- RotoRooter Strikes again... Part II
- dwv problem
- Watts Adjustable Floor Cleanout
- copper pipe in masonry wall
- New Attic Bathroom
- Vent stack
- Concrete removal, best way?
- Cast to PVC
- Will this work for new P-trap for vanity?
- two sinks - one riser
- Adding a new 1/2 Bath, need help.
- Waste & overflow installation
- Removing Cast Iron Drain
- PEX in an exterior wall
- Sanitary Tee on its back...
- Kitchen Faucet Spit
- Sweating Cu Pipe and Kitchen Sink P-Trap Questions
- Sewer gas HELP!!
- 3" saddle tee abs
- broken manabloc valve
- Basement bathroom plumbing
- No water to faucets
- No water to one sink & dishwasher from hot water lines
- Rough piping a new upper bath
- Old copper pipe larger?
- Another double vanity sink drain question
- leaking Kohler K-15160 kitchen faucet
- Toilet instalation
- Mysterious Leak -- HELP!!!
- Delta Shower Faucet
- Freeze proof water spigot help
- Help with condensate pump outlet
- Vessel Drain
- Gluing ABS pipe
- Moen Single Handle Kitchen Faucet, #87500
- Hot water smell
- Basement sink won't drain
- Sink drain to main DWV connection
- Can I cut this pipe?
- Odd length freeze proof faucet
- Standard DWV stub out height for kitchen sink
- See anything wrong with this design
- Wilkins 600 pressure reducer: bleed up
- I think this is an S trap - kitchen sink from the 50's
- Sulfur smell in Shower Faucet ?
- Vent Stack in Bath Remodel
- toilet paper holder
- Toe Kick Heat
- Faucet Dripping - Next Step?
- Kitchen faucet bangs
- Adding new jet tub to 3 piece basement bathroom
- Shower head arm is straight, but leaks
- 1993 Kohler Wellworth, Why does the toilet back up?
- Adding a bathroom...need drain help...
- toilet upstream of lav - how to vent?
- Under Sink Help
- Replaced cartridge, shower still not working
- Correct Glue for PVC to solid HDPE
- tub p-trap vent more than 5'?
- toilet drain 3" or 4"?
- Drop in tub help needed
- dont need p-trap in vanity drain?
- whole house water filter cartridges - facts needed
- Reroute Vent Pipe
- Will This Improve My Water Pressure?
- How can I dissolve hardened caustic soda?
- Vent Pipe/Soil Stack Leak
- Tub faucet replacement help
- Can't beat Leaks at Couplings
- bad connection?
- whirlpool modification
- cast iron in basement floor
- basement toilet vent sizing - WI
- shower drain is only 1.5"
- Hey need a connection answer
- Which type of booster pump?
- Location for Adjustable shower bar.
- Spigot Leaks Inside House
- toilet sprayed water during sewer cleaning
- Does hand soap corrode?
- frozen vent pipe?
- Maax Maui tub
- Question about the slope of a 3" line...
- Shower fittings
- Dishwasher away from sink
- Trying to replace old sink
- PEX or Copper
- Kitchen Drain Size IPC in CT
- Looking for "thin" ADA bathroom sink
- Leaking Shower Drain
- for toilets and urinals in commercial bldgs
- newbie
- PVC Pipe Size for Shower Drain?
- 2" trap for tub/shower. Is it a good idea?
- Do I need water hammer arrestors?
- frozen water meter
- chile
- Tub fixture change Noobie here
- help with adding a 2nd zone in bsmt
- Tannis Problem
- strange leak
- Plumbing questions
- Solder Copper to Brass?
- Craigs List-Check this BOZO out.
- Gate Valve under Sink for Outside water
- Pipe-to-flex line valve question!
- Wiring Boiler Controls
- Water hammer after plumber came
- 3 handle valve to single handle valve question.
- Kohler bathtub diverter
- Anti-Siphon Frost Free Sillcock won't let pipe drain?
- Calcium in water lines
- diy grey water install
- Vent termination: above roof -vs- out the wall
- faucet replacement
- 1 1/2 copper drain issues
- Brass Cleanout Plug in ABS Cleanout Tee?
- silcock leaking
- Watts Floodsafe? Not Very! part1
- Vanity on exterior wall plumbing question
- Water pressure regulator
- Replace short run of cast iron.
- sand point low flow/surging
- Modifying existing pipe
- toilet flange
- 3/4" IPS to Copper? Urinal Question
- Washers on toilet flange
- Kitchen Sinks...
- Hot water heater & die-electric union
- Thought I had it licked . . .
- Should buy a house with ipex kitec
- Bath sink faucet with 1.5" base - old sink
- Basement bathroom
- Price Pfister single handle sink faucet no hot water
- My empty Crock problem
- Constant Kitchen Sink Repairs
- Help with Pedicure Spa chairs plumbing
- Adding two lavatories to existing vent
- basement rough in question
- Hot Water Issues
- Flood pump with built-in water sensor
- bad smell from gas appliances
- Shower drain removal
- Reducing from 2" to 1-1/4 inch. Where to get the fittings?
- Desperate need of help!
- New const. plastic line question
- please help with leak
- Flush mount sinks
- Stuck tub trap
- toilet spacing
- My plumbing books are in the hands of SBTX
- big loss of pressure
- S-Trap Workaround
- After cartridge replacement, water won't shut off
- Sewage Pump Issue
- New Tile - Tub Spout Won't Thread On
- Hooking RO filter inline
- DWV help please
- New splice fitting
- Street Flange Question
- Thermal Expansion Bypass
- PRV and Expansion Tank
- solid waste removal
- Replacing bathroom faucet help
- Connection Help
- Help with drain for steam generator and other fixtures
- Soldering, Unjoining, and Resoldering Copper???
- How can a Tile Tub be Site Built?
- flux in shower head
- Water Meter Inlet Valve
- Looking for Grohe 19 294 in chrome 000 finish
- New tile floor - toilet flange too high?
- Water hammer arrestors and code
- Ever see a lead toilet connection like this before?
- Adding a sink in the garage.
- Granite Composite Sink
- Venting a utility sink with an AAV
- Odor in Water after Plumber...
- Hot water pressure!
- Sloping new drain line
- DWV fittings - where what
- Stacking Laundry - Plumbing/Venting Question
- Dishwasher wye
- No water from faucet!
- Pop-Up faucet leaking at the control not drain
- Grohe volume control... plastic linkage tube
- Connecting pvc/fha Drain to Old Cast Stub
- Basement plumbing vent and drain question.
- Zurn Auqasense?
- water meter question?
- Broken water radiator pipe fixed, but produces no heat!
- Capping a galvanized pipe
- GPM at the kitchen sink
- Copper 1/2 inch Tee in
- Noise from Hot Water?
- 4" Rubber Boots to Connect Cast Iron to PVC
- Water pipe repair.
- 4" Cast Iron Pipe: Unplug Sections
- 1/2" supply and GPM questions
- DWV Question
- Lower water preasure from hand held
- Sump Pump Thumping Noise/Vibration (video)
- Now it Leaks, Now it Doesn't... HELP!
- Repair kohler sink faucet
- Venting a wall mount toilet
- DWV for new bathroom questions
- Double vanity, one gassy sink
- Noisey Pipes and rattling?...
- Faucet Installation
- Indirect Water Heater Not Calling for Heat
- Oddball Sink
- City water master cutoff!
- Plumbing facts of life
- Leaky Tub Faucet
- City turned water off, now it's back on it smells!
- 4" to 3" Question
- Woodford Valve Seat Question
- bending pex around corner in 2x4 wall
- copper line corrosion
- Question on Zurn PEX
- washing machine lines
- Need Advice on Faucets
- Cast Iron Pipe Corrosion - This is Bad...
- What does the PVC fitting look like that connects to bathroom laves
- Tub wall support
- Leaks in lead joints
- is there a limit to reheating copper?
- fittings
- Have I correctly laid out bathroom venting?
- Washing Machine DWV Question
- Do I glue the yellow dwv test cap?
- Covering pex stubouts
- Garburator trouble
- Adding fitting to existing drain
- Sewage pump could cause big mess
- Brass to PVC adapter?
- Need advice on Thermostatic shower controls
- return duct
- vertical drains
- Kitchen Sink Rough in
- Horizonal Wet Vent??
- A question: Can you
- Bent Shower Valve
- Backwater Valve
- Slab floor drain leak
- Black (gray) hot water from tub only
- Sleeving of damaged cast iron pipe in slab
- Low Flow Rain Showerheads
- cold water stinks
- sewage ejector pump failing ??
