex installation - northern michigan cottage
  174. two capped copper pipes protruding from concrete slab in basement
  175. what are some tricks to tighten chrome/nickel etc pipes
  176. Hellenbrad iron curtain sytem
  177. Trap arm - height adjustments
  178. How to change a roman tub faucet, and add a handshower, with a tiled tubsurround
  179. I Found This Strange; screw found in supply tube.
  180. Hydronic system in -25 Celsius (-14 Fahrenheit)
  181. PE in steel?
  182. need help with a leak
  183. Side Discharge Bath Drain
  184. noisy studor vents only when it's cold
  185. Built-In Diverter / Rain Shower Head
  186. A day made of glass
  187. Can Someone Offer Me Some Do's and Don'ts for Mobile Home DWV Plumbing
  188. PVC pipe (soil stack) to horizontal main line
  189. dishwasher plumbing
  190. Which flange?
  191. connecting trap to galvanized nipples
  192. Dishwasher drain weirdness
  193. New England DIYers: Share Your Plumbing DIY disaster story
  194. Stainless Steel Tank and Copper Plumbing
  195. Single bowl to double bowl vanity installation
  196. Gas HWT clearances from doors, other intakes
  197. Stopped By An Angle Stop -- So What Went Wrong?
  198. Thermal expanstion tank for water heater
  199. How to adapt a 1.25" tailpipe to a 1.5" trap adapter in the wall?
  200. Adding bath sink to 1 1/2" pipe coming from kitchen
  201. Adding new sink drain to existing horizontal drain
  202. Moen Faucet Removal
  203. Leaky Danze Kitchen Faucet -- Help!
  204. Dishwasher siphoning water
  205. Do you pay the plumber-roto rooter man?
  206. New drain line routing in half bath?
  207. Water spewing out of faucet handle
  208. Rough-in for concrete over PVC DWV
  209. New Bathroom Faucet Leaks After an Hour
  210. self-closing valve for faucets. (Foot pedal?)
  211. Closet flange drain question
  212. Trap adapter question
  213. water line issues between shower and hot water tank drain P-trap
  214. Gravel fell in stool line
  215. Bath tub stub outs
  216. Bathtub trouble with drain
  217. Sizing CPVC or PEX Galvinized Replacement
  218. Multi-head showers
  219. Trenching & high water table?
  220. Refrigeration grade 1/4" coil ok for refrigerator water /ice?
  221. vent grade
  222. Can new simple water pressure gauge be inaccurate?
  223. Use Chlorine (Charcoal) filter in Whole House Sediment Filter Housing ??
  224. Leaky water main sleeve
  225. Vent pipe placement
  226. Boiler Condensate Line: 3 Questions (pic)...
  227. Sterling
  228. 3/8 inch shower arm?
  229. Need help with outside waterline size and type
  230. taco 557 valve
  231. Hot water heat pipe layout question
  232. Burying Copper Pipe
  233. These aren't shutoff valves! what are they?
  234. Clawfoot drain questions
  235. Hello, I need help
  236. Outdoor patio drains, Zurn products & traps...
  237. Draining Copper Pipe Causes Corrosion? "Old Wives Tale" or ?
  238. Laundry closet challenge
  239. Water Flow At Both Faucet & Shower Head
  240. Double Vanity Vent
  241. Anyone know what this is? Rotameter
  242. Sewer backing up into basement
  243. Add tee to existing 1" CPVC
  244. singing pipes problem
  245. Basement Ejector Pit Venting Main Stack
  246. Please help connecting washing machine water pipe
  247. Adding New Sewer Line Under Existing Slab on Grade
  248. Quick Question about No-Hub
  249. 2 wlls
  250. Traps in Walls: "Can't" vs. "Shouldn't"
