View Full Version : Plumbing Forum discussions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Insulate drip sound in vent pipe?
  2. Standard Vent (line chimney) vs Direct Vent
  3. new svc line black PE
  4. Hit a phone line and need help.
  5. House water turned off for 3 hours, house plumbing out of whack - Air in system?
  6. Shower Problem
  7. Basement drains in a modular
  8. Electric water heater for barn
  9. Wax Ring
  10. Was wondering if you could help a newbie out-Question about Sink Repair Traps
  11. Faucet identification
  12. water pump for refrigerator ?
  13. "Nuts" to Trap Adapters
  14. Question about placement of water line
  15. Double Wye for Back to Back Tolets?
  16. Water Meter Couplings
  17. Sewer lift station--help with design and install.
  18. Solder particles in water?
  19. Connectent 2 inch PVC to copper for drain
  20. Sanitary Tee on Back in DWV
  21. How to move cold water supply 2 inches?
  22. Drain line carry
  23. toto vs. kohler toilets
  24. Plan for 2nd Floor DWV
  25. main water line break
  26. Briggs Toilet Flush Problems
  27. tail pipe kitchen sink
  28. shark bite
  29. how do I find the leak????
  30. polybutelyne to cpvc connection
  31. How should I lay this stack out?
  32. replace toilet flange on concrete floor
  33. laudry room drain issue... please advice
  34. Pipe for exterior gasline
  35. 3 easy questions!
  36. polybutelyne to pex
  37. Purging air from boiler
  38. Master Bath Remodel
  39. Kitchen Plumbing Rough-in
  40. Is this OK?
  41. Shower remodel question
  42. can I please get some shower faucet recomendations?
  43. How to install dishwasher drain to double sink?
  44. floor mount tub filler...
  45. 1910 Kitchen issues
  46. Multiple shutoffs under sink?
  47. Modified Washering machine drain...still overflows
  48. Confined Air Spaces
  49. New plumbing...replace meter?
  50. New Waterline Whoa's
  51. larger then 2" standpipe ?
  52. faucet base plate
  53. Installing a neoprene sleeve banded coupling - the easy way!
  54. Keep or replace old threaded supply piping?
  55. knocking pipes
  56. I should know the answer but dont
  57. Pipe freezers, are they worth getting?
  58. Push Button urnial
  59. CI Plumbing Stack to Sewer
  60. problem with abs fitting
  61. New PRV Causes Foghorn Noises Everywhere
  62. Help finding a Toto Aqua!
  63. Pop-up Assembly Does Not Fit
  64. Help needed with pedestal sink selection
  65. 2nd Floor Plumbing
  66. hot water pipe near elec.wire
  67. Help with bath spout
  68. water heater expanding tank
  69. Pipes & Meter freeze protection question
  70. Delta Valve, can I drill it?
  71. Tube support liner removal in Shark Bite?
  72. Copper to Brass with Teflon
  73. No pressure to upstairs bath
  74. Fire Pit on balcony (and gas line location)?
  75. Pittsburgh Pipe Wrenches Any Good?
  76. Boiler for Radiant Floor Heating - Need Advice
  77. Fixing Small Leak in Black Pipe Gas Union
  78. Moen faucet repair ??
  79. Self-Leveling cement
  80. Pex, Bathrub and Water Pressure
  81. lavatory faucet for tub filler???
  82. Gas Leak Detector
  83. Depth of pipe
  84. Basement Rough-In Advise
  85. external drain stoppers for sinks w/o overflows?
  86. shower drain noise
  87. yet another island sink vent question
  88. Buyer Beware-Kohler Fixtures
  89. looking for knowledge
  90. Bradford white question
  91. Great tool
  92. oil fired water heater
  93. Basement Bathroom from Scratch
  94. locating galvinized pipe in slab
  95. How To Plumb & Vent My 3-Piece Basement Rough
  96. 4:45 AM wake up call, The Walls are alive
  97. Can I do this?
  98. KWC faucet
  99. Kitchen Sink Rough-in height
  100. Sewage Smell When I run water in sinks?
  101. Water Hammer and Washing Machine
  102. Water heater platform
  103. expansion or pressure tank
  104. Which Pex Fittings?
  105. flexible cpvc pipe ok to snake in walls?
  106. dishwasher w/o vacuum breaker
  107. Delta Fluidics H2OKinetics Showerhead
  108. H2ow To Product Info
  109. Manibloc Vanguard in crawl space??
  110. Mixing copper types
  111. 2" or 1.5" under sink?
  112. Toilet, tub, and sink draining very slowly. Need help!
  113. Need help/advice regarding oily substance on surface of hot water in basin
  114. Has anyone seen a drain configuration like this ?
  115. Plumbers Putty Function under Faucet
  116. PEX with Baseboard Heat????
  117. Remember when "chrome" was metal?
  118. pipe thread ?
  119. Big Problem
  120. Kitchen faucet problem
  121. Plumbers rule, pass the Advil
  122. Cleanouts Questions
  123. Home owners changing there mind.
  124. Black sludge in toilet tank - NOT slimy
  125. water tanks?
  126. water pipes outer wall
  127. Can anyone tell me what the Heck this thing is?
  128. Is it necessary to add cleanouts? Also whether to tie in A/C condenser?
  129. My first Tankless install.....
  130. leaking shower arm...
  131. Please help with leaking sink? What did we do wrong??
  132. Orangeburg repair/replacement.
  133. Electric Water Heater Placement
  134. Can I use a cleanout for a toilet?
  135. Hot water won't stop coming out.
  136. RELIANCE 501 Water Heater specs.
  137. Need advice on drain pipe repair
  138. Replacing plumbing to second story
  139. joining NSF DWV to PVC?
  140. Hey all! Softener Install Question
  141. Old style faucet replacement
  142. Another hardware question
  143. Sink driving me NUTS!!
  144. Sink Removal
  145. correct faucet hose
  146. washing machine will not spin
  147. what is the correct water pressure
  148. Which model water heater?
  149. Series Hot Water Heater
  150. Drain too high!
  151. Interesting Inspection Photos
  152. pipes clanging
  153. Too long for Recirculation Pump?
  154. sump pump versus grinder pump or both?
  155. Water Heater Modification
  156. BIG PROBLEM: Installer didn't read instructions!
  157. How weird is this? Pipe soldering clamps
  158. Broken 1" pvc supply line help
  159. Combining sink and toilet's water pipes?
  160. Basement toilet mounted on plywood?
  161. Dry Fitting Flange......Too Tight...how?
  162. black particles clogging faucet aerators
  163. flange extender over slab
  164. Outside Sillcock, I messed it up, please help.
  165. Proper Dryer Duct Materail
  166. Cleanout problems solved, now come vent problems
  167. bathroom vents
  168. Water pressure problems
  169. Dielectic union between brass and black pipe
  170. Basement Bathroom Plumbing
  171. How much length does ABS need to grip a closet bend
  172. Losing pressure when filter is installed
  173. Help tieing into 4'' drainage line
  174. Plumbing Distance
  175. pressure 80 psi
  176. Can this be real? $700 drip
  177. Bathroom Venting Questions
  178. Dip tube replacement question
  179. Help replacement shower diverter is to short.
  180. Wye Combo / Wye Questions
  181. loss of pressure /volume
  182. Pressure vaccum breaker
  183. Bladder or no bladder
  184. TOO MUCH SEDIMENT!!! Help!
  185. Question About Pipe PLEASE HELP!
  186. Spray handle won't budge
  187. Filter for hot water? (dip tube problem)
  188. dirty water
  189. New Construction - Basement Slab Roughin
  190. PEX Pipe for under the house?
  191. Tying new half bath to existing drain
  192. Pegasus series 7000 cold water faucet cartridge removal
  193. Leak in Ceiling!!
  194. Tying 4"x4"x2" all-hub into existing stack
  195. Kitchen sink drain
  196. Bit of Hot Water Tank Science
  197. Washer/sink rough in question - pics included
  198. Help!! He wants to run the vent into the attic...doesn't seem right to me...
  199. Oxygen to Sealed Combustion Hot Water Tank
  200. New water service.
  201. Danco Plumbers Waterproof Grease vs Danco Plumbers Silicone Grease
  202. thermobalance(Hansgrohe) vs. thermostatic (Grohe)?
  203. cleanout installation
  204. Silver solder 4%?
  205. toilet tank seal
  206. Job Specs For Estimating
  207. 12 gal water heater on It's side????
  208. shower valve
  209. Pipe and water noise
  210. Replacing water service to house
  211. Gas line question
  212. water running somewhere, but where???
  213. Shower drain attach to cast iron drain in basement
  214. can vent face upwards on a backflow preventer
  215. Raising my bathroom drain pipe
  216. Pegaus series 7000 Cartridge
  217. DWV Questions for Bathroom Remodel
  218. Faucet Turned On By Itself
  219. Water softner
  220. Can I fix steam radiator shut off valves or do I have to replace
  221. Trap on washing machine drain?
  222. Bathtub Drain Advice
  223. Tub/Lav Swap- Need advice on venting!
  224. Riser Clamps
  225. Ball Vs Gate
  226. Gas work for landlord
  227. Booster Water heater
  228. Water Softener plumbing question
  229. Johnson T advice?
  230. Heat tape required for house?
  231. contemporary p-trap odors?
  232. Panasonic bathroom fan grill not flushed to ceiling.
  233. Air Testing
  234. framing for plumbing
  235. Basic Soldering Dumb Question perhaps
  236. Need Help working with PEX
  237. Basement vent needed, but long way from stack
  238. Proper way to clean home sewer lines?
  239. New Softener Contaminated Permanently?
  240. Slab drain pipe issues!! HELP!
  241. Commercial Water Service Pricing Question...
  242. Proper drain for water heater?
  243. Pros and Cons of Using AAVs
  244. Bosch dishwasher and airgap
  245. Aqua Stat Trouble?
  246. white stuff in shower valve
  247. Leaking Moen Kitchen Faucet
  248. Drilling through joists
  249. Two Way Cleanout - Ok?
  250. 9 inch rough in toilet needed... or ideas.
