View Full Version : Plumbing Forum discussions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Anyone Had Experience With GFX?
  2. What is the fair solution?
  3. Air gap RO faucet
  4. Flex Connectors - Water Heater
  5. shower help - can't stop the leaking
  6. fitting redo??
  7. Kitchen Faucet Moen 7730 - how to remove handle
  8. is this water hammer?
  9. Septic additives
  10. Hot Water Woes
  11. Water Testing
  12. Drain re-config
  13. Venting a WC waste line horizontally
  14. 3 inch sewer main???
  15. Confused about what to do, please help...
  16. Confused on Drain Line Routing
  17. cold water line shaking when tub fills?
  18. Problem removing bath
  19. Fixing my utility sink and laundry drain...
  20. PEX questions
  21. is it okay to have tub faucet on exterior wall?
  22. A Kohler Shower Handle was Lost!
  23. changed vent pipe to PVC but not aligned
  24. Floor cut too far to mount flange to floor
  25. service stops and bypass for rough in
  26. Remodeling Bathroom: Need advice with plumbing/venting
  27. Question About Temptrol Trim Change
  28. Sewer smell from under sink and adjoining closet, but not from drains?
  29. Dishwasher Island Drain confusion
  30. pack a gate valve under pressure
  31. Utility Drain
  32. water heater problem!!
  33. Adding a cleanout to septic line
  34. toilet install
  35. American Standard faucet - weird problem
  36. Wet Venting, Plumber Made Mistake, Opinions
  37. Bathtub located at load-bearing wall?
  38. moving water supply line - difficult?
  39. Draining first floor stand pipe into basement standpipe
  40. Smallest Shower & Toilet possible?
  41. thermostatic shower
  42. Burried Natural Gas Pipe
  43. CPVC vs PVC
  44. No more hard copy parts books
  45. PoliMex
  46. Vent size ?
  47. what is the easiest way to mesure fall or slope in waste line?
  48. Washing machine outlet box
  49. need help...
  50. Dishwasher Island without a sink?
  51. to eject or not to eject that is the question
  52. Help with proper fittings, pic included
  53. toilet water running
  54. replacing basket strainer
  55. Low Pressure in Bathroom
  56. New plumbing job look ok?
  57. setting new pvc drain height for pre-formed shower pan
  58. CPVC to outdoor sill faucet
  59. What's eating the pipes
  60. Will this ever be a basement bathroom?
  61. PRV troubleshooting...
  62. Air Gap Question
  63. Sewer smell or mold
  64. Hot Water Issue
  65. Another Flange Bites The Dust... (How to Repair?)
  66. Problem with Sink Floor Drain
  67. Georgia, 2006 IPC - does this old work look up to code?
  68. cleanout pipe threads corroded!
  69. Problem with Laundry Drain. Photos Included.
  70. Vent Upstream from Fixture?
  71. Dishwasher - Appliance Issue
  72. Slow Drain
  73. too much is going wrong!
  74. hot water violent surges
  75. what causes cavitation?
  76. Novice looking for information on installing utility sink in basement
  77. Help -- Leaky Toilet, Broken Flange, Soft Floor
  78. Washer drain-- Did plumber do this right?
  79. Which drain to use when converting from double to single sink
  80. Sump pit always has lots of water - next step ?
  81. toilets slow to drain
  82. Failed Cast iron drain lines
  83. New Bathroom fixtures
  84. Nibco Dura Pex questions
  85. Concrete Subfloor
  86. No water from outside faucets
  87. No hot water on Moen Shower Faucet
  88. Low water pressure from tub water pipe
  89. Keeping Faucets From Spinning on Granite
  90. Copper to CPVC
  91. Finishing Basement - Expanding Existing PEX Sytem
  92. Is this vent above the toilet legal?
  93. Expansion Tank
  94. Old water cistern
  95. How to flush out dirty water after turning off and on the water main?
  96. Laying sewer pipe 300 feet deep, and the machine breaks!
  97. drain saddle for 1 1/4" metal tailpiece
  98. Venting a WC waste line horizontally II
  99. Washer hose leak, how often do you change hoses?
  100. Can I install a new vent system for basement bathroom
  101. New hotwater tank, fizzy water.
  102. What type of Pipe?????
  103. Wet vent question
  104. No vents installed in barn before concrete was poured.
  105. Adding standpipe to vented shower run
  106. Normal pressure drop?
  107. Hearing Gurgling In Other Pipes When Toilets Flushed
  108. Newbie from Chicago checking in
  109. redoing copper sweats
  110. outdoor faucet
  111. Do I see a flange or top of a drain pipe
  112. Dishwasher Drainage Pipe To Flexible Hose
  113. water main ?
  114. Ready to Rohl?
  115. Help! Shower overflows when washer is on!
  116. flexible copper pipe question
  117. Removing old pvc drain
  118. sump pump/floor drain question
  119. Need Feedback on DWV Plan for Addition
  120. Why everyone wants to be a plumber
  121. Is Cellular PVC OK in 4" Stack
  122. Shower is great...
  123. Replace PVC with cast iron in vertical?
  124. Removing Antique Sink Widespread Faucets
  125. Free Estimates
  126. plumbing over electric panel
  127. new faucet and drains led to sewer gas smell
  128. Bathroom faucet stem make from pic
  129. sump pump
  130. Exposed Pex in house?
  131. Delta VS Moen shower valves
  132. New kitchen sink, questions about drain lines
  133. Adding bathroom to basement
  134. Lukewarm water all faucets
  135. gas line kinking
  136. Most inconvenient leak...
  137. Push-on valve question
  138. Cast Iron Baseboard Brands
  139. Tough shower faucet removal
  140. Vacuum breakers
  141. Found something odd. . . .you ever see this
  142. Flotec Bar Sink Pump
  143. I need some info on moving my toilet
  144. Lift and Turn Tub Drain
  145. newbie question on drain couplings & solids hanging up?
  146. Plumbing Leak?
  147. PEX Manifold to Water Heater Distance
  148. THANK YOU - Terry and all the pro's
  149. "Water Hammer" When Turning Faucet ON ?
  150. draining supply lines
  151. What is this plumbing part?
  152. Basement toilet overflow from heavy rain
  153. Supply lines for washing machine?
  154. cold water pressure in faucet slower than hot water!
  155. Please help! PEX newbie.
  156. I drained the system...and NOW I have water hammer????
  157. Bladder to feed a cold water line that has low flow on city water.
  158. 5/8 water meter connection
  159. Any one else terrified of Copper plumbing
  160. Leaking Waste Drain Stack
  161. laundry sink snapped off plumbing
  162. I used too much flux -- flushing didn't clear it
  163. Water Overflow Pipe Dripping
  164. Webstone Pro-Connect
  165. What the heck is this?!?!
  166. Woodford 67C wall hydrant
  167. need to trench for a water line.
  168. rough-in question
  169. copper caper
  170. Where should a toilet supply be?
  171. copper pipes over old wiring
  172. Funny sounds and pressure drop at shower issue
  173. hot/cold taps position on basin
  174. Water ON causing a Throbbing Noise
  175. Your showerhead can kill you ...
  176. Finished Basement with Exposed Ceiling Pipes - Can they be moved?
  177. Bringing in a new water supply line
  178. pipe threads with teeth?
  179. Plumbing Stack
  180. Water Pressure
  181. Vent Stack Where?
  182. What is this pipe?
  183. HELP-bathroom drain/main problem?
  184. How do I turn this valve?
  185. Off white particles from WH flush
  186. Leaking Outdoor Faucet?
  187. Water Shut off valve for residence
  188. Copper Water Valve you perfer?
  189. Tips for using Flexicable Copper Tubing???? Downsides?
  190. Extending PVC Toilet waste pipe
  191. Help installing shut off valve on copper pipe
  192. Pex Wirsbo uponor tool
  193. 3rd Floor Bathroom
  194. Water Pressure
  195. comments on new laundry config?
  196. Electric Pipe Wrap
  197. Supporting copper pipe
  198. Drainage from Washer....where should I run the line?
  199. Extender for faucet spout shank
  200. Weird question
  201. Can I use vent line in attic?
  202. Elbow between p-trap and vent?
  203. Sealing 3" Rodding access Threaded Connections
  204. Blow out pipes
  205. Drain Basin Question
  206. millside36
  207. Drain for garbage disposal
  208. Removing a Zurn QickClamp
  209. Did my contractor mess up our entire plumbing system?
  210. Toto Soiree TL960SLD Lav Faucet
  211. Aquadis parts source?
  212. Adding a wye in basement cast iron stack
  213. Re-piping the main loop of a cast-iron radiator system
  214. Exterior Plumbing Question......
  215. PVC to CPVC Adapters
  216. Wisbro PEX compatable with Manabloc?
  217. Water heater question - cold water, water leaking thru overflow pipe
  218. New Dishwasher Plumbing Questions
  219. trap design help on new vanity
  220. Sleeving Pipe to Garage
  221. Kohler Valvet (I think) conundrum
  222. New Washing Machine Drain Trap Location?
  223. Cutoffs
  224. AAV Placement Confusion
  225. Coventional instal vs. macerator
  226. Pex in Block Construction
  227. Which 1/4 turn ball valves to get?
  228. woods cabin dwv
  229. Hot tub question
  230. Need Dishwasher Snap Aerator
  231. new house(old) house - no WM vent?
  232. Faucet stem unscrews, but won't come out
  233. Mysterious Water Draining from my house
  234. metering
  235. faucet engineering
  236. pipe leak under lawn?
  237. Sulfer Rotten Egg smell after running water....
  238. Pump Control Cuts Off & On Repeatedly?
  239. Septic line DIY replacement
  240. High water pressure
  241. Pump Control Cuts Off & On Repeatedly?
  242. Mixing Valve for Garage
  243. Reliant kitchen faucet
  244. Loud pipes when water is running
  245. No main vent out roof?
  246. Changing from two lavatories to one
  247. Overflow pipe dripping when heating turned on
  248. Low water volume problem from municipal water supply
  249. Refrigerator Water Hose
  250. Anti Siphon Faucet Replacement
