View Full Version : Plumbing Forum discussions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Can I install toilet vent in vertical section of pipe below toilet?
  2. New baseboard covers won't fit
  3. Urinal nightmare
  4. Extension Pipe Connection
  5. iron filter drain
  6. Testing Copper Supply Lines before hooking up
  7. 14+" rough -- only 41" to wall -- short toilets?
  8. what's up with potassium chloride??
  9. New Tub Drain is Slooooww ?!
  10. How to connect j leg to copper pipe
  11. Toilet Flange bolts keep spinning...
  12. Smell in master Bath/Bedroom
  13. ftg fittings
  14. Severe Water Hammer from long downhill run.
  15. Sudden Reversal of Hot and Cold Water
  16. cartridge for Delta R10000-UNWS valve
  17. Got the blobs, need help
  18. drain/venting question
  19. Vibrations in plumbing lines
  20. Outside vent/cleanout, Distance from house
  21. Add on draft inducer
  22. Sewerage/sulphur smell in house?
  23. Bathtub Drain - How Many Elbows
  24. Connecting to City Sewer Main
  25. Hot water problem only in on room
  26. Need Help with installing hardibacker
  27. Automatic Vents in MA
  28. Water Heater No pressure
  29. How to stop PVC thread joints from leaking?
  30. Baseboard
  31. laundry valve and wall box
  32. Well water questions?
  33. Failing leach field
  34. Codes minimum size and opinion
  35. Slight leak under kitchen cabinets and dishwasher
  36. Sewage ejector pump check valve
  37. Do thermostatic valves supply higher GPM than balanced pressure units?
  38. Main Valve Leaking
  39. plumbers putty
  40. Favorite House Water Purification System?
  41. blanco kitchen faucet
  42. Replacing floor drain bowl in basement
  43. Lav trap on larger trap arm: actual problem?
  44. Looking for hot water heater suggestions
  45. Loose fitting tail piece into extension pipe
  46. frost proof faucet leak
  47. Minimum wall requirements
  48. back to back toilets
  49. Sewer line slope
  50. Handwriting on wall
  51. ODD Sewage Odor--Need help to detect source
  52. Singing pipes
  53. Water hammer: Can it damage stuff?
  54. Leaking sill cock
  55. How to remove steel nipple from brass tee?
  56. Advice. Toto Soiree or Axor Steel???????
  57. Toilet Noise after Flush/Sudden Pipe Break
  58. Best Electric Water Heater???
  59. Which PEX sizes according to ...
  60. Dirty Hot Water - grease like substance
  61. Hose Bib Brand Recommendations?
  62. compression fitting dilemma
  63. I am looking for a straight line valve
  64. What size and type of pipe
  65. Slip joint connections
  66. Drainage systems
  67. plumbing plans comments
  68. T&P Valve
  69. no pressure shower/tub
  70. Foundation excavation or sump pump?
  71. What does a thermostatic valve do while "waiting" for hot water?
  72. Intermatic WH Timer Problem
  73. Kinetico K60 resin replacement recommendations
  74. Code for Steam Shower Line/Drain
  75. Tools you wish you had...
  76. Volute Design
  77. Please comment on this setup
  78. Hole in steel pipe under tub
  79. Access hole?
  80. Vanity pop-up drain seal leak
  81. Vent Stack vs. Stack Vent
  82. Cost to replace lead pipes to copper
  83. Advice: Winterizing frost-free faucets
  84. Home made P-Trap
  85. difference between 2400e and 2400es?
  86. Foul Smell in 7 year old laundry room
  87. using an overflow drain with a non-overflow sink?
  88. Soldering copper to shower fixture
  89. Worried about overheated joints
  90. Washing Machine Valve
  91. Washing machine discharge
  92. Expansion Tank
  93. Sched 40 or 30?
  94. Need Advice: Slow draining sink with no vent.
  95. New Water Heater Technology
  96. Water hammering, no, jack hammering
  97. Electric Hot water Heater Forced hot water
  98. Think I screwed up
  99. Tub drain and stack side by side... how to connect
  100. Downpipe mod. into rainwater tank
  101. Will this fitting leak?
  102. Silicone caulk vs. latex caulk
  103. best advice for new plumber?
  104. Oh No--please tell me I don't have to redo existing waste line.
  105. Neighbor turning on her outside faucet causes noise in my water pipes
  106. recognize?
  107. Air vents (AAV) or overkill?
  108. shower p trap 101 needed
  109. location of drain line for water softener
  110. Upside down tee a water flow concern?
  111. Is there a good swimming pool forum somewhere?
  112. Drain Line for septic - DIY?
  113. Water Softener Mineral Buildup- PITA
  114. Washing Machine 1 1/2" drain stack?
  115. Tub Delta faucet leak - How to fill space at wall?
  116. Installing 5 frost free stand pipes
  117. Sloan parts needed
  118. Protecting cabinets from leaking valves
  119. It's just not Copper
  120. Can I cap a pipe better...
  121. Sulfer Smell
  122. Sharkbite to water heater
  123. No hot on Pegasus shower valve
  124. Gas Line Filter?
  125. Gauge placement
  126. Copper supply lines contaminated with PVC cement chemicals
  127. Loud clunking when pump turns on
  128. Pex in a bad neighborhood.
  129. California Roof Drain Codes
  130. Roof drains, do they have to have a cleanout?
  131. Help with Whirlpool Water Heater
  132. Disposer flange and sink basket in cast iron sink
  133. Gas Range problem
  134. Passport tub does not turn on
  135. dishwasher repair
  136. Pit in basement.. what's it for??
  137. Mapp gas question
  138. Van shelving & divider screen
  139. Back to Back 45 Degree Offset in Drain Line
  140. Valley faucet handles?
  141. hand shower causes knocking/vibration in pipes
  142. shower drain & p trap code question
  143. 1/2" meter for 3/4" water line
  144. main water line mystery
  145. bathtub faucet leak
  146. Kohler 3402-PB Rialto OLD Flush Valve
  147. What is Recommended Water Pressure??
  148. Temperature Pressure Relief Valve
  149. Convert Floor drain to sink?
  150. Kitchen faucet has less and less pressure -- now barely works
  151. Water heater question
  152. Kitchen sink indirect waste into floor drain?
  153. Mansfield Outdoor Faucet Problem
  154. Water Hammering
  155. water heater distance from wall ?
  156. Flat rates
  157. green flakes in water--from copper pipes?
  158. Cleanout needs to be modified
  159. Galvanized pipe broke off
  160. Bottle Water Cooler piping question
  161. Most trouble free fixtures?
  162. Advice on replacing clay waste line
  163. Vacuum breaker question
  164. toilet supply line make-over
  165. Water Lines and VApour Barrier
  166. Sudden Drastic Water Pressure Increase?
  167. Closet flange issues...
  168. Looking for Delta Brizzo faucet handles
  169. Vent
  170. water softener
  171. need help with ferroli gas boiler question
  172. Water arrestor
  173. Possible leak under the slab
  174. Broadway Aerator
  175. What does this sound like?
  176. Temporarily capping Polybutylene ?
  177. Simmons Valve
  178. critique my dwv model
  179. 3" 90 street bend with long end?
  180. water pipe dimensions?
  181. add laundry sink to washer drain?
  182. Sewage ejector pump
  183. upgrading water service
  184. Electric Water Heater 30 or 40
  185. Is this a disposal inlet knockout?
  186. Stuck galvanized steel elbow
  187. MIP thread for tub not tapered?
  188. trouble removing old faucet - no room for basin wrench
  189. Wirsbo / Uponor Installation Question
  190. DWV Layout
  191. Pulling a gas line complicated????
  192. Plumber's Putty swells out
  193. Rattling noise behind refrigerator,.......water line.
  194. Kitchen faucet - left to right reversal of spray
  195. Toilet fills by itself?!?
  196. Where to get water heater anodes?
  197. Basement Rough-In Moving
  198. Expansion tank pressure question!
  199. Add flange extender or replace the whole thing?
  200. Rotate toilet flange?
  201. delta r10000 connections to pvc
  202. water pressure
  203. Moen single handle kitchen faucet
  204. Two inch bathtub drain source?
  205. Help with Washer Plumbing
  206. Newb question...washer outlet box drains
  207. How to remove bathroom sink drain collar?
  208. Good plumber in Blaine WA for main line cleaning?
  209. Over the counter sink installation
  210. Kitchen faucet - bending copper supply tubes
  211. PEX-PIPE For pipe replacement in condo building?
  212. Plz Help In Identifiying This Pipe!
  213. Swing Check vs. dual check vs. double check valve
  214. Heat loss with plastic pipe?
  215. Double vanity from single
  216. low pressure/no water
  217. water heater prices
  218. Need advice on boosting water pressure
  219. R-Value needed
  220. Bathroom sink drain issue
  221. Dishwasher connection hose
  222. faucet connector pipe leaking
  223. Dishwasher leak
  224. Codes for PEX
  225. Private Label Toilets
  226. Gray colored Plumbing in Mobile Homes? Is it PEX, Qest, Polybutylene? What fittings?
  227. T&P line height ?
  228. Why does my Moen Kitchen faucet have rust under it ?
  229. Sudden Intermitant Sewer Smells
  230. Water heater questions; 1 OR 2???
  231. Piping
  232. Basement Drain Problem
  233. water pressure volume vs pipe size
  234. To manifold or not to manifold?
  235. What kind of PVC fitting is this?
  236. Shark Bite Valve ??
  237. Help with old bathroom
  238. risers from water line -- is 90 degrees OK?
  239. other internet sites
  240. Woodford Model 17 vale stem leak
  241. basement bathroom and venting with ejector pump?
  242. Bathtub Faucet Valve Stem
  243. Calculate PSI based on GPM?
  244. Basement cleanout/drain pipe cover
  245. Main Drain Semi Clog?
  246. PVC pipe in concrete
  247. Crawlspace mold—drain problem?? (HELP!)
  248. moen 3 function transfer valve
  249. Water leaks in wall
  250. Leak from Hole right behind Handle of Frost Free Hose Bib
