View Full Version : Shower & bathtub Forum
Pages :
8]
9
10
11
12
13
14
15
16
17
- two shower heads, one shower?
- Angle Shower head question.
- Replacing tub with tiled shower walls & floor
- Existing Drain. Use for a shower?
- Plumbing for new vanity/sink
- Replacing 30 inch tub with 32
- Shower Valve Deep Rough-In kit leaks
- adding shower drain in slab
- Look What I accomplished in day#3 work on the remodel bathroom
- leaking shower valve
- rough-in valves
- hot/cold shower imbalance
- Shiny Bathtub
- Help: Please help me identify this shower faucet
- One more turn on shower arm?
- Hansgrohe shower panel?
- Anyone ever use Bathfitter?
- Cleaning Shower and Sink
- Mortar under swanstone showerpan
- Help Identify
- Single Shower Faucet Replacement....
- Help removing shower stem
- Hard Water Stains
- Rain shower, handheld and tub.
- Drilling holes in porcelain sink
- Easier Way for 2 inch Drain? (1 Piece Shower In Basement)
- Convert Shower to soaker bath
- New shower 1 1/2 inch narrow. HELP!
- pipe adapter for shower drain?
- low water pressure in the shower
- Vapor barrior location
- Danze faucets
- Diverter, TempAssure???? What do I need for my shower?
- can't install shower hot/cold knob! wall tile issue
- Shower/tub drip - valves
- master bath remodel
- Starting the Passport Jacuzzi Ensamble
- Wing-its and grab bars
- grohe online retailers - 40% discount????
- fiberock underlay
- best ceiling fan??? panasonic? broan?
- Backer Board Under Sheet Products?
- Quick question regarding overflow pipe.
- add shower drain
- Shower Pan Installation
- Bathtub drain
- diverter stem
- Replacing shower drain pan
- moen luke warm water
- Caulking the Tub Spout Question
- shower questions
- Price Pfister Multiple Leak?
- Stuck diverter valve
- Diverter Attach - Just a strap? Really?
- Hi! need shower/tub combo buy advice
- How can I fix a bad shower pan install--Help!
- how to connect plastic shower drain to 2" copper drain line?
- Cast iron to PVC for Shower and Toilet Concrete Floor
- Aftermarket Heater for tub with jets
- Basement bathroom shower drain in concrete block
- abs vs acrylic showers
- Can I offset the vertical pipe on a p trap?
- hot water luke warm in morning when heat kicks on
- Delta shower troubleshoot
- price pfister shower knob problems
- Any experiences with Kohler Purist shower doors?
- Who knows what to do witha new Delta tub spout in new construction?
- Tub Spout Length
- Oatey brass no-caulk shower drain
- Joist meets Drain - now what?
- Slip-on or Screw-on Spout?
- rustproof escutcheons
- attic shower
- attic shower
- Fiberglass tub is starting to flex
- Replacing Shower Faucet
- No Room to Sweat
- leaky moen posi temp shower valve fittings
- Problem with old shower faucett/parts
- Kohler K-304-rite temp
- delta 1700 leaking, help
- Replacing Tub Drain Collar
- Basement Shower Drain..enough space?
- decorative wall panels for showers
- Leaking Shower valve - getting replaced, what else to look out for
- Problem With Ceramic Tile Shower Surround Walls
- Grohe Shower Faucet Covers
- Restoring 1934 tub...Refinish Types?
- Can not identify shower faucet
- Shower valve rough-in, PEX...
- Replacing a Delta Shower faucet w/diverter
- Fixing fiberglass shower/tub
- Diverter problem
- now we have rust!
- Shower water used to be hot, now it's cold
- Swanstone trim
- Can I use solder instead of tape or dope?
- noe angle shower doors
- sliding doors
- First time installing maxx vichy corner tub questions
- Opinions on Crane Whirlpool Tubs??
- moen shower valve supply question
- Insulate a Bathtub?
- replacing OLD tub handles
- Leaky American Standard
- Tub cleaning/sealing products
- custom shower with PEX?
- Water temp varies throughout house
- Shower trim kit for Delta 1500/1700
- Vent bath fan to soffit vs. side vs. roof
- Mounting shower/tub valve
- tub drain with aav
- shower arm and an easy out tool
- Shower Faucet Problems
- tiling directly to bathtub sides
- Strange Kohler Shower Body Valve issue
- Condo noise problem with tub only
- Shower drain ?'s
- Swanstone Wall Panels
- Leak around tiles (I think)
- Where can I get this bathtub?
- Help Needed- Water Running
- Non-standard drain size
- Maxx Vichey corner tub install question
- No vent or window in moldy bathroom
- Affordable Safe Step question
- Covering a rusty tub drain
- Tool for bath tub drain removal
- Thermostatic Valve sticks out too far...
- Restoring the bottom of a Pedestal tub
- Body Sprays - Does this "loop" work??!!
- old tub no shower, can i change the spout?
- New Tub Crack
- bath fan duct
- Installing plastic tub - mortar bed?
- redo pipes behind tub wall
- removing tub drain
- shower floor suggestions
- hot water vibrates
- Help me! BATHTUB WATER LEAKS after bath
- Kohler diverter leaks
- Diverters, Volume Controls, Thermostatic Valves!! Help!
- Frameless shower door enclosures
- Aqualine in my home
- How do you remove a bath tub?
- Leak from hot water tank
- Bathroom reno questions
- Kohler Faucet Replacement
- Handle replacement on compression faucet?
- Mortar to set bath tub?
- Cracks in acrylic shower stall
- Is it feasible to connect two hot water heaters to one fixture?
- 3/4" vs. 1/2"
- Where have all the metal fixtures gone?
- MIXET shower valves
- recommendation for a shut-off for showerhead that doesn't drip?
- Bath Tub Removal & Installation
- threaded shower drain
- Water pouring from tub spout during shower
- quick question- is caulking needed around replaced new tub fixtures?
- Converting Tub To Shower
- add a tub where there isn't one??
- Gerber 3 Handle Stem Seal Replacement
- Oatey Casper's shower drain
- Shower light installation
- Repair or replace Kohler shower handle/valve?
- Glued Pipe to Cast Iron?
- New Shower Leaks
- Shower Shocking Me
- Quick ? re PVC-Kerdi drain splicing through concrete
- Repair for tub surround and vinyl floor seam
- Is sealent needed with a polymer grout ( shower tile)????
- Replacing one-piece form-factor shower and tub
- Urgent Bathtub Removal Question...
- Shower Leak
- Leaning Bathtub of Death?
- Tere-Stone
- Replacing old tub with Sigma tub
- Intermittent Shower Leakage
- Only 59" for tub/shower unit?
- Improper Installation of a Steel Composite Tub?
- Hardiboard Installation
- Wobbly Tub Spout / Diverter
- Shower valve setup: Please help!...
- Shower pipes came unanchored
- Delta shower, hot=cold, cold=hot
- high pitched sound coming from pipes
- Acrylic 3-piece tub/shower.
- Converting 3 handle to 1 handle in shower/tub
- Problem changing bathtub drain plug
- How to leak test tub drain?
- Pics of my Shower
- Shower drain placement
- Shower arm installation
- Indentifying a shower valve
- shower body machine gun noise
- Shower Drain venting
- Bathtub install--finishing
- Stupid Bathtub drain question.....
- Whirlpool tub leaks ONLY while draining...IDEAS?
- tub suround instal
- Stub too short for tub spout!
- Slab shower drain
- shower over bath: type of bath ?
- Need help to identify shower stem valve
- Jacuzzi vs American Stand. vs Maxx Whirlpools
- Distance for Shower Drain from Vent
- Please Help - Moen 3330 Valve not working
- Still Diagnosing
- Plan on tub replacement w/ drop-in...maybe?
- Bathroom remodel
- low flow hot water in bathtub
- replaced Moen cartridge 1222B posi-temp, now temps all wrong
- Kerdi membrane question
- Drain installation in acrylic shower base
- clawfoot tub leg problems
- Thera Shower
- Durock or Hardi backer?
- Plumbing Body Jets
- soddering threaded fittings
- Tankless Water Heater
- no water to bathtub
- Water conditioner or softener?
- Central Faucet/Diverter Questions
- Ugly flow from tub spout
- shower madness!
- Please advise: fixing a hole in a fibreglass shower liner
- 50 year old 3 valve tube/shower faucet question
- Shower Valve Rough-In Question
- Rough-In Valve Install
- Upgrading shower valve for existing galv. piping
- kohler tub drain plug re-installation
- shower w/ concrete base leaking
- Shower Leaks
- Manhattan shower stall door
- Air coming up through the shower drain
- New Shower for basement remodel
- repair leaky hot tub faucet by shutoff at heater?
- Delta shower diverter
- Floor joist removal?
- bathtub drain overflow faceplate replacement
- Reglaze Fiberglass tubs??
- 2-inch trap between 2x8s?
- Fibreglass Shower pan ick!
- jacuzzi shower issue
- Hand held shower only placement
- Kohler Shower Escutcheons
- replacing bathtub cartridge
- shower pan making popping noise after shower
- reroute of pipe
