View Full Version : Plumbing Forum discussions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48
  1. brass to cast iron threaded connection leaks
  2. Loud Hum from Water Pipe - High-Rise Condo
  3. Double Sink Issues
  4. Do rear-draining bidets exist?
  5. Pressure drop due to temperature change?
  6. Recurring problem in 3 places
  7. Mixet shower faucet question...
  8. joining PVC to CI
  9. I augered a cat out of a drain line
  10. Shower Drain - how to open it. Help, been going crazy over this issue.
  11. Grohe shower reverse cartridge stuck again
  12. Dryer Conversion Info Needed Natural Gas to Propane
  13. boiler vent size problem
  14. need help with dvw routing
  15. cast iron fitting installed in cast iron soil pipe
  16. ok before i have a hissy fit...
  17. cooktop and wooden bar top
  18. Pic of my new plumber
  19. garbage disposal overflow to other sink
  20. Whirlpool Portable dishwasher
  21. Level a claw foot tub
  22. Question on venting
  23. MOEN HOT/COLD SILL FAUCET (hc400512)
  24. Replace 42" tub w/48" tub?
  25. Plumbing Noob needs help with Delta Faucet
  26. Sharing my recent replacement project
  27. tightening copper fittings
  28. Can this line be improved?
  29. advice on bulding up a shower base
  30. Acrylic tubs - Kohler vs Mansfield vs Laurel Mountain
  31. Replacing outdoor frost-free faucet
  32. Gas protection service
  33. Cable Drain (long cable needed)
  34. gas line
  35. anti-siphon hose bib aka PITA...
  36. Reverse osmosis - tank pressure?
  37. Sillcock replacement (with pic)
  38. warm water from the cold faucet?
  39. Replacement of leaking exhaust fan duct
  40. Bathroom shower hot/cold reversed?
  41. Sewer smell from my washing machine?
  42. Vent pipe through the roof...
  43. Source for old oversized sink drain strainer assembly?
  44. In a Moen Jam need a fix
  45. cutting into a line to put a ball valve
  46. Natural gas line????
  47. new second floor bathroom
  48. Crazy gray water recycling idea
  49. Outdoor plumbing in New England
  50. final shower base install
  51. Flux odor in water
  52. Pex Fittings
  53. jet pump can't handle the demand
  54. Drain / Vent Design
  55. Moen kitchen faucet problem
  56. Sump Pump Newbie
  57. hot wtr leak in slab AND sewage leak possible?
  58. Can an expert help?
  59. Combo ball valve/check valve for ejector pump...
  60. Grohe PB Valve
  61. Pressure Balancing Valve Output
  62. vacuum breaker leaking
  63. Vacuum Breaker Replacement
  64. 1930's Standard Mfg Shower Valve repair
  65. Anyone ever seen this type of fitting before?
  66. ball valve survey
  67. Ball valves - are they created equal?
  68. Code issue
  69. code question
  70. Gasline elbow on 1936 Norge
  71. Easy question (?)
  72. Aquapex ring slippage
  73. Leaky washerless single handle shower valve... help!
  74. Help ID faucet.
  75. Moving Refrigerator water line Pex ?
  76. Diabolical water hammer
  77. Bar sink rough-in
  78. Expansion Tank w Water Pressure Regulator?
  79. Small knob below shutoff valve?
  80. Delta 600 series copper tubes
  81. Broadway faucet
  82. hubless coupling
  83. Restrictions in Pex Modular Home
  84. sweating theory
  85. 1/2 mip vs 1/2 npt
  86. Shower - 2 inch transiiton to 1 1/2 inch and venting
  87. little flow of water
  88. Water heaters and unions
  89. Trench drain in shower using Kurdi
  90. Bathroom widespread faucet
  91. 1/2" pex to 1/4" copper for ice maker
  92. lost pressure
  93. Design looks bad but will it work?
  94. Breaking up concrete...
  95. Drain plug, such a animal?
  96. Measuring force.
  97. Slab & Foundation over existing gas line
  98. PH Neutralizer
  99. combination waste and vent ?
  100. fiberglass septic tank with a loose baffle?
  101. Existing dry vent - 2nd vent in house
  102. Mansfield outdoor anti syphon faucet
  103. Three questions about adding a basement bathroom
  104. lead closet bend
  105. Shower drain size
  106. How do I make this connection from sink drain to wall?
  107. Drain routing in bathroom remodel
  108. strict plumbing codes by state
  109. american standard shower drips
  110. Sewer drain question
  111. Rubber valve seat alternative?
  112. Leaky Lavatory
  113. new bosch dishwasher squeel after draining
  114. Garbage disposers
  115. Basement shower drain help...
  116. Can I route PEX/copper pipe through joists?
  117. Flushing drain lines
  118. 9 web 80 nnb
  119. Prier Outdoor Faucet Plastic Cap
  120. Best GRUNDFOS recirculator pump?
  121. Grohe Shower head installation question
  122. Which Hydromatic Sump?
  123. Best Way to Vent a Shower
  124. is my soldering stable???
  125. Dirt moving up through floor
  126. Water rushing/splashing noise since 48 hours
  127. installing 2 garbage disposals
  128. Nailed trim into pvc pipe
  129. Hooking up water connection to fridge
  130. Gooseneck Faucet dripping problem
  131. Poly Tubing for Drinking Water
  132. Dishwasher under Granite countertop
  133. Why an industrial ball valve?
  134. Is tub faucet cartridge failing or HW heater
  135. Basement Bathroom Reno
  136. Old iron pipe / water heater replacement
  137. Standpipe overflow/ AAV problem
  138. New DWV below slab
  139. Sharkbite Water Hammer Arrestors
  140. kitche faucet arm hard to turn
  141. Water Hammer
  142. short cycling
  143. No Water coming out of hot water heater
  144. Propane piping
  145. Sometimes you just gotta make it work...
  146. Plumbing question- PEX
  147. Shower valve connection leak, need help
  148. No Hot water from shower - Single handle knob
  149. burnt odor out of cold water line
  150. To replace or not replace...hot water heater?
  151. Water smells like rotten eggs
  152. Can the toilet be used as a cleanout for waste line in concrete?
  153. amount of water coming in
  154. squeeky new bathtub installed
  155. Mansfield Sillcock and rusted handle screw
  156. Dehumidifier capabilities question
  157. PRV - What happens when it fails?
  158. Leaky Faucet - Can't find screw
  159. Water Distribution Pipe Sizing
  160. vent locations
  161. Another wining to fog horn sound
  162. Tricky Faucet Replacement
  163. broken sewer line
  164. Plumbing permit drawing -- asking for any feedback
  165. White teflon tape
  166. Garburator Works if ABS drain pipe disconnected
  167. Help!!! Knocking Pipes in Shower!!! Only when handle in in the middle!!!
  168. Pewwww
  169. 3/4" by 3/4" brass check valve?
  170. Shower drain plumbness?
  171. PEX - Limitations?
  172. Is this to code? (Stack Replacement)
  173. Will a nicked copper pipe ever leak?
  174. Test Shower Arm?
  175. Connecting to Cast Iron P-Trap
  176. Replace Toilet Drain on Slab Fondation : Dig from under or Cut up from Top??
  177. Please help - I've lawn mowered my sewer pipe (pictures attached)
  178. chicago area plumbing question.
  179. Plumber Leery about changing waste pipes in shower room
  180. Basement rough-in vent question
  181. whistling & waterfall noises in pipes
  182. Venting a shower
  183. Sewer water standing in front yard
  184. Bathroom remodel plumbing issues
  185. Locating a gas line
  186. Moving washing machine, this is my plan...will it work?
  187. Sinkmaster
  188. Pipe movement between well pipe and pressure tank?
  189. Dehumidifier Drain Line
  190. high flow rate pressure regulator?
  191. sweating/flux ?'s
  192. sewer line questions...
  193. Sterling Vikrell & Cleaners
  194. Locate Re-nu Style Repair Kit
  195. faucet connector to male nipple?
  196. Pressure problems, etc.
  197. Please help with water line connection to fridge!!
  198. Man Hole Cover or Something
  199. Toilet base at the floor is wet.
  200. Pipe Life Expectancy
  201. Piping for water supply
  202. Exterior Spigot Profusely Leaking
  203. slow cold water flow in bathroom
  204. CAn the J bend in a p-trap be installed "backwards"???
  205. Mini Wide Spread vs. Standard Wide Spread
  206. Convert Double Sink to Single
  207. basement
  208. Going No-Lead
  209. In the Trades Forum
  210. Installing kitchen faucet with totally separate hand spray?
  211. Gas line within NYC code?
  212. sweating pipe eye irritation
  213. Pinhole in Copper Joint
  214. New Bathroom Plumbing Help Needed
  215. Why won't this connection SEAL?
  216. Pump stops and starts
  217. toilet addition
  218. bath fixtures
  219. Slow drain
  220. first time sweating
  221. Shower drain help
  222. Spread Faucet in a Pedestal Sink-- Is There an Easy Solution to this Problem?
  223. Stubborn malleable iron plug
  224. Rust under sink faucet handles
  225. 3" or 4" PVC for Sump Discharge Exterior Drain Line?
  226. Plumber's boo boo?
  227. Double Y joint?
  228. Lead drain pipe question
  229. Anyone have any sealer tricks....
  230. garbage disposal height
  231. Washing Machine -Warm Cycle is not warm
  232. PEX connection to TOTO toilet
  233. Bathroom plumbing leaks...help!
  234. Alright Here's the Deal
  235. question on leaking tub drain, can I get this part?
  236. loud "knock" heard and now water trickle
  237. Leaking or Sweating PVC below Shower?
  238. What are these plumbing elements?
  239. Venting Shower
  240. pressure tank
  241. can't stop the leaks
  242. Water heater and "closed" systems
  243. No water when turning sill cock on
  244. Are Female PVC Adapters/Couplings Junk?
  245. high temp flow reducer
  246. how to replace faucet arm washer
  247. gap in plumbing under kitchen sink
  248. PEX stubout to fixtures – How to?
  249. How do I add a shutoff valve when i can't shut off the water
  250. Patching concrete floor after rough plumbing
