- close venting????
- banded coupling from 1-1/4 copper
- solder joint failure?
- RO leak ..
- Thanksgiving, is your toilet ready?
- gas pipe question
- nuisance or danger - banging pipes
- Newbie Question: which kind of connection would you recommend
- Need Advice in Replacing a Sewage Ejector Pump
- Question on Replacing Faucets
- Please review my basement plan
- help with screwup
- Moving Radiant Heat Pipes
- water heater - rumbles loudly
- leak testing copper piping project
- Faucet Aerator purchase
- delta 600 series shower/tub valve
- Drain lever broke
- How to replace a copper fitting close to another fitting
- Drainage pipe routes
- American slowly embraces the bidet
- Cooked my heat traps and dip tube ?
- 2nd floor bathroom rough in question
- Leak in copper Line
- Water Heater.. BEFORE and AFTER
- 2" drain for bath lavs
- g.e. power vent water tank fault codes
- bottle trap
- Roto Rooter Strikes Again
- Plumbing drainage question
- Draining system to eliminate water hammer.
- island vent
- #Water in roof vent
- boiler pilot light
- basement bathroom
- Connect a new line to a water softener
- REplacing a "S" Trap
- Water heater woes.
- T&P Valve Leak
- EverPure Water Filtration
- Kohler kitchen faucet - slips off at low flow rates
- Water Heater inlet leaking
- Not good... not good.
- What Manufacturer has the Best Sump Pump
- Central Vac Plumbing
- Using a 3"san. Tee
- washer plus floor drain on second floor
- Fernco couplings on pressure pipe
- Sillcock Types, Conventional vs. Quarter Turn
- Flexi tube--does it need sediment trap?
- cleaning products and septics
- Main Drain Pipe Question
- High Water Pressure
- solenoid breaker trip
- Gas Water Heater: What is proper flame?
- Best way to remove lead cap in cast iron main trap
- Main Sewer line replacement
- Tee PVC into Cast Iron Drain
- Help with Moen Monticello single handled
- disposal install
- Ipc 2003 handbook - bath group/wet vent
- Float Switches for a sanitary sump
- Slow drains and burping toilets
- In-line screen filters
- How to clamp/fasten gas pipe to wall
- how to loosen putty between nylon bushing & brass pip?
- how to connect cast iron to pvc in a vertical run
- Time to replace galvanized where meeting copper?
- Can feces get into tank?
- Exploding Dishwasher
- Main Drain Caps - Brass vs Lead
- Water usage 100,000 gallons per month?!
- Plumber qualifications
- Gas step down
- Warm seats in winter ads
- Which Zoeller Sump Pump?
- Pex tubing water amount??
- Water Softener Drain
- Hot water backflow
- Low water pressure
- Sewer smell in yard
- Bad smell from toilet area
- Challenge the expert
- Building a hair salon
- 1.5" Extruded Insulation
- Bradley Residential Kitchen Faucet
- Shower drain
- full port valves.
- Customer Caught in Time Warp?
- Toilet waste line
- connecting drain to lead pipe
- Help I can't find the brand on my faucet
- Help me identify odd PVC coupling.
- Low pressure in faucet, not spray
- connecting pvc into stack cleanout, possible??
- Brine tank full of water
- Connect second floor shower drain into first floor kitchen drain
- Difficult faucet requirement
- Raising or re-routing pipes in basement ceiling
- Vent Stack Support
- Water Softener Brine Tank Overflowing
- Toilet Drain Line Slopes the Wrong Way
- sink drain: use 'pipe thread compound' on abs pipe?
- Insinkerator Disposal without Dishwasher Installation Problem
- Kohler shower valve leaking
- Kitec tools / Help!
- Drain problem - all connectors and no pipe!
- Frost burst hose bib internally I think?
- Moen cartridge install
- Expansion tank needed on water heater?
- PEX and heat tape
- Delta / Peerless Customer Service
- Something Always Leaks
- Heavy pvc vs packaged stuff
- Inspectors suck !!
- 45's to raise p-trap arm?
- Water Heater Hookup
- PRV's
- Moving basement toilet drain
- Tub drain
- Hot/cold mixing tee
- Pressure Pump for rainwater/toilet system...
- Help with sink strainer sizing
- Bathtub not Centered
- Water Softener recharge--Water Heater Pressure Relief???
- Kitchen Sink basket/strainer/drain sizing question - 3 1/2"??
- CSST is BANNED!!
- In-WALL air return?
- shower and Lav back to back
- toilet/shower vent help
- Trenchless Sewer Repair, Good or Bad?
- Faulty Water Softener.
- 1/4 turn supply stops--question
- what type of pipe do i have
- How do I change out a sewage elbow? (Pictures provided)
- Connecting Old Gal Nipple to PVC
- cleaning plumbers putty fingerprints of Stainless sink?
- Oil Hot Water Heater Shuts off every two days! Help!
- Identify tub faucet valve
- Lukewarm water in all sinks and showers
- rough drain set up for kitchen sink.....look ok?
- SLow Faucet
- very hot water as soon as taps turned on
- Hot Water Coming from Cold Water Supply
- plumbing
- 1.25" Main Vs 1" Line
- Backup Sump Pump Question
- Water does not completely divert from spigot to shower head.
- vent size - i know you all love these
- Resin Tanks
- Check this Venting...
- Question on crimping tools
- Using instant cement to join pvc and plastic pipe?
- Dresser coupling on hot water heater
- Instant hot water
- Kitchen Sink Tap not working
- villeta vs. reliant 3
- Water Leak and Meter Issue
- Thermosiphon
- Quick Pressure Drop
- Water Pressure
- water pipes in an unheated garage
- plumers cost to replace hosebib
- white stuff in my faucets
- PRV installation questions
- leak in hot water tank after power outage
- T&P drain
- thermostat problem
- AAV/Studor noise
- whistling sound in kitchen faucet
- bathroom remodel plumbing
- Time to remove hoses from hosebibs
- Sloan Valve and Kohler Branham
- water heater pilot light problems
- Water heater reset?
- Basement Shower Wet Vent?
- Moisture coming up through tile grout.
- Mansfield Sillcocks
- Black Specks - AGAIN
- Traps
- Brass air fittings
- Sewer line break in rubble-filled crawl space
- water heater "heat loops"
- Thermostats
- about radiator heat
- How to choose a pressure regulator?
- Lay off
- washer machine hookup
- Closet flange in new construction
- black nylon braided flex connectors on the water heater
- HELP needed quick
- Hot Water Heater noises
- Water softener making clicking sound.
- Main Water line not working
- DWV Question
- questions about fittings for sink drain connection
- Air getting into house hot water loop
- How to attach 3/4" shut off valve to cast iron
- soldering copper pipe
- Neeed: Licensed Hydronic Installer
- How to thaw frozen pipes
- Vanity Top Size/Sanding Question
- Toxic Drinking Water
- Please HELP! Toilet does not fit!
- How much does a wax ring compress?
- Location of hot & cold water pipes
- steam radiator bugging out!!
- Cold weather plumbing....longest thread ever
- Fernco bushing usage.....
- Pressure testing DWV
- Inspection find of the week
- Another pro photo
- Brad White water heater
- Septic maintenance
- White milky water
- What kind of leak, or is this a frozen pipe?
- Water Pipes in Attic
- Hot Water Heater Life Span
- New shower valves and existing lines
- New water lines to a shower..Codes?
- First post - photos of basement DWV project
- Frozen Pipe??? but wall is insulated...
- ? about caulking toilet bowls
- Plumbing Code Queston and Boilers
- Drain pipe stuck in wall...
- 66" / 158,000 gal. / min. Broken Water Main
- P trap height too low?
- Plumber needed to repair small leak
- Unclip handle hose for moen single?
- How deep are gas lines buried?
- Quality of decorative supply lines and drain/overflow for clawfoot tubs?
- What kind of connector do I need for this setup?
- portable dishwasher splashing problem
- pipe repair
- Backup in upstairs bathroom
- Water
- Crossed Hot & Cold Water Lines
- toilet tank condesation
- Water going on and off inside the walls
- Antique Tub refinish
- Water Heater Cold Water Inlet "Overflow"
- Cleanout required?
- Intermittent Hot Water
- Advice for disposal install..
- Pipe stub for hand held shower
- Licensed Plumber Needed: Spring Lake, NC Area
- Need help with filter to fitting leak please.
- Help/Advice on "whining" PF/2 Energizer toilet
- Washer/Laundry Tub Not Draining
- Tee on a 45?
