- water pressure problems
- Installing delta faucets !
- Have small particles in the hot water from kitchen sink and nowhere else...
- White specks in water
- plumbing hand tool.. for manually striking tool with hammer and driving a cement nai
- Single to Double Sink Vanity (again)
- Faucets connecting with 1/2"D IPS or with 3/8"D IPS (Flex lines)
- Connect a fridge. Pro's and Con's of Pex vs Braided Stainless vs Copper vs Plastic
- Insulation on CPVC / Recirculator
- Ceramic or tiling unsanded caulking
- Silicon or acrylic caulking
- Price Pfiester bath faucet now turns backward
- Need to remove section of air pipe (stuck), thoughts?
- Where do I shut off the water?
- Pegasus sink model discontinued?
- Moen valve issue
- Free standing laundry sink
- Metal stain on white sink from repositioning drain
- Kitchen sink drains directly outside?
- Self-rimming Kohler sink help
- Happy Father's Day, add your story here.
- sink drain with washer drain ?
- water quality
- Patio Sink
- tamper-proof angle stops...argh!
- shut off water main
- Pre-Fabricated Granite Vanity Tops - Can I cut them?
- Replacing sink drains
- Hot water at cold side all faucets
- Ball valves in pvc pipe
- New house water line questions
- Existing 1/2"
- Undersink water filter
- Little silver-winged flying bugs in my drain.... what are they?
- Supply 3 shower heads with 1/2" pex
- Sink w/tiny cracks in bottom. Repairable?
- PVC joint not square, will it leak?
- help identify the shower trim from photos
- need advice on water treatment system
- Moen Single Handle shower- no cold water???
- Jetted Tub will not shut off
- Remove propane gas line
- I did not see a Lounge Forum but Dear Terry.....
- really Cold Water
- Newbie here!
- Battery powered Chicago Faucet
- Installing fridge water line, questions about well water supply
- PEX and UV exposure
- Noisy water lines - unable to determine cause
- Dishwasher leaking
- Main drain pipe clogged after washing machine
- 1 1/2 copper to PVC help
- Advice- Rainwater Backing Up Into Basement- Long
- Copper tubing for a swamp cooler.
- dry ice to stop a leak
- Main line leak causing banging noise in house? How to locate?
- ABS Sewer (Stack Pipe)
- Brass P-Trap to Cast Iron DWV
- Moen 1225 Cartridge Replacement - Tips Please
- sound from running water pipe
- What is your preferred way to have a main supply drain?
- Elbow for ice maker line?
- Nibco 90 Stem
- Penn box on kitchen cold water pipe?
- Urinal valve question
- Hot (water)time in the summer
- Am I right with this shower drain?
- Plastic Pipe Insulators / Brackets thru Studs for Copper Pipe -- When Required?
- Red Seal Exam: Update
- Question about my Wet Vent on my Water Closet.
- Prier frost-free faucet leaking from handle
- Opinions on acrylic bathroom countertops with integrated sink
- leach bed
- Joining unthreaded brass pipe
- Another WAX-RING question?
- hard to turn off the water in shower faucet
- just moved in to 40 year old home, heard gushing water, main water line broken
- PEX faucet feed line removal question from the new guy
- Moen Faucet Cartridges
- Main line pressure testing?
- main line pressure regulator location?
- 6" Clay Drain to PVC to 6" Clay Drain
- Brown water in washer and toilets
- Hangers ??
- Delta single handle faucet hard to turn after parts replacement
- Would be thankfull for some advice...waste stack ques.
- Polyethylene Pipe Issue
- Undermount Sink Has Sunk Away from Tiled Counter
- DWV Layout Advice Needed
- Caulk between pedistal sink and wall?
- Leaking Kitchen supply pipe ??
- retrofit weeping tile
- Chicago Faucets for Bathrooms & Kitchens
- Best Float Switch
- screw hole in copper pipe
- Can I cut fittings to get flange to fit?
- Broken Closet Flange
- Rohl Shower Ext [fe threads] question
- About Pilot Valve Type...
- Copper air test questions
- angled vent stack and flexible p-trap
- Installing a sink tailpiece
- Kerdi vs Provamat drain?
- removing vintage Widespread American Standard Bathroom sink faucet
- Long Island Plumber?
- How to cap a floor drain?
- Rescued kitty gets fitting name
- Water meter causing noise?
- PEX stub outs - how do you do yours?
- Terrible water flow coming from new tub/shower set - HELP!!
- How secure hose bib to hardi plank
- Replacing Water Main Shutoff and PRV
- In-Line Vent vs. Air Admittance Valve?
- Unique Tub drainage configuration
- Expansion tank or PRV?
- DIY dishwasher install to double sink
- Well Shutsoff
- Genova 3" thin wall DWV sch 40...?
- Trouble Replacing Bathroom Faucet
- Problems installing Moen shower valve.
- Pex SSC fittings for Hydropex tubing
- shut off valve leak
- Shut off valve stuck
- Need your input on relocating 4" vent/waste CI...
- Have you seen this faucet?
- Qest fittings
- Best way to connect PVC to Galvanized?
- Pex with thermostatic valve/volume valves
- signs toilet flange is bad?
- Corrugated plastic sleeve or foam for PEX slab penetration?
- Are offset toilet flanges against plumbing codes?
- Toilet location
- Freeze proof faucet
- Pex vs copper. Which stands up better to cold?
- Sudden increase in water pressure
- Main stack & offset walls: Run Horizontal?
- Water Pressure Problem
- Silcock Leaking - unknown mfg
- Brown Well Water
- Have you seen this screw/faucet?
- Toilet problem
- Symmons Temptrol cartridge:
- Low water pressure in one shower and tub
- Trap primer installation
- Drain Fly nightmare--HELP
- short cycling NEED HELP ASAP!
- cast iron slop sink drain HELP!
- New Sink. Need a double check on DWV fittings
- gas line install
- What's this for?
- Any Ides For Sound Insulation of PVC Drains?
- Test ball location
- screen in shallow wells
- Lav faucet slow to shut off...
- Water Pressure issues
- Closet flange question
- Can I secure a gas line to an exterior wall?
- Can I rework this P trap? or doomed to a short garage door... :(
- Drain pipes need replacing
- Hot water line size
- About Macroscope 7 model WH 3-6
- Saniflo Greywater Pumps?
- Shower liner tub spout hole cut too big
- Which Cast Iron Flange Replacement is best
- Help With Adding A Vent
- Does this layout work best?
- Full House and other Flood Prevention Shut-Offs?
- Water Pressure Drops
- Shared up-the-wall vent for three fixtures?
- Radiator Piping Alteration
- Older Friedrich Grohe bath sink faucet repair
- sewer
- Can I combine brass/chrome and plastic p-trap segments?
- PEX and Vent Questions
- Basement sink drain and vent identification
- Pex bend supply source
- Floor urinals, are they no longer code legal?
- dishwasher issues
- Washing machine plumbing problem
- 1/2" Depth Split Escutcheon Cover for 1/2" Pex Tubing
- Need a tip on how to fix a drain line
- online heat loss calc???
- How do I snake a vent?
- threading PVC fitting into cast iron stack
- Drain cleaning using a snake and a high pressure water jet a friend lent to me
- Hot Water handle hard to turn
- Add cross-framing under toilet?
- Mystery leak in basement - please help
- Can you give me a BALLPARK cost estimate please?
- Standpipe questions, venting and drain size
- Help choose a new frostproof wall hydrant.
- Viega Pex suppliers?
- Matching pex tools, rings, and fittings?
- Brazing....
- Help identify American Standard shower valve
- tankless hot water and manabloc
- Please assist me design DWV for two bathrooms and laundry
- Question regarding floor drain and sump pump combo
- California lead law - new faucets
- Are the trap arms 2inch or 1 1/2 inch?
- 2 Questions: Placement of Cleanout
- Mis-Reading the Code
- Should I have my lead water lateral replaced?
- How to get a slight angle on PVC line.
- Can antique (1940s) sink faucets be fixed??
- rerouting kitchen sink water pipes through wall
- Tie in Sump Pit to sewage line as safegaurd?
- Slow utility/laundry sink
- well water sediment filter question
- Leaking water main
- Venting For Tub/Toilet Drain
- Rusted out pipe from where?
- electrical? on a water heater
- Does this toilet bend need replacing?
- water flow noise and leak
- Dishwasher question
- A Y on it's back
- Toto 1 Piece leaks from Plastic P-Trap
- Problem with washer draining / water backing up.
- washer p trap problems
- replacing main, expansion loop?
- Have to turn sink faucet handles forever before water
- Good pressure from spray hose bad from spout
- High pressure from spout bad from shower head
- sealing off unused WH drain?
- Delta Single Handle Leak + ID
- propane gas; black iron & galvanized pipe; brass ball valves; dielectric couplings
- Question on Draining Disposer
- Tub spout supply pipe question
- Washer Not Filling
- Capping a T
- Adding service extension before pressure tank...
- Source for Spin Down Filter automatic drain
- Sleeving copper water main
- Outdoor faucet leak behind wall
- Thin stream of water from bathroom faucet
- Floor drain / cast iron to pvc?
- Sump output to Storm Drain, 135 feet away?
- 4 inch vent pipe in a 2x6 stud wall?
- question about plumbing
- Freestanding bubble tub installation
- PEX Tubing Questions
- Zoeller pump for laundry tub in fish room
- floor sucker pump for use in fish room
- GE Whole House Water Filter
- Master bath toilet splashes and bubbles when toilet in neighboring bathroom flushed!
- First real plumbing inspection
- Sink drain rough-in... to 1960's era male threaded bronze?
- PVC pipe outside of house keeps overflowing
- How to find a good local plumber ??
