View Full Version : Plumbing Forum, Professional & DIY Advice, Tips & Tricks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77
  1. New format
  2. High water pressure - intermittent
  3. How do I remove a sink drain pipe?
  4. Color matching different plumbing mtfs.
  5. pex and steam heat
  6. PEX Homerun manifold - use 1/2" or 3/8"?
  7. Oaty Twist'n Set flange feedback. Is it leak proof?
  8. GE Refrigerator Ice Maker Water Supply Issue - sprays water into ice cube bin
  9. Fitting a drainage tube on an air gap (I cut it - is that wrong?)
  10. Smelly new radiators- help!
  11. MAPP vs Propane for 3/4" copper
  12. "Notching" studs vs. holes in studs for copper pipe?
  13. I need to go from a CI Hub to a PVC drain...
  14. Questions on venting my basement bathroom plumbing...
  15. grinder pump clogging up
  16. Can I tie new drain to old vent system?
  17. Exhaust fan through soffit--how?
  18. What is best/safest way to cut cast iron drain pipe (or "undo" the fittings)?
  19. Anyone used Moen ioDigital?
  20. How to fix cleanout
  21. plumber not using purple primer
  22. Opinion Poll
  23. vent terminated in attic - condensation problems
  24. sweating toilet tank
  25. Slow Drain
  26. Kitchen faucet copper pipes
  27. No hot water in Master Suite ONLY!
  28. Green sheetrock or Durock?
  29. Toilet and tub at almost the same level - condo with no tub rough-in
  30. Sink Wet Wall Drain(s)
  31. Installing a self-contained macerator pump (Saniflo) in a pit
  32. Is this bathroom idea possible(pics)
  33. GAS Leak Detector
  34. Quick code question - IPC
  35. plumbing test on new dwv pipes that vent into existing
  36. pex compatability
  37. Re-locating toilet drain
  38. What to watch for with pex?
  39. The server was rebooted
  40. new supply lines install question
  41. 'L' vs. 'Y' DWV routing under concrete and wet vent size for basement bathroom?
  42. gas valve next to electical outlet?
  43. Dog Pen
  44. Return bend only, for kitchen sink trap?
  45. Can vent dip down a small amount?
  46. Milwaukee SubScanner
  47. crooked PVC toilet flange
  48. Help with trap replacement
  49. Horizontal drilling/boring
  50. Which vent option is better?
  51. California: New closet flange code?
  52. double sink garbage disposer with drain behind disposer
  53. Copper Sweat or Compression Fittings Metric to Imperial available?
  54. Shut-off valves leaking
  55. Trying to replace my kitchen sink drain strainer...
  56. How should I do this?
  57. Converting from El-Kay to Moen?
  58. Bob Vila the MilkMan
  59. Loop vent for bathroom sink?
  60. In Wall Horizontal Pipe Runs
  61. ABS closet flange too high. What to do?
  62. help with our new house plumbing
  63. Locations Of Trap Adapters
  64. Lav draining well but.....
  65. Recessed 1.5" Nipple Removal?
  66. Long wait for hot water in half bathroom
  67. Pressure regulator drifts up during night - What to do??
  68. Loose faucet base problem
  69. Toilet vent confusion
  70. basement plumbing help
  71. Basement Laundry Tub & Washing Machine question
  72. AAV on shop utility sink
  73. Case wall mount 1100 toilet
  74. Zoeller M264 stopped pumping
  75. kitchen sink drain basket....can't find the right one. HELP!!
  76. Which line to use for water feed?
  77. Quick Question
  78. Can you really vent this way?
  79. What do you think? Lav and Shower waste and vents
  80. Annual Problem
  81. Delta Diamond Seal Technology faucets
  82. What brand faucet?????
  83. Installing Kohler K-304 pressure balance valve
  84. Question about rough in - Delta 1700
  85. Change Vanity Plumbing:
  86. Strange smell from new pipes
  87. Jog vent outside...?
  88. Restricted flow in radiant floor
  89. Is this kosher?
  90. Commercial sink in residence
  91. Switching Drain Fields Question Soggy new one vs reusing old one
  92. Questions for professionals or experienced DIY's
  93. Hot water - Washer/Dryer problem...?
  94. sweating the small stuff
  95. Mixing valve pressure & whistle noise
  96. How to Drain the Dishwasher when the Sink is installed over in the Island
  97. Basement rough in
  98. Use of combo fitting
  99. Primer
  100. Installing faucet question?
  101. crawlspace plumbing photo critique needed
  102. Inexpensive sink side spray heads
  103. SS Braided Hose vs. copper/with compression nuts
  104. Tying PVC into Cast Iron Drain -- in Los Angeles
  105. drain ?'s - proper use combos, etc
  106. Giving advice and help to friends? What is your experience?
  107. Running a gas line to fireplace
  108. Wye from toilet into stack?
  109. old brass pipe
  110. Another basement bathroom
  111. Frozen Pipe Issue
  112. Moving A Soil Stack
  113. Basement Bath Shower Pan Planning
  114. Help with washing machine drain connection
  115. classic toilet flange question?
  116. How to separate PVC pipes
  117. Setting water pressure question
  118. moving closet flange sanitary t or wye?
  119. High water pressure
  120. Flange Questions with Picture
  121. change this kitchen drain pipe or not bother
  122. Cleanout Orientation
  123. Basement Bathroom Project
  124. Residential Plumbing and pipe size
  125. Where do you find articles?
  126. heavy rain and septic question...
  127. PVC Pipe Cutters
  128. (another)basement rough in
  129. Are open drains a risk of infections?
  130. Trouble securing closet flange to concrete floor
  131. Sink Drain question
  132. Island Bathtub
  133. Do I need a hammer arrestor?
  134. restaurant grease trap install?
  135. Sink drain tail too close to stub in wall
  136. Propane Stove Reconnect
  137. Garburator Blocked Please Help!!!
  138. Minimum Trap Arm?
  139. Replacing heat element
  140. The elusive "double fixture fitting"
  141. Toto Soiree pedestal sink questions
  142. Moen Hydrolock
  143. Drain & Vanity centerline offsets
  144. Is there any acceptable way to glue a PVC fitting onto a galvanized pipe stub?
  145. Mystery Valve
  146. new drain question
  147. Plumbing woes....main line.
  148. serializing a 40 gal water htr to a existing 50
  149. Honeywell Aquastat & Outdoor Reset Module
  150. Thermo-siphoning in Active Solar Hot Water System
  151. Septic tank location
  152. Re-locating an Aerobic Septic Tank System or use system as-is?
  153. Smoke Bombs
  154. Disposal Question
  155. kitchen sink drain
  156. Pop Up Drain in Vessel Sink Drains Slowly
  157. Recessed garden hose boxes
  158. Moen rough in valve 3320 3330
  159. P trap and tailpiece too close!
  160. mixing and matching finishes across brands
  161. American Standard warranty
  162. Inline water pump
  163. Floor Cleanout?
  164. Cracked main drain..advice desperately needed
  165. Dual Vanity
  166. Considerations for Burying Sump Pump PVC Drain Pipe
  167. New Standpipe install, info
  168. 3 Comparment Sink, Mop Sink and pluming it
  169. Questions regarding Fernco Fittings
  170. Basement Plumbing Rough In
  171. Washing machine and utility sink tie in question
  172. Viega: PureFlow PEX Crimp v/s PureFlow PEX Press
  173. ProPEX® EP Stop
  174. Momentary Cold water
  175. could be good...could be bad
  176. water heater leak!!
  177. Looking for comments on bottle traps
  178. Is this water closet drain vented properly?
  179. Small job turned big.
  180. old moen kit sink faucet
  181. Garage Utility Sink
  182. How to install lavatory legs
  183. Aluminum Pipe Wrenches
  184. Inadequate Main Drain Slope Under Mono-Slab
  185. Cartridge faucet still dripping from spout after cartridge has been replaced?
  186. slab leak repair - near old foundation repair with piers
  187. Faucet recommendations
  188. Pedestal sink installation problem
  189. Yet another toilet flange question...
  190. copper to pvc 2"
  191. Basement utility sink pumps?
  192. Best Plunger for fitting Toto
  193. happy but sad
  194. Another Broken toilet flange thread!
  195. Hard to find
  196. Will 4" be enough to vent a tub?
  197. Fixture venting question
  198. Need New Gas Lines From Meter Run. Thoughts on What Plumber Told Me Option Wise
  199. med gas
  200. basement flood
  201. shower vent ?
  202. Water pressure in the house
  203. standpipe and other rough in
  204. Hss
  205. Vent for Bathroom Sink
  206. Can I “winterize” the charged water feed lines in my cottage with RV anti-freeze?
  207. Bad brass threads?
  208. Cottage pump and pressure tank
  209. Washing machine P-trap question, under floor?
  210. Main line backed up again!
  211. Any tricks for dealing with misaligned sink drains?
  212. Valve Basics
  213. Is one way better than the other way
  214. Leaking garden hose valve.
  215. amtrol 41
  216. Someone should invent a substitue for pipes
  217. Leaking in-wall lav faucet valve
  218. Metal Roof PVC standpipe is loose
  219. how high
  220. Kitchen peninsula venting
  221. Bathtub Drain Kit Issue
  222. water closet/flushvalve question
  223. How tight is 'tight enough'?
  224. Smelly water and black stuff comes through the faucet every couple of months
  225. help with "O" rings
  226. Need DWV Guidance
  227. backfill - what do you like?
  228. insulating pipes
  229. Recirculation Pump
  230. Pex pipe problems
  231. Installing a wash tub
  232. Humming noise in water pipes after installing an RO filter
  233. Green particles collecting in faucet aerator - not dip tube
  234. Revised post re: hot water taking tolong to get to faucet
  235. Test fitting pvc
  236. Tie into cleanout for sink, vent question
  237. Can I tee this particular run in a PEX homerun?
  238. DWV System: Do you guys see anything wrong?
  239. uponor and manabloc manifold?
  240. Lavatory Drain Stub Out length?
  241. Wet venting shower through the lavatory - look okay?
  242. Brass lavatory drain conundrum
  243. Crane Walsan in-wall Toilet Questions
  244. No Venting
  245. Cast Iron pipe - Lead removal and resealing
  246. Help identifying a stem?
  247. reverse osmosis system
  248. First "big" DIY task - Basement DWV
  249. Looking for a 2 inch bathtub drain assembly
  250. Sump Pump Replacement and Check Valve
