View Full Version : Plumbing Forum discussions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Pressure Balance Shower valve
  2. Oatey Wshing Machine Outlet Box Help
  3. Valve recommendations?
  4. Sewer Gas Smell After Flushing
  5. Antenna and lead - vent
  6. Water Supply Pipe
  7. 1 1/2" Copper Shower Drain NG in MA
  8. Is there a class action lawsuit against Kitec piping?
  9. What type indirect water heater?
  10. rough in plumbing plan??
  11. Shower Drain Question
  12. Water Pressure Booster?
  13. Low pressure at kitchen sink
  14. 3/4 or 1 inch service
  15. Removing push-on stops on hard copper
  16. 3/8" compressions to 3/4" Pipe adapter
  17. No-overflow sink draining slow
  18. Is 1/8+ gap between adapter and pipe fine ?
  19. Is 17 AWG dishwasher tailpiece that uncommon
  20. Family in need
  21. urinal stop valve question
  22. basic question on threaded fittings
  23. Shower drain installed by chimps
  24. water softener disaster...
  25. Code v. reality: 1.5" drain
  26. Gas Burning Question
  27. Slow leak in bathroom
  28. Replaced all galvanized except for.....
  29. Cutting Cast Iron
  30. Female Pipe - Nipples - Pipe Support
  31. Vessel Sink Height and Venting
  32. Repairing lead vent flashing
  33. Newbee: help with drain on slab foundation
  34. Rough in height for bathroom sink?
  35. Tankless Water Heaters any good?
  36. Conventional Water Heater minumum space needed?
  37. Another Basement Bathroom addition
  38. PVC Pipe Roof Vent Leak Onto Ceiling
  39. Change basement rough in
  40. DIY Soldering
  41. When to use flexible copper?
  42. electric water heater
  43. Kohler Pedestal Sink Install
  44. Pex in cabin? Freezes? Minerals?
  45. 2 water Heaters vs 1 large one?
  46. Pipe Fittings
  47. Pipe Dope vs. Teflon Tape
  48. Install clawfoot bathtub faucet
  49. hot water heater question
  50. Whistling Pipes, Not the best music
  51. ABS into cast iron hub with neoprene gasket HELP
  52. Cast Iron Drain Modification Needed
  53. Is this legal plumbing in NYC?
  54. what size studor vent?
  55. Elec HWH
  56. High quality/designer stop valves?
  57. Pot light wants 1/2 copper real estate
  58. Stuck lav drain
  59. Broken sink stopper knob
  60. Running A Waste Line in an Exterior Soffit???
  61. Flapper questions
  62. Pulling our hair out in North Bend WA
  63. I hate cold showers!
  64. Plumbing newb seeks advice on rough-in
  65. Hot water in attic Question
  66. slow draining tub, help!
  67. Has anyone ever seen a 3/8" Female Compression - 1/2 Male Pipe Adapter ?
  68. Pipe Volume
  69. Black iron pipe question
  70. Automatic or Non-Automatic Zoeller 267???
  71. Toilet Flange - Will this work?
  72. Roof Vent Question
  73. water heater install question
  74. Running COAX/Cat5E down Vent Pipe??
  75. I need your help
  76. Replacing sewer line
  77. 3 Seemingly Basic Basement Plumbing Questions
  78. When am I supposed to use Brass tube support sleeve
  79. ? Application of T plus 2 Rectorseal
  80. Who do I contact
  81. Fernco Donut
  82. pipe threaders??
  83. fancy faucet - big leaks!
  84. Any tips on capping off angle stop
  85. tankless water heater for radiant heat
  86. Hot Water Tank Problem
  87. ejector pump keeps running
  88. Accepting Credit Cards for Payment
  89. Hotwater Heating
  90. Extending shower/bath supply lines
  91. Nail Plates on Studs and responsibility
  92. Plastic or Brass Compression Sleeves
  93. New Home water pressure
  94. Should there be movement on a compression fitting
  95. Gas pipe sizing
  96. How much black mold will stop you from getting old?
  97. No Brass Insert for flared Plastic
  98. Reusing ball valve
  99. how do I purge gas line? I installed new gas range.
  100. Gas boiler installation...
  101. Hot water issue in shower/tub
  102. Proper Pipe Sizing on Plumbing ReDo
  103. Is green *patina* normal on copper pipes
  104. Vent stack question - washing machine
  105. Washer Waste Drain Slope
  106. Water heater - hot water disappears
  107. Bathtub faucet removal/install
  108. Kitchen sink backups
  109. tool for oatey brass shower drain
  110. where to solder copper pipe
  111. Reaming copper pipe & noise
  112. copper to old lead water line
  113. Required drain size for double sink and tub
  114. flexible pvc pipe
  115. Piping for natural gas
  116. 2 HW Tanks in Parallel, Where to Tap Irrigation Line? Need for Expansion Tanks?
  117. Noisy Electric HW Heater
  118. install a T on existing line
  119. Drain & Vent questions for new tub/shower
  120. water reembursement , broken pipe
  121. Dishwasher Drain Hose Question
  122. Connecting addition into existing DWV?
  123. AO Smith Conservationist "Gold Edition" 40-gal NG WH
  124. kitchen sink pressure
  125. A water Pipe is making a knocking noise when...
  126. Are some *brands* better than others
  127. LOckNut Wrench
  128. PowerVent Water Heaters
  129. What *wrench* fits for a Kohler Sink Drain
  130. location of clean out plug
  131. Dirty Dishwasher help needed
  132. New Construction Plumbing Layout
  133. pressure test on new PEX tubing
  134. Source for 3-way stop
  135. How to snug up my DW - tailpiece adapter
  136. Recirculating ac condensate?
  137. Anti-Siphon S Trap
  138. Triple bowl kitchen sink
  139. white plastic debris plugging faucet
  140. Number of fixtures per line?
  141. So tell me fellas - who's going to adopt to the snap on copper fittings
  142. Basement rough plumb - what's this?
  143. Sewer Drain Problems
  144. DWV fittings for pool plumbing
  145. Hooking up my humidifier
  146. I need your secret :)
  147. Stubborn faucet flange won't budge
  148. Removing Basement Rough-In
  149. Question about new Speed Connect Drain by Am. Std.
  150. Water Line Layout
  151. how much markup?
  152. Shower Diverter / Leak Problem
  153. Experience with plumbing supply house
  154. Copper pipe touching pressure treated wood
  155. Pipe Protection
  156. Newbie Gas Questions
  157. sweating
  158. P-trap under grade beam for outdoor drainage
  159. Aluminum pipe wrenchs
  160. Steam shower manufacters recommendations
  161. laundry faucet hookup
  162. Moen Rough-in Valves
  163. Plumbing - Does this look right?
  164. Forum like this for HVAC?
  165. Loop vent question: waste connection
  166. new home knocking pipe
  167. Help posting attachment
  168. prob. W/ wash. mach. valve
  169. Foul odor near ejector pump
  170. Venting questions for basement bathroom
  171. Ejector pump taking on water from under slab?
  172. 2nd toilet overflows when it shouldn't
  173. Can I tie a basement vent into drain pipe of upstairs sink?
  174. loud low humming noise associated with outside irrigation systems
  175. Diagram-tankless shop heating?
  176. To prevent copper from touching ductwork?
  177. conceal water pipe - interior room
  178. Need help finding DECENT manufactured home kitchen sink
  179. Tub Only Fixture Question
  180. Special attachment from drain/overflow to ptrap
  181. Dishwasher drain hose
  182. Flint walling water softener problem
  183. Zoning Heating System
  184. Draining 2tubs 1 shower into 1.5
  185. Help with pitch/slope from house to sewer
  186. Weil-McLain Ultra 155 and purging air out of system
  187. Angle Stop Valve Leak -- Help!
  188. Any plumbers wanna take a look at my roughin plans?
  189. bathroom sink vent/drain
  190. 1952 american standard shower diverter
  191. New upstairs bathroom advise
  192. Thanks for all the help
  193. hot water heater brands
  194. What's the best valve for "shut-off"
  195. Not a Plumbing Problem - But Would Appreciate Advice
  196. delta faucets won't flow, help if possible
  197. priming domestic heat pump
  198. We gals need some help
  199. Newbie needs some help
  200. need a different solution
  201. Leaking taps
  202. no vents for a septic system
  203. Metal straps on ABS pipe?
  204. Connecting sewer ejector to gravity lines
  205. Sweating mystery -what did I do wrong?
  206. Accidental hole in 3" PVC Drain Pipe
  207. Inspection report - Plumbing
  208. 3/4" copper bonnet leak
  209. Hot Water heating circulation problem
  210. Relocate Water Heater
  211. Sink Vent Connection
  212. American Standard R015 v. R115
  213. Toilet Draining Problem
  214. Slow Toilet
  215. One handle shower valves...
  216. Access Plug to drain frozen
  217. Pex Tubing
  218. The Unknown - Dishwashers!
  219. Scholarships
  220. lead solder? Uh oh!
  221. street elbow
  222. Type of check valve
  223. 3/4" PEX Plates
  224. fuse blowing
  225. Rerouting gas pipe for basement rec room
  226. Bathroom remodel - lead sink drain
  227. Vents and smells
  228. Master bedroom washroom toilet
  229. Noise coming from water lines?
  230. sewer gas from basement shower...
  231. Fixing Basement Bathroom
  232. Replacing a garbage disposer
  233. Low water pressure after changing handle valves
  234. Single handle delta clean out?
  235. Auto Radiator stop leak plugs copper pinhole.
  236. Who is the manufacture??
  237. sweat vs threaded on a boiler
  238. Sloan verses Zurn
  239. Pop-up Sink Drain install - off center sink drain???
  240. slip coupler sources
  241. winterizeing an in-ground pool
  242. help with water heater
  243. Broken CI drain part - how do I fix it?
  244. air in well water system
  245. Plumbing Installation through floors for sewer pipes
  246. British Standard Plumbing Thread - Plugs
  247. Extended travel - Do I stuff the sink trap ?
  248. 3rd floor shower clogged
  249. instead of a p-trap ----
  250. Supply Line Size for Rain Shower Head
