View Full Version : Plumbing Forum Discussion & Blog
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71
  1. Musty Odor From Sink Drain
  2. What would you do in this situation ?
  3. Drain and vent for laundry tub
  4. Kitchen faucet nut won't budge for removal
  5. advice on sealing/plugging holes in PVC pipe
  6. Is 3 GPM OK for a valve for shower and tub?
  7. High swing spout bath faucet
  8. Manufactured Home Water Heaters
  9. Looking for a BALLPARK cost estimate …
  10. Existing double sink plumbing, venting question.
  11. Hot water issues
  12. Pipe movement from above ground parking
  13. Bit of an electrical Gremlin on an older boiler system.
  14. What to do about my main stack
  15. second stage regulators, propane application
  16. dripdoc
  17. Chip/crack in pedestal sink
  18. ABS vs PVC drain lines in concrete slab? Advantage for one vs the other?
  19. broken terra cotta sewer line!
  20. Who makes inline ABS BackWater Valve?
  21. is plumber's putty under plastic okay?
  22. Banging water pipes from water heater heat traps?
  23. Need help/advice planning new plumbing for a laundry room
  24. Frost proof Hose Bib Valve clogged
  25. 2 SS clamps on PEX fittings or 1 ??
  26. toilet to urinal rough in
  27. copper pipe lenght
  28. Plumbing issue in newly remodeled bathroom
  29. Basement dehumidifier/ condensate pump
  30. Santee vs. Combo
  31. Kitchen sink vent
  32. Real time help needed/water main!
  33. Plastic to plastic threaded fittings... use teflon or not?
  34. Real Time Help: Pipe Compound with Compression Fittings
  35. 4" no-hub CI vent connection to old Bell & Spigot - special adapter?
  36. takagi tk2 problem
  37. Closed stem leaks while other is open
  38. Running Pipe over Unheated Garage
  39. DWV Hi Rise - WC-dedicated Soil Pipe max length and venting question
  40. had great pressure now just a trickle????
  41. I.D. of Wirsbo 3/4" fittings?
  42. phantom water leak
  43. PVC drain pipe and fitting in Southern California?
  44. Quick Kitchen Faucet Question
  45. PB to PEX adapter and crimping
  46. 2nd Floor Washing Machine Puts Water Into 3rd Floor Sink
  47. Kitchen gas line
  48. pipe volume
  49. Is dielectric union necessary?
  50. Stupid Newbie Question - Leaks in new faucet connection
  51. Relocating venting for my tub.
  52. PEX and recirculating hot water system - branch, home runs, or?
  53. Big thanks to HJ
  54. Whole house water conditioner?
  55. AAV for sewage pump
  56. Question on SDR 26 sewer line running under house
  57. WH heat trap interfering with Hot Water Lobster?
  58. A Simple question.....Why is there more than one code for plumbing!
  59. Pex Fitting
  60. quarter turn angle valve1/2 sweat
  61. water line thru basement block wall- how to?
  62. 1955 American Standard Shelf Back faucet valves and sleeves
  63. Uneven toilet flange in concrete
  64. House Re-Pipe Using CPVC (Hot) and PVC SCH 40 (Cold)
  65. drain from basement laundry sink
  66. Venting question
  67. Sunroom
  68. Basement Floor Drain
  69. A/C drain line trapped in series with tub trap
  70. Interesting S trap and venting
  71. Need retro 50s faucet and handles for shelfback (?) sink
  72. PEX connection question
  73. Sound in water main
  74. Cleanout for WC run
  75. Alsons fixtures
  76. mansfield model500
  77. Drainage layout and advice for Horse Barn
  78. When is it OK to run flat? (consecutive 90° bends)
  79. Horizontal Run with Pex (* Raceway *)
  80. Opening concrete floor without filling the house with dust?
  81. Solder Fail
  82. Professional opinions on this plumbing job, please.
  83. help identify cartridge
  84. p trap height
  85. How to route piping
  86. Help with general plumbing layout for Bathroom Addition
  87. i really could use some advice, please
  88. Ice maker outlet
  89. Bad advice??
  90. Refinishing an Astracast composite corner sink
  91. Special Thanks To This Forum
  92. abs connectors
  93. What did I do wrong? Slow drain...
  94. 3 piece vent question
  95. Shut off valve for wall-mounted faucet?
  96. Removing bladder tank solved pipe banging problem...why???
  97. TPR Inspection Question
  98. How to secure black iron at the wall penetration
  99. Uphill Sewage connection - 300 ft and 70 vertical feet - Need advice
  100. PEX Concerns, should I worry?
  101. GE Whole House Filter Flow Problem
  102. Noisy PRV
  103. Where did I go wrong? Water backing up into kitchen sink.
  104. Connecting tub drain to main drain
  105. toilet vent
  106. Pressure Relief Valve-Furnace
  107. Plumbing natural gas from meter to range
  108. Pipe insulation, what you should know
  109. Iron Pipe: Is this an acceptable cut?
  110. Please help me plan the DWV for my bathroom remodel... toilet venting etc
  111. question on water heater venting (orphaned water heater)
  112. Drainage Problem from Bathroom Sink
  113. OK NOT to use a Long Sweep 90 at the bottom of a drop?
  114. Toilet flange to street 90
  115. Hot water out of cold taps - plumber is stumped
  116. Isolation Valve
  117. Supply to Double Sink Vanity and Shower... and Shower Hardware
  118. Can pipe (pex) size affect how long it takes to get hot water at sink?
  119. Tapered screw for plugging brass plugs / fill test?
  120. flowguard gold
  121. Branching off water supply lines
  122. Questions from Louisiana
  123. hammer arrester
  124. Drain line in slab has negative fall - what to do about it?
  125. CPVC or Wisrbo AquaPex ????
  126. Trying to plumb my way out of a money pit.
  127. DWV Setup/Suggestions With SketchUp
  128. Cast Iron Pipe Seperation Under Slab - Advice Appreciated
  129. Moving washing machine supply lines
  130. Does sink need to be centered over plumbing?
  131. DIY or Run for the hills?
  132. Regulator- Am I doing the right thing? Plus additional help needed
  133. venting shower
  134. DIY'r
  135. 25"x22" Stainless drop-in sink in 27" sink base cabinet?
  136. Dripping tub; polybutylene pipes
  137. Basement DWV - can I do this?
  138. Apollo valves
  139. How to adjust a Water Pressure Regulator Properly?
  140. Will Replacing a toilet really save that much water?
  141. How do I handle this dishwasher drain setup?
  142. Kitchen sink hot water pressure disappeared
  143. Hansgrohe metro has no pressure on HOT side
  144. A flange from the 60's
  145. Septic Pump
  146. Newbie Question about sink drain
  147. Replacing a Lead Closet Bend
  148. Does an outdoor channel drain need a p-trap?
  149. Need Advice on preventing drilling into Water Lines - Grab Bar Installation...
  150. I need help solving a residential plumbing problem.
  151. Kitchen Sink fills when MBR shower is used...
  152. Reaming a sillcock
  153. Wet Venting
  154. P-trap issue - Is it possible to switch washing machine and bathroom sink locations?
  155. Island Vent Loop Question
  156. floodstopper leak detection system
  157. Can't figure out how to disassemble my Eljer faucet...
  158. I've been slimed!
  159. piping connections to water heater
  160. Jumper Wire over Water meter?
  161. Help identify this blue pipe?
  162. Dealing with imperfect surface on bottom of sink around drain hole
  163. Slow Draining Bathroom Sink
  164. Fix drip or buy new faucet??
  165. P Trap Question
  166. Advice to stop teeny tiny leak?
  167. Should PRV be before iirrigation system and house? Or just house?
  168. Should I trash or save this assembly?
  169. SCH80 pvc cement and primer question
  170. Sump pump ball check/backflow valve.
  171. Pressure tank install questions
  172. Minimum diameter for a hole in the floor for a water supply line?
  173. Septic Pump Help
  174. High water pressure outside; low inside house
  175. Elbow too low and too high
  176. Noisy ice maker
  177. Found yellow plug in toilet
  178. water line and refrigerator line hook up
  179. Copper pipe support under kitchen sink?
  180. Copper and Galvanized lines in contact?
  181. replacing undermount bathroom sink. Need advice
  182. Faucet whistles for a few seconds anytime water runs in the house.
  183. How to locate a pipe leak on sloped driveway?
  184. High quality shower valve
  185. Replacing Glued PVC Tee joint
  186. DWV Drawing for adding half bath--please comment
  187. Help!! How do I connect the overflow and drain assy to ny new kohler tub?
  188. Help!! How do I connect the overflow and drain assy to my new kohler tub?
  189. Cs & b
  190. Washing machine & laundry sink venting
  191. Faucet problem
  192. I hope Septic questions are OK...in a bit of an emergency! Help.
  193. Water won't come into dishwasher?
  194. Leak in diverter valve, help!
  195. Tuscany Brass shower faucet problem
  196. San Bruno Gas leak Blast
  197. converting fiberglass shower(on slab), should I embed drain ABS in concrete?
  198. House Re-Plumbing Project
  199. The lesser of 2 p-trap evils
  200. Kitchen Rough-In Problems
  201. Septic Field Lines
  202. Pressure-balancing valve = cold water on the hot water circuit?
  203. Workarounds to use single handle bathroom faucet with 8" pre-drilled holes?
  204. Does this toilet vent look OK?
  205. Older bathroom faucet repair
  206. 670' residential water line. What size should I use
  207. Aging gas lines in America
  208. Gerber Maxwell Faucet - Advice
  209. Unvented WM drain, and wants to add a sink in basement
  210. Can I drain/vent a sink into this drain pipe?
  211. What's In a Faucet. Can I Make My Own Faucet from Various Parts?
  212. DWV Layout for Bathroom Remodel
  213. New Kitchen Gas Line Install
  214. Need Help Removing a Stubborn Faucet Nut....
  215. Need help finding 1" AquaPEX
  216. Anybody do Radon?
  217. Where to find 1" Pex manifold?
  218. Recirculating pump advice
  219. Vertical Drop before venting
  220. Well started pumping large amounts of sand, now no water
  221. Unique icemaker supply stop valve
  222. Quick (hopefully) WC to Tub drain question.
  223. PEX system leak. How do I find it?
  224. Options for Shallow Sink Over Dishwasher
  225. Drop in Water Pressure?
  226. Reverse Osmosis: Prevent Leaks
  227. Are there any types of side work you would rec to an apprentice?
  228. Special Hose Bib Compression Fitting
  229. P-trap location
  230. heights for supply and drain lines for bathroom sink
  231. On the class action lawsuit front ( plumbing related) Clorox, Lowes
  232. Imbalance of Hot/Cold Water
  233. Sabotage?
  234. Toto brassware for a laundry sink
  235. Black bears in the plumbing !
  236. Toto shower valve with threaded adapter
  237. How much pressure is too much?
  238. "Proper Handling" of Threaded PVC Joints
  239. Flexible (roll) copper for bathroom supply lines?
  240. trying to find a well pump to replace the one that was stolen
  241. Strange (to me) water heater issue
  242. Whole house water filter cartridge stuck in housing?
  243. Poop in my sump pump crock, how do I fix this?
  244. Siox Chief icemaker box- help with selection
  245. whole house water filters
  246. Moen kitchen faucet model 7730 handle problems
  247. DIY Laundry Box
  248. copper pipe nicked
  249. Remedy for AAV concealed in wall?
  250. Sharkbits
