View Full Version : Plumbing Forum Discussion & Blog
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71
  1. Low pressure caused by single handle faucet?
  2. Basement Bath groundwork
  3. I have a ba cu 301.
  4. How do I unthread pipe from a fitting?
  5. Help finding a part
  6. question for plumbers more experienced than me
  7. Rosin-core solder and copper plumbing
  8. closet bend 14 ft. from main stack!
  9. Plumbing Diagram Help
  10. Compression va Flex Lines
  11. Slip Joint vs Threaded.....J Trap
  12. Compression Angle Stops vs. Solder Stops
  13. Sewage Smell
  14. 2 problems: could they be connected?
  15. Need new fixture for small front mounting sink
  16. Installing new toilet flange in concrete
  17. Parts: Keyboard style levers for On-Off valves
  18. Extra vent required?
  19. Flex water supplies....rubber gasket vs. metal bullnose seal
  20. Too much water damage?
  21. freeze proof faucets manfacturers?
  22. Changing water pressure on house pressure regulator.
  23. Copper Kitchen Sink- Need Advice ASAP!
  24. Any issue with placing soil stack outside of a house?
  25. Removing PVC threaded section from cast iron
  26. BEFORE I buy new tub/shower trim - some questions
  27. faucet id help!
  28. Pressure Tank only gets up to 20 PSI
  29. Cracked heat exchanger in furnace
  30. Noisy water flow
  31. Is this where I go to ask for a dishwasher?
  32. house main shutoff
  33. Need Urgent Help for Tem Cartridge Removal
  34. Main stack vent horizontal offset question
  35. Installing new tub - is there an easy way to extend PVC drain pipe 1/2"
  36. Thermasol steam unit
  37. sealing gas pipe threads ?
  38. Kitchen-washer cast iron drain is corroded
  39. Combining Vent Pipes
  40. Ridiculous Pipe Knocking
  41. Possible sewer line failure?
  42. tankless water
  43. Landscape Fabric Under Tub?
  44. Toilet Venting - Distance to vent
  45. Tub Deck Valve Installation
  46. Nibco faucet handles
  47. Replacing ABP Frost Free Hydrant 455-06
  48. Basement bath backing up, have not located clog. Amateurs request advice.
  49. Fair price for a slab leak repair
  50. Brass pipe has same OD as 1/2"copper coupling
  51. Is there a plumbing equivalent to Richter's "Practical Electrical Wiring" book?
  52. Hans Grohe Aqua Era Kitchen Faucet
  53. Water Meter Pusating Noise?
  54. New attic drain into existing
  55. Vent Pipe
  56. pex in the ground
  57. Kitchen Sink Drainage Problems
  58. Cast to PVC to Cast to PVC
  59. Threaded Connections and No Access Panel
  60. Replace copper pipes or line them here in hard water-plagued san diego county?
  61. how to protect buried black pipe
  62. Lead P trap under tub?
  63. pvc thread repair
  64. Pex Shutoff Valve
  65. Does a washer standpipe have to be a single piece or can it have slight bends?
  66. Shower P-Trap Help
  67. Permaseal P traps
  68. Connecting P-trap to drain for tub
  69. Wanting to build bath in basement using existing rough-in plumbing.. Venting?
  70. Kitchen Sink Drain Space Issue
  71. Urgent: Kitchen drain issue
  72. Can you tell me the brand and model of this faucet?
  73. Basement Plumbing Diagram Help
  74. bathroom fixture shutoff question
  75. Bathroom remodel
  76. Galvanized for gas in fireplace?
  77. Help drain a pedicure chair
  78. Replace Main Shut-off Valves - Cost
  79. Water Pressure Booter Pump w/softener and whole house filter
  80. leaking fernco
  81. Used Kinetico
  82. U-shaped connector under sink????
  83. Removing tub drain from septic system, good idea or bad idea?
  84. Witching for pipes Video, this is how you find underground pipes.
  85. Plumbing Double Vanity (Remodel): Please Check My Plan
  86. plumbing 2 showers
  87. Horizontal run
  88. Green sediment in water
  89. Terry, can you help me
  90. Pipe route question
  91. well pump
  92. Help Me Remove This Moen Faucet From This Sink
  93. New Here - Getting Ready To Plumb an Entire House
  94. Proper fitting question
  95. Cast iron short sweep horz-horz connection exception (UPC)
  96. ABS gluing questions
  97. Kohler overflow installation question w/ pics...ASAP please!
  98. Clothes Washer drain size
  99. EPA lead laws
  100. iron P trap replacement
  101. Playing with Traps
  102. Dishwasher Odor problem -- Drain line? (PICS included)
  103. Sound Proofing a Waste Pipe (PICS included)
  104. Question on what to do now that toilet flange is exposed
  105. Loose Sweat Fittings
  106. Help...Rusted fitting won't come off...Do I need a plumber?
  107. Drain leak on new sink
  108. Fridge Water Line Connection
  109. Please Help with Kitchen Sink Plumbing! Waste Pipe is too high
  110. New 10" deep sink - now waste drain too high! options?
  111. Shower drain vent question
  112. Hot water manifold leaking and corroded
  113. New floor drain in concrete
  114. 3/8" Gas Line for Weber Genesis 230
  115. Please Assist!! Adding second vent/soil stack
  116. Pipe Leak
  117. Back to back bathrooms without a double fixture?
  118. Standpipe works great
  119. toilet waste and vent in Canada
  120. Water toilet for winter use in non heated building
  121. Tankless water line????
  122. Vent for Vanity
  123. Can I tie my bathroom sink and utility sink drains together? As well as vent?
  124. odd argentina plumbing bathroom drains
  125. Softener, humidifier, and AC drains - into trap or arm?
  126. No Plumbing Vents
  127. Outside spigot bangs when on low
  128. well-air hydro pneumatic well tank
  129. Multiple drains go to building sewer--ok?
  130. I hate shower diverter "valves"
  131. ID this weird valve after the shutoff valve
  132. Uncharted territory - clay to PVC
  133. Sharkbite VS Soldering
  134. Frost proof faucet problem
  135. Question on k-Rain Hyrdrotek 1114
  136. Prime floor drain trap from standpipe?
  137. Outdoor Faucet....Can't Get A Good Seal
  138. Size of drain pipe for high performance shower?
  139. Kitchen / Bathroom / Laundry Project Creeping...
  140. Supply lines ran overhead..air lock concern?
  141. Shower Drain Leak
  142. Do I have a supply-line leak?
  143. Half Bath layout - please check
  144. New septic system.
  145. Replacing old cast iron elbow in wall. How do I fix this?
  146. I found this Visual Guide to Plumbing very helpful
  147. Moen Frost Free Silcocks
  148. Clothes washer rough-in
  149. Hubless coupling questions.
  150. Connecting CPVC to PVC
  151. Corrosion at copper joints. Why??
  152. single handle kitchen faucet
  153. Ondine parts
  154. Undersink waste pipe leak
  155. strange kugler faucet problem
  156. Washer stand pipe, trap, and drain within one stud bay
  157. sewer gas smell from new shower drain
  158. Revised DWV
  159. Toilet Flange spacers
  160. Uneven wall/tiling
  161. gas systems
  162. hook two water lines to one stop vavle?
  163. Bad pressure regulator?
  164. Bathroom waste/vent piping [PICTURE]
  165. Rock Star Plumbing
  166. Supply (& DWV) lines in exterior walls
  167. Basement Sump Pump Siphoning & Air-locking
  168. Which Manufacturer?
  169. Hydronic Heating question... need answer fairly soon.
  170. Bathtub copper pipe leaking?
  171. BrassCraft 1/4 turn G2 water stop
  172. Outside fauset- anti syphon valve
  173. DWV piping won't pass pressure test
  174. is it the water pump?
  175. vent through a wall
  176. Adding a sink on the 2nd floor
  177. Chicks and Dicks Softball with Love Plumbing Logo
  178. Pressure/Push activated valve
  179. Flushing the toilet shakes the house
  180. A Quality Hose Bib
  181. Vent Pipe Manifold
  182. Fixing a PVC to cast iron connection
  183. Nipple with cocked threads?
  184. Suggestions for good online PEX supplier
  185. Sink not draining correctly
  186. Backflow Prevention Testing Certification
  187. Need advice on venting 2nd floor bath
  188. curious about a septic no-no///
  189. Bow's SuperPEX??
  190. Offset tub drain when the floor joist is in the way.
  191. Mega showers have may go the way of the brass faucet!
  192. outside shower hookup to house supply
  193. Ken Griffey Jr retires today, June 2nd 2010 "He gone!"
  194. DFU load when 2 dishwashers. ( = 3" pipe ? )
  195. Lead flashing for 3" stink stack -- sealant required?
  196. Connect to spigot & hub or reroute?
  197. How to connect to hub & spigot cast iron?
  198. Leaking widespread American Standard bathrrom sink faucet
  199. replacing my bathtubs. Tub drain is threaded into the trap???
  200. AO Smith Vertrex
  201. Cherne Clean Seal OK in Brass Test Tee?
  202. Sink clog- time for the Calvary?
  203. Hot Water Heater problem
  204. What kind of spigot insert is this?
  205. Remote hose bib uphill from house
  206. How much to replace a ondencing boiler?
  207. sizing natural gas grill line.
  208. Can you help me identify this frost-proof faucet?
  209. Installing New Pressure Reducing Valve
  210. New Toto Drake-Hissing sound
  211. [B]Anyone know the expected lifetime of a Proflex no hub coupling?[/B]
  212. Dishwasher waste water
  213. PVC joint dry-fits too loose?
  214. Internal Pipe Cutter
  215. PVC Pipe Drain Clearance to Furnace/Boiler Flue Pipe
  216. Tools for sweating copper pipe, questions & answers
  217. PVC Into a Cast Iron Cleanout?
  218. Kitchen faucet hot line slow after water shutoff
  219. PEX for home fire sprinklers?
  220. Replacing Arrowhead Frost proof Faucet
  221. Mysterious Drop Ceiling Water Stain
  222. Need help! Constant Vibrating pipes!
  223. Sump Pump and Floor Drain
  224. Updating exsisting plumbing
  225. No drywall/sheetrock --> did I screw up?
  226. Pex really scale proof?
  227. Supporting 45-deg run
  228. Kitchen hot water pressure
  229. Rough-in for Toilet
  230. Delta 2 handle bath faucet (3555) - leaking from under spout body
  231. Really bonehead move... now I need to remove PEX from a manifold
  232. Problems with Terry's washer drain pic
  233. New valve/faucets w/Ace Duraflow coating in place
  234. Radiator piping
  235. Does my pipe have leprosy?
  236. Icemaker make-up water slow
  237. Kohler K-304 to K-306
  238. Leaking compression connector PEX hose under sink
  239. Advice on Choosing Bathroom Faucets
  240. Bleed air from terminated drain lines for leak check?
  241. Test ball / balloons?
  242. Red Seal Exam
  243. PEX cinch or crimp best?
  244. pex to fixture transition
  245. replacing old pipe.....need help picking out what to use....CPVC, PEX, Copper???
  246. Gas pex question
  247. Viega vs uponor pex...which is better
  248. Dryer vent
  249. Advice please on Delta single hande shower faucet
  250. What torch do I need?
