- Code Check guide books?
- wrong drain height
- Toilet flange is level w/ finished tile floor
- Richmond Water Heater Pilot Problem
- Don'tcha hate when...
- PEX Pictures
- faucet recommendation for salt water
- Installing an angle stop valve
- Reference thread: when not to DIY.
- union leak
- Outdoor fixture repair
- Boiler replacement questions
- I thought PVC was easy...
- One for the books
- New Closet Bend and Flange Question
- Huge Emergency 9:30 at night...HELP!!
- Kodler bathroom faucets
- Water Line for Icemaker
- Dealing with gray water (shower, sink)
- Multi-Shower Heads ?
- Shower drain - order of events
- Dishwasher problem
- Septic Tank question
- Undermount sink to granit install
- Can't find Kohler Tub Part...
- smelly water heater
- PEX Manifold sizing (Vanguard MANABLOC)
- Ethics Question
- Shower head leaking when filling tub???
- Leaking Outside Faucet - need a fix
- PVC P-trap to Metal drain pipe??
- Flow Issues
- sewer gas/rotten food/dead mouse odor
- Hot water heater trouble
- "Life Time" Warranty Water Heaters?
- Pros and cons....Uniforms for a more professionial looking plumber.
- Loose pipes
- Shower Arm Flange for Hacks?
- please review new drain and sewer line pictures
- Bad night at work
- Venting drainage system in cottage
- Changing bath lavortory
- Demo Hammer/Roto Hammer--Help me choose
- Some CAD for fun...
- connecting rough-in 3rd level shower, sink and toilet vent stack
- tub overflow drain
- vents and windows
- Plasterguard
- flushmaster toilet fills/runs longer than normal
- Language and Courtesy to others
- 5/8 Fitting
- Rotten Stud(s) Replacement and PVC Vent Line
- Leak through second floor??? HELP!
- kitchen drain
- Kohler 2 bolt tank
- Advice on underground PVC repair couplers and moving earth
- Clifornia Plumber License
- "water" air conditioning
- Removing paint from copper pipe
- Water heater Overflow Issue
- How to break concrete around copper?
- A few gifts from plumbers.... to the rest of us.
- Running Pex in craw space
- How to connect metal pipe to PVC?
- DIY philosophy
- Need Septic tank advice please!
- water heater elements
- Help!!!
- Need ABS to Metal Adhesive/Connection Advice ...
- sub house drain question
- going from 1/2" feeds to 3/4" valves...
- Distance to Water Tank Question
- can you make this right?
- No Tip
- Clogged shower drain
- Water Softener Brine Tank Odor
- great way to clean cast iron sewer lines and more
- Enlarging stud holes for sillcock
- Securing a vent stack
- Ok, now my plumbing problem...
- Replacing a cracked waste & overflow assembly
- Handheld Shower with fixed head combo
- Plumbing hasn't been used in years
- Making a sleeve for basement closet bend before cementing???
- Dual Heaters?
- Plumbing a slab with no existing plumbing
- Noisy pipes, pressure / air in the lines?
- HW advice New construction
- "Clunking" noise when water first turned on
- main service to the house
- faucet question
- replacing thermostat/gas valve on water heater
- Water Meter
- Plumbing Time Bomb!
- help - hot water tank leaking, no hot water
- trap alternative
- Creative Plumbing
- Valve Recommendation
- Kenetico Water Softener claim question.
- Are these Concrete? How do I connect PVC?
- How do I Replace a Faucet??
- How many vents can I tie together?
- Fitting size on gas regulator
- Delta MultiChoice Rough In Valve
- Drip in Wall?
- Water Tank Theory ?
- How to solder correctly
- Water service line from street...
- Copper Supply Pipes - how close to outside wall
- Toilet bend Not 100% level?? Am I OK?
- Septic root problem
- Removing Old Cast Iron Clean-outs
- Drilling cast iron
- Double vanity with single center drain?
- Venting a Bar Sink
- L.A. Style P-Trap
- Vent lay out and hight in 1.5 story house
- Rusty Water
- Roof Vent Pipe, Help Please
- 1 or 3 furnaces for a multi unit?
- bathtub faucet leak
- 4" mini-spread in 8" wide-spread holes?
- Cutting Cast Iron 3" Pipe
- Catastrophic vacuum breaker failure and brand
- Bend in pipes vs clog - now what?
- Pex in salty environoment...
- Drain Lines for Washing Machine and Sump Pump
- My water bill is too high!
- bathtub drain down pipe issue
- Diverter confusion in Ohio
- Where should I cut and connect the Galvanized Pipe?
- Recomendations for a shower valve?
- Sharkbite/pex problem
- Air in the line ?
- Water Heater-Fire
- How to Level a PVC Shower Drain?
- Pipe diameter
- Inserting a Tee into an existing copper line
- Bath Fan to Weak?
- Problem Installing Toto Aquia on Closet Flange on Floor
- Tankless survey
- Business Question (NSF)
- Mystery Fumes
- Venting through a double Wye Tee
- More Copper Theft but with concequences
- Seriously Tough Plumbing
- Croton insulation...
- Ok to use 90 degree bend in 1 1/2" drain?
- Turn off water & gas water heater question
- Blowing Water Out of Lines
- Replacing T/P Relief valve using PVC instead of copper?
- Danze vs Blanco
- raiser below ground
- Covering Ugly Galvy Pipe
- Slow bath sink drain
- Unknown toilet manufacturer
- Repairing dime-sized hole in 4" CI pipe
- Plumbing question
- Can I reduce the size of my main vent stack
- Replacing Kitchen Sink cabinets
- Kenmore ultra 800 water softener problem
- sizing gas pipe residential Ca.
- General liability insurance question
- GI Joe, What we find in toilets
- Question about pipes in bathroom (photos)
- Installed new kitchen sink, but no water?
- Funky Sink Trap Problem
- Zone Valve Change motor
- Type of Pipe Used When Driving a Well-Point??
- Hot and Cold Water
- Sewer smell
- Vent line
- Tub-Shower Drain
- Split Copper Water Line
- Moen Kitchen faucet sprayer trouble
- Septic field is across the street. Concerns?
- Sewer Backwater / Check Valve
- lavatory drain: need suggestions
- ELECTRIC Water heater
- Gas Water Heater Question
- toilet install
- New product idea?
- No vent Or looped vent
- New tub in basement help needed..got photos!
- Supply Line For Ice Maker
- Radiant heating with tankless water heater
- 1.5" to 1.25" Drain Reduction
- Hiding in the Joist Bay
- Intermatic Water Heater Timer
- Plumbing noise
- removing stand in shower
- PEX Help
- Shower drain odor
- sewer holding tank filling quickly
- piping for condensate drain, good or bad?
- Copper water supply under slab
- Old plumbing - Do I need to update for toilet?
- Plumbing Trap ?
- Air admittance valve - "above the flood level rim"?
- Soaking Vanity Faucet
- P Trap Problem Please help!
- How busy are you guys?
- Grease trap/gravel basin
- Plumbing Conundrum
- polyethylene svc line
- To flare or not to flare
- Minimizing Noise Ideas
- Draining & purging boiler system to add 3rd zone
- Sizing pipe for a new hose bib
- removing unused drain + supply
- Establishing a value for your business.
- problem with new porcher bathroom faucet
- What do I use to plug this drain in my floor?
- Tightening Grohe Ladylux Plus
- Re-plumbing House-Piping Selection
- replacing closet flange - not much pipe to work with!
- Water removal from an outdoor below grade stairwell
- PVC Vs ABS
- Made a mistake...wrong cement
- Kitchen Sink Leak
- Workaround for slight damaged closet flange
- Convert draft vent WH to power vent?
- No Hot Water from Shower
- How deep the drain pipe bury under the cement floor
- Rapidfire hammer noise
- Any tips for removing old metal basin
- Fleck 5600SE water softener programming
- Question about delta kitch. faucet repair
- Supply line
- trying to make this work
- Flux ?
- Source for Copper Finish Drain Parts
- HELP! Gas Water Heater Leaking!
- Pure Irony
- Installation of Wood Boiler
- Joning CI to ABS...drip...drip...drip:)
- plumbing for solid surface tub walls install
- wall mount sink
- Fountain leaking at PVC pipe/cement joint
- Outside Shower
- Kitchen Remodel and old plumbing issues.
- Computer-controlled digging for water main replacement?
- Condensation Mystery!
- Testing new Plumbing
- Please Help!
- Metal Bonding?
- 'Depressurization' Smell to Water ???
- Water Softener location?
- Installing Shut Off Valve on copper pipes
- flow down to trickle. Why?
