View Full Version : Shower & bathtub Forum
Pages :
7]
10
11
12
13
14
15
16
17
- Am I in trouble? Damaged floor under shower pan.
- Replacing tub and tile
- Bath tub replacement cost?
- Need Help!
- Drain in slab issues
- Delta 1400 Series shower faucet problem
- Symmons Temptrol System Removal
- new shower for upstairs 1/2 bath
- Installing universal tub spouts
- h/w pilot light not staying lit?
- Water pressure & supply line question
- gurgle and drip
- 2" Waste and Overflow for shower/footbath?
- Shower Valve stem?
- Installing a Shower Tower
- How to flush a Moen Positrol shower valve?
- Is CPVC Any Better Than Copper Or Steel In Cold Weather?
- Shower Drain and P-Trap
- Drip, Drip, Drip from my shower head
- Attaching steel tub to wall
- Noisy Acrylic Shower
- Bath faucet - plastic housing leaking, replacable?
- ripping a bath out, getting a shower cubicle installed , how much ??
- How to remove bathtub faucet handles?
- Help with shower valve identity - dripping
- Shower Massage Blues
- No Water == No Leak, right?
- shower diverter stem
- Weird Pressure Issue
- Replacement tub/shower unit?
- Help- got Minwax in tub
- Symmons Rough In
- my delta one handle shower faucet
- leaking Hudson Reed tub faucet
- water volume adjust for shower/bath faucets
- Delta 1700
- Shower Finishing
- shower drain flange replacement-help
- bathtub/shower diverter leaking!
- Vibrating shower pipes
- Valve Seat Removals
- installing a tub and a one piece surround...
- Help with shower decision please!
- Rust-colored water coming out of faucet
- Pipe noise from shower body?
- Need help - mobile home shower drain removal
- shower the valve turns on by it's self
- Removing whirlpool tub jets
- Swanstone Shower Base - Do They Flex
- replacing shower base
- Price Pfister faucets
- Mixet Madness
- Couldn't remove diverter stem
- bathtub no shower
- Cutting holes in ceramic tile, etc
- Installing ceramic tiles in tub/shower
- Considering
- Sterling/Kohler Shower Doors -Horrible experience
- installing new tub
- Drop In Tub
- shower and tub run at the same time
- New alcove tub - ledger or no ledger?
- Drop in Tub sizes
- installing shower kit on hardwood
- New bath in an unfinished basement
- Next bath project Question
- Bathtub drain leak brass rubber connection
- green board in ceiling???
- Looking for recommendations on a new tub
- Replaced valve stem washers--now NO WATER
- Drum Trap diaster
- Cast Iron Tub Installation
- bathtub faucet leaking in the wall
- Shower leak and knob questions
- my tub screw-up
- Help -tub rusting
- American Standard vs. Jacuzzi (?)
- no water
- Factory installed overflow?
- Removing a bathtub
- Bathtub requires leveling ?
- tub drain
- steel tub warpage
- low-profile tub drain?
- Re-Surface Fiberglass Tub/Shower 1piece Shell
- reusing antique overflow coverplate with new drain?
- Mortar under cast iron tub?
- how difficult is replacing this bathtub
- American Standard diverter valve problem
- Help with gurggling noise
- Plumbing for a new whirlpool corner tub
- Need a vent in the shower drain?
- Add Shower to 1/2 Bath / Laundry Room
- American Standard Bathtub Valve Removal
- Kohler faucet pressure balance problem
- Tub to Shower Conversion
- Shower Supply Question
- Notching Out A Fiberglass Tub
- Show pan installation
- Moen Restrictor
- Drain Stopper-Overflow Tower
- Shower Door "twisting"?
- Replacing old tub, need advice.
- Need to replace Shower mixing valve with separate cutoff valve for inputs.
- New shower valve only hot water
- Whirlpool tub installation
- Moen Cartridge Problem
- Code question for tub DWV, and another ?
- Shower mixer leak question
- Leaking pan - how to locate source?
- Tub to Shower - Venting Question
- Stop valve sizes for whirlpool tub and faucets
- Water Temperature?
- Insulating a noisy bathtub. How?
- Tiling a shower ceiling. Tips?
- Deleting Tub/Shower for New Shower
- Mass Drain Confusion
- Please help. What is this?
- Calculating floor load capacity
- New Moen Cartridge - Very Little hotwater
- Shower/tub vent
- Hand Shower Pressure
- shower floor
- beadboard in bathroom
- grout in tiled shower base stays wet
- Tuscany single handle won't shut off
- tub spout diverter problem
- corner shelf in shower
- ASSE 1016/1017 issue with bath hot water
- More tub to shower conversion
- New shower trim wallplate doesn't cover shower wall hole
- Omnigrip
- Swanstone Panels: Butting ends together on same wall
- faucet "off position"
- Basement Bathroom Addition
- shower/tub lower hot water pressure
- upstairs shower problem(s) molds & pan settling
- Hand Shower
- Hard to remove sleeves on shower faucet
- Bathroom remodel help needed please
- Swanstone Veritek fiberglass shower
- HELP - Washer Drain tie in to TUB Drain
- New bathtub installation worry!!!
- Installing new Kohler Tub
- shower,tub diverter problem
- shower supply question
- Dual Shower Examples?
- upstairs shower, cold water works fine, hot trickles
- Peerless shower System
- I need help in a hurry.
- Low Cold Water Pressure
- strainer drainer blixon, donner,rudolph!
- Help UFS Unidentified Faucet Stem
- Converted bathtub to standing shower
- Repair Cast Iron tub scratch?
- clunking noise from shower faucet
- reglaze tub in Seattle?
- Hot Water
- replacing surround w/std tub/tile maybe.
- Pre DIY Advice Please
- Shower Door Installation
- tub grab bar
- Price-Phister Shower Valve / hot=cold; cold=hot
- Help tonight, bathtub
- Curved Shower Rod
- Tub Blockout
- Caulking a drop-in tub
- Basement Shower Install
- Copper size for a new restroom/shower/toilet and sink
- Any suggestions and ideas
- No Water From Shower
- shower pipe to plumbing
- Price pfister 3-handle valve for rainshower?
- Plastic shower arm goes round 'n' round
- Leak in American Standard single-handle shower valve
- Jacuzzi Tub Pre-intallation testing ?
- Mainline tub faucet
- shower/tub not draining
- Tub DWV question
- problem removing delta faucet in bath
- Tub surround help.
- tile around tub
- Changing shower hardware
- Vapor barrier required???
- Mortar under tub question
- basement shower p trap
- Tailpice question
- Help with Hardibacker installation in bathroom
- delta to price pfister roman tub replacement
- Maybe a dumb question, but.........
- single-handle Aqualine shower handle
- Replace shower Plumbing Valve assembly shower head 2 knobs
- Replacing old shower pan with Swanstone
- Bathtub Issues
- New Delta install - Now leak at Shower Head
- upstairs bathroom drain/vent question
- crack in shower surround
- freestanding tubs
- Delta tub faucet
- 1/2" PEX supply lines to Moen Shower valve
- Bath Remodel: Tight Space Advice Needed
- Tub shoe drainer issue
- Old Style
- Steel, Fiberglass or Cast/Tub Replacement Questions
- rethread shower elbow
- Almico Whirlpool Tubs
- Pre-Fab Shower Crack
- size & location of tub access panel
- very little pressure from hot/cold to tub
- hot water shower handle
- Roll-in shower
- How to replace valve in Moen Posi-Temp?
- crane dial-ese replacement
- Removing Tub/Shower Escutcheon
- Two plumbing questions
- Ceramics and Durock
- shower valve problem
- Mortar under Shower
- Cutting swanstone
- Shower valve plaster ground depth.
- Shower drain pipe exposed
- fiberglass shower pan installation
- Bathroom Reno and Low pressure to sink
- Placing tub in 3 wall alcove
- black spots in bathtub
- tile underlay
- Multi-Shower Heads/Body Sprays
- Problems removing a bathtub spout
- Drain won't stay open
- Sealing a bath (keep bath full for ? hours)
- Problem with Delta 17 series shower valve
- Foam blocks under whirlpool tub
- Leak coming from bathtub
- Delta Monitor 1700 (1768) "Graves" tub/shwr valve
- Bathtub 3 Handle Faucets
- New floor under or around new toilet?
- Removing Shower Handles
- Replacing Bathroom Fan
- New product
- luke warm water at bath
- Questions about a mortar bed for Sterling Vikrell tub
- Older tub wall and plumbing help
- Backer Board only or on top of green board?
- Leaky tub faucet
- Toilet flange not level
- Am Std Bath drain leak...Help!
- Tub to Shower Conversion Hot/Cold Leads
- Trouble with new tub and old (formerly) drum trap drain
