- Water Hammer when water turned on
- A newbie wants to build a Kerdi Shower!!
- turn off water to all but boiler
- transition Tee from copper to cpvc
- Grohe Bathroom Faucet Problem
- what is a good submersible sump pump to buy?
- Vent Problem
- Well Pump held by 1/4" cord
- Water pressure and supply line question
- PEX supply questions
- What caulk to use for plumbing penetrations?
- Mildew smell coming from overflow holes
- broke off galvanized pipe under slab..need help
- No more Teflon?
- Radiant Heating System Newbie... Help!
- Preferred Pex Brand
- Adjusting vent pipe
- Boiler Change-out?
- Plumbing clogging under slab
- Toilet flange not flat against the floor
- Clogged Cold Supply, 1 loc., Pre shutoff
- Winter is coming
- Can you snake a 1/2" ID galvanized pipe?
- Mineral Deposits in Water Heater Inlet
- How to get a quote for hooking up radiant?
- waste flow with old toilet vs new toilet
- No Hub Couplings really work?
- Vanity venting
- ABS to PVC under new vanity
- sink vent
- Sears / State Water Heater Nightmare
- Main Vent Question
- This one may require an asprin
- Help with Moen Single Hole Faucet
- Red/Blue AquaPex (Wirsbo/Uponor) Scratch Question.
- Potterton Suprima 40 not fire up
- cpvc and wrong glue
- Odour from Acid Drainage System
- On Demand Hot Water?
- Gas Water Heater
- need to buy an electric hot water tank
- Toilet Flange Advice
- Replacing Main Water line
- Septic to sewer conversion
- Copper touching black pipe
- Grease biult up in kitchen drain
- Here's a Picture, How Do I Move Drain?
- Rit Dye Safe for Septic System??
- Faucet handle slides down
- rotten cotton / mineral wool
- Water Line Leak Question
- Brass Pipe Thread Connections...
- Need to move PB hot water line...
- water line
- Condensate neutralization, or not?
- Best recirculating pump?
- Gas water heater (good - better - best)
- Water line vs. water pressure
- Tax writeoff on Van for business use?
- garbage disposal
- Duel Kitchen sink odor
- Venting ?
- Incline for shower waste
- Jacuzzi Waterfall Tub Filler
- Popup drain plug doesn't
- Sewage pump
- Help with Faucet Supply Lines
- Moving/Extendiing or rerouting pipes
- Bathroom torn up and wife returning from vacation!! HELP!
- Another soldering question
- Installing CPVC tee to drain humidifier
- Options with galvanized pipe
- Polybutylene Piping, do I buy?
- Plumbing question for remodeling
- Newbie, first bathroom install would like some advice
- Basement Toilet freezing in the winter
- AAV with basement ejector pump
- The plumbers broke my faucet
- Old Cast (underground) to PVC
- Galvanized plug in copper pipe?
- Sewer gas in office
- ground joint unions with center punched nuts
- Please Help With Newbie Question- Roughin In New Bathroom
- Pex Insulation
- Whirlpool Junk Water Heaters
- Redoing Hot Water Radiators - Whats Ideal?
- sewer gas.....
- Water Heater Location?
- acid bath
- Dmw Chart
- Dwv Chart #3--please Comment
- MOEN Diverter Off In Middle Position??? Help
- Basement sink, vent question
- Use of Pre-soldered copper fittings?
- my kitchen sink sprayer thinks its a machine gun
- Formula for GPM ?
- Male copper adapter to shower valve slight drip?
- Sulfur smells...from one shower head only!
- Need comments on my proposed install
- shower drain
- Weaping union fittings
- Water heater question for EXPERTS....
- Question about an icemaker
- Rookie first time questions..."cleaning" the solder
- Darn "Flapper" won't shut up!
- Foundation Drain System (sump pump)
- Anode Rod-Sorry--Long
- The tale of two nipples...
- Qest, Zurn, Sharkbite, Watts, grrrrrrr.....
- Ice maker hookup
- Hydro Air Coil Pex sizing
- Basement bathroom rough-in
- Musty Smell from hot water in house
- Pipe sizes for drain, vent, and distances for Colorado Springs, Colorado
- Moen Faucet, it works... eventually.
- Concrete Encasement???
- Raise Cast Iron Radiator due to new wood floors - HELP!!
- Cruddy fixture --> PITA ---> nightmare !!
- Square Oil Rubbed Bronze Shower Drain
- recalled water heater
- Good fences do not make good neighbors...
- Funny sounds...
- Replacement Shower Drain
- where to tee in
- Aerator Spraying
- Gas Water Heater
- dis-similar metals
- Slab vent
- Shower drain tool?
- Sanity check
- Help to Install Flange
- Boiler in 105 year old home
- flange spacers
- Copper Pipe - 10 foot lengths??
- Black tubing and glued fittings?
- Connecting new tub drain
- Best tip we ever got
- What type of pipe to use
- Flange ???
- Lift station questiona
- Refilling baseboard heater boiler and lines
- capping laundry room floor drain?
- disposer and sanatary tee height problem
- hot water shut off valve
- price estimates - insultating pipes, water filter system, etc.
- icemaker water supply-modify?
- use of 100% silicone sealant
- Question on planning for inspection and floor drain
- Sewer smell from basement drain
- How to Hide Pex Plumbing??
- ProPex Question...
- Strange Water Hammer in Baseboard
- Bathroom Sink Remodel/Drain Pieces Aren't Long Enough
- Bathroom fixtures
- How to sound insulate ABS drains
- Hose bib w/ galvanized line in crawl space
- Plumbing & Sewer and Drain Professionals
- Am I Getting Hosed???
- Saddle Valves and PEX?
- Remodeling Bathroom
- Cutting 2 inch and 3 inch copper pipe
- Supply lines and drain for washing machines.
- Solder and Flux
- 4 in. PVC vs. 3 in PVC
- Shower drain smell
- Dirt?in the water
- mini moat around shower drain
- value in insulating hot water pipes
- Squealing Pipes
- Maximum number of fixtures
- Rusty water from tub spout
- Compression fittings
- drain pitch
- Plumbers of the world, take a bow!
- clothes washing machine hose -will water stink?
- Drop Elbow for shower bar rough in
- Heating Rads A Strange One !!!
- Attaching Kerdi to old CI concrete floor
- Island style vent for bathroom sink vent?
- grasslin integral timer
- Hot Water Tank in Uninsulated Shed?
- Plumber Of The World Wanted
- Moved the trap, right?
- Sink Replacement
- cauking at shower drain stall
- dangerous water heater?
- Sewage smell in drains sometimes???
- Moving forward on zoning heating system
- Low flow faucet options
- central heating nightmare
- Hot Water Heater
- stink pipe
- Direct Drain Bath Tub Question
- Waterheater/snow melt
- Carpeting over floor draines...
- Humidifier
- Sink overflowing Alzhiemer's - need metering push faucet?
- Fine thread on drain shoe question.
- pressure relief valve
- move vent to install medicine cabinet
- Discharge from T&P valve
- Bath tub spout "SWEAT" question
- Water heater query
- washing machine odor
- gluing CPVC
- Gluing CPVC pipe with PVC cement
- gurgling sound
- Bypass humidifier
- Grohe faucet base removal?
- hot water smells, could it mean my water heater?
- electric baseboard heat
- Munckin Boiler and Munchpak
- Water Heater Dead ?
- T&P valve drain plumbed up!
- Anyone use these
- Basement bathroom install questions
- Washer /Dryer Question
- Hot water only noises
- What to do if water in pipe when soldering?
- Bathroom Makeover
- leeching fields and cesspools in a high water table
- Water heater theory.
- Smell from Hot Water Heater
- HW Tank Installation Advice
- sewage smell in bathrooms
- Sink noise and HVAC heater....connection???
- Water Hammer
- Bath Remodel
- T&P valve activating on new water heater
- Shower Drain In Concrete Slab
- A pain in the glass
- Kitchen Sink Clogged!!!
- Kitchen Sink
- Adding a Laundry Sink
- 120V Thermostat Change Out
- drain pipe failure - pics
- Hissing noise but no water?
- Good fences do not make good neighbors - cont.
- How do I cap this cleanout--no threads
- Shutting off one of two water heaters?
- Stack Vent Routing
- Shower Drain distance from stack
- Hot Water Heater Lock?
- Need electric water heater placement/design advice
- Water Heater gas line
- instance hot water dispenser installation
- Bathroom Sink Leaks
- Extending Central Heat to 2nd and 3rd Floors
- Gas furnace readings
- Leaking Bathtub
