View Full Version : Plumbing Forum discussions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Time for new pressure tank?
  2. Brazing
  3. drip drip drip
  4. Leak from base of American Standard faucet
  5. Proposed layout for bathroom drain lines
  6. no hot water in shower or tub
  7. Overflow drain for tub
  8. DWV fittings allowed in concrete?
  9. pb piping info
  10. Drain maintenance
  11. Flat Rate or T&M?
  12. Electrocution of Plumber
  13. can I cap off a hot water radiator?
  14. Commercial venting
  15. city water pressure
  16. Re-plumb/ turn off water?
  17. temp change
  18. Bathtub gurgles
  19. Whole House Water filter? Will that make the Sulfer smell go away?
  20. flexible pipe under subfloor
  21. Two hot and two cold 1/2 inch water lines any valve to use.
  22. Trap Seal Primer
  23. Tip on Wrangling Black Poly Coil
  24. Saniflo...Plumbing Code?
  25. little tankless's
  26. Pin Hole Leaks in Kinston Brass Faucets
  27. An All-metal Dishwasher Air Gap
  28. Lower pressure on new bathroom
  29. Copper rings with Wirsbo?
  30. Basement bath design review
  31. New Drain Lines
  32. Replacing Cast Drain Project
  33. New shut off valves releasing water when off?
  34. Buying Uponor ProPEX tool for DIY'er
  35. 1949 waste lines : any life left?
  36. How can I add a p-trap to finally resolve stinky laundry room!
  37. Delta Shower valve install
  38. New second floor bathroom: Drain design check
  39. All Moen's alike?
  40. Pressure Drop Across Thermostatic Mixing Valve
  41. Toilet drain replacement
  42. Testing Drain Lines
  43. Anyone see any problems with this install
  44. low water pressure
  45. Pex vs FlowGuard Gold
  46. More Shower Head Angle
  47. Question about toilet venting requirements
  48. Ball Valve Leaking Internally
  49. Sink faucet installation help
  50. Question about vent layout
  51. Basement bathroom plumbing options (pump up to septic line)
  52. Is there a proper way to route PEX through attic?
  53. moving faucets and showerheads
  54. Pedestal sink with no overflow
  55. Venting Under a Porch-National Code Reference
  56. 3" copper - Moving toilet
  57. Is this valve easy to replace? Pic inside...
  58. parts for pedistol sink
  59. Valve Identification help.
  60. Kitchen faucet sprayer does not work
  61. Gasketed pipe direction of flow
  62. Copper tubing in slab
  63. Home Run Plumbing System
  64. PRV and location for install
  65. Repair PVC drain pipe - small leak
  66. Suggestions for a powered hydronic valve
  67. ABS in Highrise buildings
  68. Crawl Space
  69. Toilet noise question?
  70. Is 1/2" female NPT the same as 1/2" FIP?
  71. woodford hydrant
  72. Hot Hot Hot Water!
  73. Vent issues
  74. "Bubble, Bubble Toil and Trouble"
  75. Which brand for RPZ, Watts or Cash Acme?
  76. AquaPex and the ferrous issue isolation
  77. fiberglass shower basin out of level-help
  78. Comment for the plumbers and big box
  79. washer vent, is this ok?
  80. 1950 home on slab, returns on floor
  81. Changing from Dura Pex to Uponor
  82. Question on drain for utility sink install in basement
  83. small leak above zone valve?
  84. Hot Water Heater problem
  85. Low water flow/pressure
  86. What solder to use to install zone valve?
  87. Under Sink Shut-off Valves
  88. First time installing dishwasher, elbow connection question
  89. Gas hot water heater, problem
  90. Wondering if I have a circulator pump problem
  91. Odd sized sink basket
  92. Emergency shut off valve (for leaks)
  93. Underground Pex Installation Questions
  94. Vent for Roman Tub
  95. I need feedback on my techniques of bathroom plumbing
  96. Are all toilet bolt locations the same
  97. Should I get a permit for a basement bathroom?
  98. XH cast iron properties
  99. new online encyclopedia of welding terms and info
  100. How can a drain pipe in a brick wall be repaired?
  101. Ikea Sinks
  102. Septic doom on the horizon ??
  103. NPT thread length to tighten
  104. Failed house water shut off valve.
  105. closet flange to closet elbow distance
  106. How to detect leak under a slab with underground pex
  107. Re Routing Stack of drains and water lines
  108. Basement remodel - bar sink, utility sink - design
  109. washerpan or drain
  110. Initial hammering Sound when open Tap
  111. Badger 1 electrical requirements...
  112. Is this disposal plumbed right?
  113. Bar sink venting...7' away from the wall
  114. Help identifying wall mount faucet
  115. Constant Knocking Noise from Pipes
  116. Slow draining lav without overflow
  117. Update on exterior water supply line
  118. is this legal?
  119. Main Vent Clogged
  120. Bathroom and Kitchen sink Dains slow and girgles
  121. Price Pfister Madness
  122. water meter
  123. pex insulation
  124. Smoothie
  125. Replacing Cast Iron Waste in Kitchen Wall
  126. Hot Water Singing...
  127. Help removing a shower valve stanadyne
  128. water pipe repair with sch 40 conduit
  129. Hydrants
  130. Routing vent under slab?
  131. Cast Iron Question
  132. Where can I find a nice floor drain strainer?
  133. ABS fitting inside concrete footing?
  134. awkward..how to seal drain pipe???
  135. Alteration to Washer Stand Pipe
  136. Water Smells like Sulpher
  137. Avoid damage to tree
  138. best way to cut pvc pipe?
  139. One More Hose bib question....
  140. Expansion Tank Question
  141. foul odor in all drains
  142. Moving/recessing basement cleanout?
  143. Sump float switch position
  144. water flow indicator on main line
  145. Water Quality Testing
  146. Is it okay to use PEX for fixtures or should I use copper for the rigidity?
  147. is my PRV shot?
  148. Gas LIne Sizing?
  149. Little Help Routing Drains
  150. Cold Water Spurting Air
  151. Draining a Washing Machine in the Basement
  152. Dishwasher Hookup Help
  153. Another basement bathroom
  154. shallow well jet pump mystery
  155. Moving a toilet (with a flat vent)
  156. gas line question
  157. Kohler WaterHaven Leaking Problems
  158. "Big Blue" Insurance
  159. Replace toilet shutoff valve
  160. Just to get you guys worked up, what do you think of this?
  161. Double Sink in Bathroom Vanity
  162. ABS vs. PVC- marine application- building a shark cage
  163. When our well kicks in, things drip.
  164. Replacing or Repacking Leaky Stop Valve?
  165. bonding/grounding and pex
  166. pump running;water murky
  167. What are you gents doing to get rid of "Gnats" Fruit Flies coming out of Sink/Drain?
  168. Please help; new faucet won't turn off
  169. Transition from galv supply to copper
  170. 1/2" or 3/4" supply for bathroom in far end of house?
  171. Trap under slab - concrete over or leave exposed?
  172. No pump in sump...
  173. Washing Machine Drain Question
  174. PEX: crimp or compression fittings?
  175. Second story remodel adding bar sink
  176. Brass or Bronze
  177. Gas Explosion Rocks Puerto Rico
  178. expansion tank issues
  179. Stainless Steel Strainer for kitchen sink
  180. Copper drain lines
  181. water tank questions
  182. Will Plumber know what crimp ring to use on Uponor PB to PEX fitting?
  183. Crack in Hung Sewer
  184. Noise coming from meter/PRV area
  185. ABS sunlight exposure
  186. Type of valve
  187. Overhead sewer system tie in.
  188. I'm working without a permit again
  189. Single bathroom vanity sink into double bathroom vanity sink
  190. moving the toilet
  191. Pressure Tank Bladder
  192. kitchen sink draining into dishwasher
  193. Washing Machine: breakdown of the cement balance weight around the drum
  194. New Bathroom - Venting and Draining
  195. help with laundry tub, washer hookup
  196. Drain Pipe too high (kitchen sink) for disposal
  197. Replacing Main Stack
  198. Hose Bib - Slow to Flow
  199. 2 Shower Drains
  200. Cleanout 4" into wall?
  201. Stack Venting
  202. To plug or not to plug...
  203. sink hole cutout mistake
  204. Favorite valve?
  205. Pex to Copper
  206. Hot water heater plumbed in reverse
  207. Kitchen Faucet Located Close to Wall/Backsplash
  208. Basement plumbing rough-in
  209. How to join new cleanout to angled sewer line?
  210. Disparity in replacement washer drain hose size
  211. Tile in Bathroom leaking from Underneath!
  212. removing rusty drain from antique sink
  213. Utility Sink Standpipe Conversion
  214. PEX, Water service from meter to house, DIY project????
  215. expantion tank location
  216. Its now or never...decisions (Two questions)
  217. How to Locate sewer pipes in basement floor
  218. Cast Iron Baseboard Radiator
  219. Pressure Reducing Valve Sweating?
  220. Sewage in shower; no clean-out?
  221. Washer water supply valves won't turn
  222. A change of plans
  223. boring holes in studs without right angle drill
  224. head scratcher
  225. KBI cpvc valves USA made, any opinions?
  226. hansgrohe axor pull-out kitchen faucet
  227. Valve corrosion
  228. Removal of Single Handle Gerber Faucet
  229. question about home radiator
  230. Clean-Out Location
  231. New p trap in kitchen
  232. Legend cpvc, or Mueller brass ball valve?
  233. pedestal sink leak
  234. Bathtub Drain Hair Catcher
  235. Kohler shower valve model GP71969
  236. RO system pre-fill & sanitizing
  237. DWV help me make it right! (CAD renderings included)
  238. How does the dshwshr rinse agent get into the rinse?
  239. Compression Stop-Valve Problem
  240. mobile home kitchen sink question
  241. How close can PVC and copper be?
  242. water heater flex question
  243. Any One got an extra ball valve
  244. New vanity drain doesn't line up
  245. Toilet Drain
  246. Soil Stack Question
  247. Question - Plumbing/Electrical
  248. Stack Venting - Toilet and Shower
  249. Supply Lines
  250. Running Flushometer Toilet
