- Dumb problem - would like to avoid opening ceiling
- Thermo Shower valve temp adjustment
- !Stupid! pipe fitting question
- Thermal Expansion Tank Location
- Advice for moving sanitary tee up
- No septic repair area
- Neutralizer questions
- Raising floor to avoid slab disturbance
- Basement Drain Line Replacement
- Seeking help to reduce noise from shower drain
- Oop's I hit a pipe with an auger bit!
- Basement Floor Plumbing Identification?
- Mansfield Sillcock
- Stop Valve Compression "confusion"
- Leak somewhere between kitchen and bath..help!
- Need advice on a tool
- Proper sealant for popup? (faux marble)
- Cast Iron Sink Excess Enamel
- Roots in Sump Pump Crock?
- Basment waste pump out question
- New Bath/Shower Valve Problem
- Tool for scratchless install?
- question about attic supply line
- pex and sharkbites
- Low Pressure in Kitchen
- Can I replace my shower faucet with this?
- Mop Basin
- Chrome Pipe Cover/Sleeve
- best pipe for gas
- Copper "L" vs. "M"
- Hot water pressure issues throughout house
- Garden Hose....diameter vs. outlet feed
- converting single bathroom sink to double.
- Copper pipe to steel pressure tank
- Dual shower head
- Sink Tailpipe Issues
- How to add a fitting in underground line
- Fridge Ice Maker Water Line Burst - HELP!
- hot water tank
- Replaced PRV, now have too low of pressure
- "Professional Grade" Price Pfister
- help! sizing issues
- Bad diverter in a discontinued faucet
- Just want a nice hot bath
- New Construction Advice
- Outside Spigot Repair
- Measuring solder
- Galvanized pipe to water main?
- rough in help. pics included
- hole behind 3 overflow holes?
- Water Softener Regulations in Las Vegas
- Gas HW Heater Code Advice
- Air hose reel used as garden hose reel???
- Dishwasher drain problem
- Need advice: Would soldering stop this leak?
- Replacing water heater anode rods?
- Water Filters
- new ball valve leaks at stem
- newbie with basic plumbing questions
- Woodford tube removal????
- my toe kick heater won't get hot? Help`
- is 36 lbs pf pressure enough?
- 6" Certainteed Pipe splitting
- PEX SSC clamps versus standard method
- Floor Access Panels
- Cast Iron Soil Pipe Questions
- Is a WH supposed to be raised off the floor?
- Looking for supply line connectors for my tub filler
- Bullnose supply tube to Price Pfister?
- Noisy Kohler Faucet
- plastic or metal WH catch pan?
- drain attachment question - newbie
- Wedi
- Ejector Pit Venting
- Adding a laundry room, how to vent?
- My Pex install
- Removal of backflow preventer flapper
- Rust particles coming out.
- New garage plumbing question...
- Is there a 3/8 compression to 3/8 Compression water shut off valve?
- Rattling Water Heater
- PEX-conventional or mainfold
- Replace dinosaur electric with electric, power or direct vent?
- Support straps on Vents and Drains
- Venting through metal roof
- Help with rough plumbing...
- Insulating PEX hot water lines
- Why a tub spout in a dedicated shower?
- replace plastic drain valve on Rheem WH?
- Basement floor raised????
- Help - Mounting a hose bib on outside - no solder....
- cracked galvanized pipe
- Best Plumbers putty
- Sawzaw safety
- Issue w/ water pressure on newly installed island
- Basement plumbing, layout & third floor waste stack HELP
- Basement floor drain and toilet issues - need help pls!
- Install drain basket in new acrylic tub
- Wet Rooms
- Help! Multiple hot water problems.
- Help with garage plumbing
- pressure vacuum breaker at spikot..
- Basement plumbing layout
- Flue tape?
- Question How's this Filter setup
- Pool Wastewater/Backwash Connection
- Large vent pipe up through 2 x 4 top plate
- Replace vent pipe?
- Moen Outdoor hot/cold frost free silcock?
- Removing drum trap in lead drain
- Mansfield Flush Valve problem
- Question on Bathtub Valve Stem Leak
- 1st floor plumb layout
- Horrible venting problems SUGGESTIONS??
- single handle shower faucet repair
- Double Y coupling closed on top.
- I'm drenched
- waste line
- plenum rated pex tubing
- Pipe Dope, Plumbers Putty, or Teflon Tape?
- Hose Bib Leaking Inside
- Moen Kitchen Faucet problems/quality
- ABS pipe moves --- is this bad?
- Wall Mounted Faucets
- Mixet tub/shower valve questions...
- 3rd floor bathroom in 1924 house
- Short-lived hot water pressure on new WH install
- Clawfoot tub drain alignment
- DIY Cast Iron to PVC project
- Replacing Sewer Drain Cap in Basement Floor
- Gas Furnace Steam Radiators And Cast Iron Pipes
- Bad Jacuzzi tub
- Testing for gas leaks
- Using air to flush pipes
- DWV remodel for new bathrool
- Can anyone identify this hose faucet?
- trying to update
- Help with rough-in of Samuel Heath V427 shower thermo
- Main Water Supply Line
- accident. Need help
- Washing Machine Drain?
- kohler k-438-k versus k-300-k -- diverter?
- supply line sizing
- Advice - PEX Tubing
- Water heater copper pipe corrosion
- Slow draining washer drain
- rack in a fiberglass shower floor?
- Modifying Bath Plumbing
- Remodeling a bathroom that was poorly done; venting question
- dialectric union vs dialectric nipples
- Open 2"-3" ABS pipe in Basement - Dripping
- Vent question
- hard water vs soft water
- copper tubing questions
- Rough in/venting advice
- Ecoflow peat filter septic system
- low hot water pressure after installing new tank
- Buried fernco fitting
- Need plumber, West Bloomfield MI
- Avoiding a dry drain trap
- Summer Cottage Hot Water Heater Questions
- closet flange Issue
- Wondering if I made a mistake sweating copper
- Switching propane gas valve to nat gas water heater
- toilet installation
- Anyone know the model of this faucet?
- * Please Critque my Plumbing Design
- DIY macerator and lift station
- Woodford faucet problem/question
- seal chrome vanity pipes
- Stuck Valve-Yukky Water
- Plumbing archaeology question
- Shimming Toilet
- Failed Wilkins Model 600 Pressure Reducing Valve ???
- PVC drain into ABS waste stack
- New Kitchen Sink - Offset Drain
- gas pipe load calculations
- Great Site!
- Basement flooded
- Best toilet flange size
- Culligan Medallist Water Softener
- Faucet Drain-P-Trap alignment
- 80 year old septic question....I need your guys opinion!
- Outdoor Kitchen Sink
- saddle valve on black pipe
- Information on a reusable whole house water filter:
- Water pressure
- p trap height
- Kitchen drain backup with dishwasher
- Sewer/Sulfur Smell From Isolated Shower - City Water
- Compression Fittings Allowed Inside Wall?
- Dual Gas Hot Water Heater - Low Temp
- Chloramine disinfection
- Foul water in my basement...
- Steel to Clay Pipe connections....
- Vessil Sink Drain Alignment
- Need help with replacing my water heater
- Cold water feed makes a right racket
- What does this noise result from....
- What type of strapping can be used for plumbing?
- Totally stumped on high water bills!! Need advice!!
- Water main, irrigation, then whole house
- Jetted Tub Switch
- 1" down to 3/4" Pressure Reducer
- Offset Vent Stack
- chamfer tool, is it required?
- add shower DWV
- Flowguard gold vs regular CPVC
- Adding another sink to dual sink drain
- sump pump never runs
- Hot water flow stops abruptly
- Sump pump crock
- Where should the water hit the basin?
- P-Trap installation
- water softener/water filtration
- Shower Vent to Main Vent joint
- Dirt in bathtub trap - Push on or vacuum out?
- 1 1/2 inch drain sufficient for a shower?
- Bathroom plumbing project
- How much PEX vs. Copper?
- Cold usage pulls hot water lines?
- Thinking smart about plumbing design...
- Modifying Plumbing / Soldering / Leaks ?
- Vessel Sink Drain that prevents overflow
- Best Thread Technique / Pipe Dope
- Torch Questions Types / Lighters etc.
- W/H tank longevity and anode rod replacement?
- A/C overflow
- Natural Gas Questions
- New Problem Plugged Bath Faucet After Repair
- Electronic Switches on Sump Pumps
- Do these parts exist?
- Condensation buildup in Water heater exhaust
- Lav and Toilet DWV Advice
- Frost-Free Pipe busrt, installed wrong
- Water Heater Problem
- Tiny Insects from Drain
- Do you guys caulk lead vent pipes????
- bathroom supply leak
- Exterior Frost Free faucet leaks
- Well System needs a pressure tank!!!!!
- Water Heater Plumbing questions...
- Venting for 16' underslab drain
- Adding Laundry Room Drain to Kitchen Drain
- Vent solutions for LONG distance drains
- Floor Sinks and Hub Drains
- Cutting/Breaking up concrete basement floor
- dehumidifier tie in to basement dwv with primer valve
- Basement Rough In
- mapp gas
