View Full Version : Plumbing Forum discussions
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Plumbing,what kind of pipe to use
  2. roof vent termination location
  3. access panel - is it required by code?
  4. wanting to do install work
  5. Water softer installation. Where?
  6. ?Antiscald valve?
  7. Slow Drip From Kitchen Faucet
  8. Drain pipe addition
  9. Kitchen Sink Leakage from dishwasher drain outlet
  10. dishwasher air vent leaks water
  11. My water heater sings to me but it brings no joy.
  12. Can PVC be glued to ABS?
  13. Under ground water main
  14. How to attach 3" waste pipe to existing 4" flange?
  15. Recirculator works to prevent frozen pipes
  16. pin hole leak at refrigerator pipe
  17. 2"main stack vent, big enough??
  18. Hot Water Supply Sizing
  19. Water Heater Replacement
  20. Instant hot water heaters
  21. Help! MANY plumbing problems
  22. How to fix bad solder joints?
  23. Water hammer arrestors
  24. removing chrome drain pipes
  25. Squirrels Eating Lead Vent Stack Covers -II
  26. Brand new water heater pilot goes out often
  27. Trying to match an old American Standard lav faucet.
  28. Move Toilet Flange
  29. Leaking Brass Union
  30. Novice Question: When to use check valve
  31. Help! FrostFree/Freezeless Wall Faucet
  32. How far can a main vent pipe run horizontally
  33. Water Supply Sizing
  34. presure
  35. New sink is leaking
  36. Leaking Garbage Disposer
  37. How Do I Run PEX Through Corner Studs?
  38. Toilet + sink plumbing plan: please review -- trying to decide between two plans
  39. the best fix
  40. install garbage disposal in double sink
  41. Plumber Damages Home during repair
  42. Loud humming noise in pipes
  43. Radiator plumbing question.
  44. Venting Requirements - Basement Laundry tub pump
  45. Trap primer questions
  46. Legit or not?
  47. Wye on it's back?
  48. New Install Dishwasher won't drain
  49. Opinions on American Standard
  50. Types of sewer pipe
  51. discovered 2 holes in the 3" copper vent
  52. Need help with shower leak
  53. How do I shop for water softner?
  54. Sewer Line Replacement
  55. Dielectric union V. Dielectric nipple
  56. salt in water due to softner
  57. Adding Propane Line
  58. Should I install a whole house filter before water softner?
  59. sewer/kitchen sink
  60. code question
  61. Can I use this...
  62. water hammer questions
  63. Please Help! Ground water leaking into heating ducts
  64. drain trouble
  65. copper pipe question
  66. Teflon tape deposits
  67. Sewer/main line is plugged
  68. air in the hot water lines??
  69. garbage disposal causing minor backup in double sink
  70. Flow rate? Flow thru? Water softner restrictions.
  71. Stuffed Drain
  72. Proposed layout questions
  73. Water line valve problem....
  74. Cutting cast...
  75. Help - What Is This? Does it do the same thing as an expansion tank?
  76. Help-Smelly Dishes
  77. Sewer Gas Odor Outside My House
  78. Washing Machine Problems - I feel dumb
  79. A tragic flaw?
  80. Apparently Motor Vehicle Dept. wasnt hiring...
  81. any one know wher to get this PVC fitting? And can I use it like this?
  82. Strange Drain Problem
  83. Roots in Sewer lines-pl. help
  84. Vent Rerouting
  85. Cleanout fitting
  86. Seek Help with Estimate/Budget for Plumbing Rough-in and Finish Costs
  87. Replacing a pressure tank
  88. connect cpvc to metal shut off valve
  89. justforcopper..
  90. Draining hot water heater???
  91. Water coming out of shower drain.
  92. leaking lav drain
  93. Sewage Pipe
  94. presure valve
  95. Rules on using 90 deg. el in dwv
  96. Adding a Y to existing underground sewer main
  97. pex and polybutlyene
  98. How to seal an overflow hole in a sink drain?
  99. Stub outs
  100. Increase Sidespray pressure
  101. Water softener drain question
  102. Guesstimates for new water line from meter to house
  103. A Few Questions for the Pros
  104. corner sink unit
  105. Any shot at passing inspection?
  106. looking for sink ...
  107. water heater
  108. Humming Noise
  109. Leaking in-line shut off valve
  110. Is stack legal?
  111. Natural Gas Grill Connection
  112. Multiple Water Heaters Anyone??
  113. A question of fittings...
  114. Any qiuck fix for copper leak?
  115. Mansfield anti siphon hose bib; 500 series
  116. Dissimilar Metals: Galvanized OK w/ direct Cast Iron Connection?
  117. Parts available for Duraflow frost free...
  118. Is copper more quiet than pvc?
  119. Mansfield anti-syphon outdoor faucet
  120. Push 'n Go Fittings?
  121. Basic Kitchen re-attach
  122. Anti-siphon faucet
  123. Low water pressure after installing filter/softener
  124. Galvanized pipe removal
  125. Capping a buried gas stub
  126. Closet Flange
  127. Sewer Vent Location
  128. Polybutylene to copper
  129. How durable are flexible supply lines?
  130. New Basement Rough-in
  131. PVC Pipe broken in wall at "T" connector
  132. Reliance Water Heaters
  133. New Water Heater, low pressure
  134. reading my polybutylene pipe date
  135. No Water --Mansfield Frost-Proof sill cock
  136. Am I ready for glue?
  137. Hot Water becomes warm ocassionally
  138. Tub On a Slab Installation
  139. Inspectors, What was your last encounter like?
  140. Pressure Relief Valve
  141. Removing saddle valve
  142. Removing lead and oakum
  143. T & P valve and water heater noise
  144. how are we gonna do w/out our waterheater?
  145. Outdoor Faucet
  146. How can I measure my water pressure at the toilet?
  147. Tankless Booster for Tank? - Help
  148. Outdoor Faucet problem
  149. perferable method to vent shower
  150. turned around hot&cold
  151. kitchen sink base size
  152. Am I asking for trouble with this fix?
  153. Leaking Toilet
  154. lead water service line replacement
  155. Some gizmos are right as rain for saving water
  156. Drain not aligned with drain line
  157. Refrigerator water filters
  158. Americast Kitchen sink leakage
  159. Plumber can't be located
  160. How do I plumb a primitive gravity-flow water system?
  161. Kitchen Sink Trap Placement
  162. Ultraflo replacement parts
  163. 1/2" water service / Multihead shower
  164. Motivation
  165. Opinion on repairing my sink link:
  166. New toilet install..
  167. 'S' trap replacement
  168. tankless heater for very small house
  169. PVC Pipe Leak
  170. Knee deep and over my head – breaking up floor for bathroom
  171. Problem with new water heater
  172. Air Admittance Valve
  173. Woodford 17 Anti-Siphon Hose Bibb
  174. Galvanized supply pipe removal
  175. Preference for solder and flux?
  176. Challenge routing kitchen sink vent around window
  177. Mystified in Chicago (Pipe Noise)
  178. Onyx on onyx
  179. Help with new sink install
  180. 3 way valve?
  181. No Water...Help
  182. Rather Simple Vanity Drain Question
  183. Kohler Memoirs quality problems
  184. Leak under foundation..
  185. New slab construction
  186. Need some help with a leak
  187. Merlin 1 on demand reverse osmosis
  188. Gas water heater prices
  189. Water Won't stay hot-tankless oil burner
  190. Water has egg smell
  191. wierd hot water situation
  192. Pan for steam radiator?
  193. Small nick in hot water pipe
  194. Stainless Steel Hot Water Heater
  195. Replace T&P Valve on Water Heater?
  196. iron pipe plugs
  197. 2nd Floor plumbing plan
  198. do enzyme treatments work?
  199. flux and solder
  200. How many pumps does my system need?
  201. Water Pressure
  202. Crimper
  203. PEX Inside 3/4 Type M Copper
  204. Do I have a Leak?
  205. 'Ungluing' pvc dwv pipe?
  206. Washing machine hoses
  207. leak at trip lever gasket when showering
  208. Trapped air from hot water heater
  209. Replacing pipes
  210. loss of pressure and pump runs continuously
  211. 1/2" copper supply feeding house
  212. replacing 4" cast iron vent tube?
  213. I need a LARGE easy-out
  214. Water softener problem/question
  215. Single lever washing machine shutoff
  216. "S" trap to drain pipe fitment question
  217. single vs dual aquastat - water heater
  218. Beacon Mixer Valve-Where to buy?
  219. basement floor drains
  220. basement floor tiles...asbestos?
  221. Water Softeners-Potassium or Sodium Exchange Resin?
  222. Tankless water heater problems
  223. No water From Hot Taps
  224. Water Softener problem
  225. P Trap question
  226. New Sink: 1-1/2" to 1-1/4" Trap to Tailpiece
  227. No pressure, but a lot of stress!
  228. What's the best Direct Vent Natural Gas water heater
  229. Sediment in hot water pipes?
  230. water dripping from ceiling
  231. broken woodford valve stem
  232. hot water pipe rattle
  233. Adding bathroom
  234. Upward drain
  235. Another Washing machine hose question
  236. Adding Bathroom to detached garage
  237. Hints for removing brass hose bib?
  238. faucet pipe too short
  239. Moving washing machine...
  240. Sweating Copper
  241. Isolators
  242. cleaning the inside of a hot water tank
  243. Water valves
  244. Cutting PVC pipe - need to get it straight
  245. Vent Stack Question
  246. Cleanout Valve
  247. Removing Stem Extension
  248. Oil hot water heater vs electric
  249. Massachusetts plumbing questions
  250. Venting Question
