- Compression fitting faucet valves
- low flow hot water
- screwed up the bathroom reno
- Using fernco proflex
- Best sealant for high water pressure?
- Wide sweep copper 1/2" 90's?
- Underslab DWV
- PRV opening on new tankless..
- New Pressure Regulator - Still getting pressure problems
- Costs of moving DWV and Toilet
- Elbows
- auger through the trap
- white or wheat bread....
- Bosch Dishwasher and drain line issue
- Help with slow running water after installing a pump
- ABS plastic and concrete
- Do I really need to use frost-free spigots?
- Sanitary T w/ L & R Side Inlet
- Basement DWV OK?
- Newbie sweating pipes
- Adding a laundry tub in the garage
- water softener mechanical vs digital meter?
- Low water pressure in the shower only.
- Plumbers fight for famous phone number
- Would someone explain to me...
- Yuck! shower smells like a septic tank
- Old pipes. slightly larger?
- Please help/Bad odour in house
- Anyone???
- Is this valid?
- Studor Vent for Bar Sink
- copper pipe in the swimming pool systems
- shower drain
- Expansion Tank and Check Valve Install
- How to avoid overheating rough-in valves.
- Finding pipes in wall to epipe a 2 story
- Bathtub venting question
- Septic Tank Odor - Vent pipe (Why now?)
- This faucet drain leak is driving me crazy, pls help!!
- Washing machine problem
- Running Water and Drain from Slab to Slab
- PEX versus Copper
- How did "street" become fitting name?
- roughing in for a toilet before concrete
- How low should I go? (buried water lines)
- Help! Only lukewarm water
- Pex..? Should I be worried?
- Whistling Gas Line to Pool Heater
- Lack of Water Pressure
- Cement slab leak
- black pipe assembly technique
- Basement plumbing rough in
- Sewer Line Under Slab - New Construction
- Installing Shutoff Valves in Galvanized System
- Help grohe rough in valve won't turn off
- Switching steel for copper
- fountain problem
- Lound Banging Noise with sngle handle shower valve!!!
- tub spout/diverter replacement
- Dishwasher Won't Fill
- HELP! Manabloc/PEX Problem
- Looking for a 4" sanitary tee with two 2" inlets
- Bathroom renovation
- Dishwasher connection
- The worst I have seen in a long time
- Can I pipe two bathroom fans to one roof vent?
- Water Heater Leaking on Top at In/Oututs
- Moen trim kit - Handle sticks out too far
- Vent... should it stay or should it go
- Critique, please
- Septic drainfield / absorption field questions
- Tub/Shower Rough In Valve
- PVC SDR35 versus PVC SCH40
- Sill Cock Faucet Problem
- shocking
- Bathtub faucets
- Putty?
- Condensate Pump for Water Softener
- Shady plumber or paranoid client?
- Plumbing & Subfloor Preparation
- soil cement or ??
- new washer drain
- Replacing main water line - Questions...
- Need Longer Drain Hose
- Kohler lowboy rebuild tips&tricks needed
- new install...leaking valves ????
- any ideas??? DELTA SINGLE KNOB SHOWER-REPLACED WITH PP SINGLE LEVER
- Torch Troubles
- Vent Stack
- Sewer cleanout outside house is 8 inches too tall
- Starting up a septic system
- Icemaker
- abs or pvc
- toilet vent size issue
- how to verify if drain pipe passes code (cast iron below grade)?
- Brass Pex fittings failing?
- Couple of questions regarding new tub/shower installation
- DWV Line Testing Device - Can I make one?
- WM Standpipe/trap
- Under Slab Waste Pipe
- Steel riser clamps for PVC
- Bauer Water Softeners
- Removing clean out cap?
- Sump Pump disaster/failsafe solutions needed
- Brass tailpipe stuck - plase help
- Chrome plated brass p-trap to 2" PVC
- automating stuff
- Kitchen sink drain install questions
- Plumbers putty on fiberglass tub?
- Is 1/2" PEX supply big enough for dual shower head?
- dumb question about pipe supports
- Want to move vent pipe, not much room
- Moen from Home Expo?
- Polybutylene (PB) advice for new condo purchase
- Pipes bang when turning water on
- Basement Floor Drain Problem
- Electrically Actuated Full Port Brass Ball Valve 3/4"
- how can I get snake past this T?
- Estimate
- Pipe Sweating or Leak?
- Bradford white pilot tube
- How long do copper water lines last?
- Pex brand question(s)...difficult decision
- Electic water heater doesn't work
- Grohe Ceramic Cartridge Drip
- Smelly Faucet
- Pump cutting on and off ever few seconds
- Installing PEX in attic ( non heated space )
- toilet flange question
- How make jacuzzi jets harder?
- Connecting 2" PVC to 4" Stack under Concret
- using a ball or gate valve as a throttle?
- Job Opportunity
- Garbage Disposal-Stone Sink
- shower stall leak
- Low-end Kohler products - is my builder ripping me off?
- Tub Faucet, Cold Water Slow
- Draining Tank Lots Sediment!
- Perplexing PLX
- screw hole in pvc vent pipe
- Can Sulfur smell and iron be removed with a softner
- move waste line
- moving waste line
- Thread or sweat for new Delta shower valve install?
- Cement cure time?
- Tub Install Question
- MOEN Single Handle Kitchen Faucet Repair
- question about galvanized pipe
- where to find old style kitchen sink
- PVC Plumbing too high; need to lower
- No water, consistant problems.
- Tuscany vs Delta
- Constant pressure sys VS larger cap well tank
- Sawzall blade for steel tub??
- Thomas Skid Steers
- Pls review my bsmt bathroom plumbing plan
- Sewer Line Woes!
- Venting a kitchen sink
- Hot Water Heater
- Shower Trim Sealant or no Sealant?
- I can hear the groans
- Pex and UV
- water heater pilot light issue
- Spa pump needs vent tube?
- Where can I get this funky DWV PVC 6-sided cross piece???
- Drilling kitchen sink vent up through open web truss
- A Problem With Tub Overflow
- Yikes, Cut Joist/Toilet flange
- Leaking G-Max or Power Gravity Fill Valve
- Purchasing Freeze Damage home
- Got to know the Plumbing marketing
- Sewage pipe relocation question
- Vent Collar Broken on Cast 3.5"T How to fix?
- inspector's class
- Sizing for Washing Machine Vent
- Single to Double Sinks - Steel to PVC
- sharing water via garden hose?
- Black Pipe for boiler installation?
- Vent pipe ? Ends above the drain
- Sizing a Propane Pipe
- Need source for faucets (commercial application)
- hose bib sounds like a jack hammer
- Air in water line
- Basement bathroom plumbing plan, new version
- Water heaters...and finding a good installer.
- What's the thing called on a freeze proof hose bibb?
- Redo stack or not? Pictures depict my problem
- follow up to sharing water via garden hose
- PEX and fitting compatibility
- shared bathroom sink...what are these called??
- Why do I need vents? (How about AAVs?)
- Basic bathtub plumbing question
- Help...I Cant Find Any Fittings
- Any teflon in a hot water tank
- Repairing Kohler Finial Handle Leak
- Holy High Pressure!
- Can Thermocouple Touch Metal?
- New water main = bathroom trouble
- Best hot water solution for radiant floor plus domestic hot water?
- PEX and Tankless - what distance matters?
- Today's 1/2" fixed copper pipe project
- Replacing galvanized water pipe with copper?
- Question
- 2 Pex lines to a Urinal out of the question?
- Plumber Issue (need advice)
- Bad/Good Idea.Shower Valve
- DWV Vents Through Roof (NYC)
- Pex Plumbing Questions
- shower pump connection
- Sewer plug
- Problems with faux (HD) Moen fixture?
- Replacing a stretch of galvanized that has 3 problems
- Hooking new toilet to stack on 1st floor, below existing bathroom
- Why should dishwasher drain go to disposal inlet?
- Toilet flushes by itself..brand new
- New people; new approaches.
- New bath/shower valve
- cpvc expansion
- Closet Flange Installation
- Grease it up, or leave well enough alone?
- Bathfitters
- Copper threading tool
- Cutting ABS Straight??
- Cost to install pedestal sink vs. cabinet sink in new construction
- Main Stack Connection
- California plumbing code question
- Smell from sink
- sand point surging
- Improper Grading
- How to attach/paste pictures in threads
- Thread joints and Teflon tape question
- Twice as much time, Three times more money
- Should a new gas water heater need adjustment?
- Use of flared-end (bell) pvc drain pipes
- To whom it may concern
- Disconntinued Grohe trim
- Adjusting/Elimiating a Pressure reducing valve
- Question re using an apt. sized washer in an older building
- screw broke off in faucet handle
- I need a 1 1/4" slip joint 90 degree elbow.
- Tight fit in an older house
- Hot Water Tank doesn't hold water ?
- PRV outlet
- hot water pressure dropped after heater was replaced
- Freeze proof outdoor spigot repair
- Changing kitchen faucet.
- Need advice on tankless/PEX system
- Replacing shower fixtures
- Yet another smelly bathroom
