View Full Version : Shower & bathtub Forum
Pages :
5]
10
11
12
13
14
15
16
17
- Standard Heights?
- Subfloor Question
- Changed my mind, need advice on tub wall surrounds.
- Harden Temptrol shower valaves
- Need advice on how to properly install floor drain in concrete slab!
- Leaky bath drain-getting annoyed
- Bedding Material
- Need Help Quick!!!
- new bathroom tie in
- Non-Sliding Tub Doors?
- Code Question - Shut off valves inside wall OK or not?
- Pegasus mixing valve for shower.
- body sprays: 1/2" or 3/4" loop?
- Shower installment
- Plumbing parts
- water flow rate
- 10 jet Aker/Maxx combo
- Is thermostatic (anti scald) valve required by code?
- How to install drywall up to tub edge.
- Moen Posi Temp Question
- Disadvantages to no shower access panel?
- Pressure balancing valve problem
- Shower stall
- Tileboard
- Heater for Whirlpool
- Tub strainer leaker-help
- Bathtubs: Vikrell vs Americast vs Acrylic vs ???
- Water Backup into Bathtub when using sink
- Opinions on comfort
- Bathtub Install Question
- Reglazing a fiberglass tub. Which technique lasts more? Better?
- Seeking advice before purchasing fancy shower system
- Need a good shower head
- Hot/Cold Reversed; Kohler Shower Valve
- bypass shower doors
- Tub choice - Sterling Vakrell or Lasco 2603-2p
- Installing a basement shower stall
- Anyone have experience with Mustee tub surrounds?
- Problems with my rough-in for my existing drain
- shower faucet leaks when shower head is on
- Installation of VIKRELL TUB and SHOWER
- small waterproof doors?
- Valley Diverter hard to turn
- Basement Bath Rough-in
- Grohe question
- Drop-in Whirlpool Tub install
- Stall Vent Question
- Floor heights...
- Life expectancy of fiberglass tub surrounds.
- ran into a problem when installing laminate floor in my bathroom help!!
- Changing shower faucet help
- repair external threads on shower spout
- All Elbows
- Stall Shower Drain Problems
- Low pressure or volume coming from symmons shower valve(S296x)
- water flowing from shower head without diverter pulled up
- question about waste drain for kohler tub
- Converting Shower Drain to Bath Drain
- Hot Shower Valve won't turn off
- Problem with broken tub spout
- ceramic shower tiles falling out
- Fixing a cold water leak from bathtub spout
- Water from behind spout when use shower diverter
- Installing an overflow drain in a new bath tub in a manufactured home
- Length of Pipe for Tub Spout?
- Cutting Pipe in Shower Base
- Braided vs. Copper supply
- Another waste drain question
- Shower Door track
- Overflow cover.
- Showerhead question...
- Bathtub drain not holding water.
- Delta Monitor Question
- Price Pfister remodel kit
- shower valves
- Drop in tub for the standard installation
- Undermount installation option???
- Rotting corner shower
- Duravit sink/Removing Pre-punched holes
- Floating existing bathroom tub/shower walls
- Low Pressure Shower Issue
- Advice on choosing faucets (clawfoot tub, shower and sinks to match)?
- Advice on plumbing tub/shower drain
- Tub Draining Slowly
- Bolt came loose on drain
- Water Entered Home Through P-Trap Hole in Slab
- Properly sizing hot water storage for shower and tub.
- Tub against pressure treated lumber
- Plenty of Pressure, but none in the shower
- Showerhead/faucet problem
- Tub Opinions / Recommendations?
- Polished Brass & Pitting
- Kohler Water Tiles
- attic shower p trap
- two handle vs single handle tub/shower
- converting stand up shower to bath and shower
- Running water creating sound?
- Moving Tub on Slab
- Good quality shower valve
- Replace tub with shower
- Semi Finished Pics
- Symmons Temptrol
- faucet(s) replacement question
- Tile Redi Shower Module
- Installing drain on fiberglass shower unit
- kohler tub and shower module question
- Water Pressure and Hot Water Heater Grounding
- shower drain cover corroded
- HELP, have a screw floating around in tub pipe, which is damaging the cartridge.
- Replacing tub faucet
- Recommendations on Sectional Shower?
- rainfall showerhead in sloped ceiling...
- Looking for a new 46" shower insert
- Price Pfister Flowmaster repair
- Maximum length of duct for bathroom fan
- Adding 'spa jets' to shower
- Rusty pipes
- shower faucet repair
- Water to both Wall and Ceiling heads
- Loose Faceplate Behind Tub Spout
- No hot water at tub/shower
- unfamiliar with shower water pipe/fittings
- Removing a whirlpool tub
- Shower Pressure Adjustment
- Fiberglass / Acrylic Shower Stall Drain Install?
- Shower valve with separate diverter valve question
- Shower water fluctuates?
- shower pan
- Basement Bathroom
- Depth to install??
- Shower diverter with no removeable seat
- Shower arm extender?
- embarrasingly cluless
- greenboard and hardiboard issues
- whirlppol bathtub question
- Shower problem, cant find answer anywhere!
- It's Alive
- Which Terrazzo Shower Base to buy?
- control plate
- How to re-install my tub faucet....? 1st post...be gentle
- ?ID Bath Faucet Type-Kohler, 1937? Stem?
- Need help repairing leaking Gerber faucet
- Help with changing shower fixture in a tiled shower
- Walk in Bathtub -- Recommendations?
- Hot water heater vs. Indirect water heater
- Bath remodel recommendations
- Gerber Valve Stem Seat is Stripped
- I cant remove the tub drain on my bathtub.
- Convert 2 handle to 1 handle shower/tub
- Center Drain tub
- Measuring for a new tub
- Which Shower Valve???
- Kohler Transfer Valve
- Tiling question
- Delta Faucet Spring and Seat Repair
- Tub Faucet Diverter Valve Leaks Despite Replacement
- WILL IT FIT!!! whirlpool in slab basement
- Tub drain & overflow kit
- Tub tiled on 2 wide sides and one narrow side?
- Hand-Held Shower Head
- shower drain
- which valve??
- Shower stall noise
- trip lever bath drain installation
- jetted bathtub not working
- Roman Tub Faucet Question
- PVC under the tub has broken . . .
- Grohe shower drip -- please help!!!
- Leaking Price Pfister 0X8 valve
- Roughing in Kohler 304 Shower Valve
- spout leaking into basement
- broken shower drain???
- What to do! Construction Shower Pan???
- shower valve
- Shower diverter that won't
- PHLEXICARE SHOWER WASTE PUMP connections
- overflow/stopper
- 3 Handle Shower Faucet Replacement
- Banging when shower is turned on
- Hot and Cold Reversed on Kohler Faucet?
- WARNING!! Lowe's Replacement Stems
- Horrid smell from the shower!!!
- removing the screw on a 3 handle shower faucet
- Moen/Delta
- Bathroom remodel questions for a newbie
- Drain length and hot water in toilet?
- Tub Drain
- Waste and overflow
- Water Temperature mystery
- Bathtub Refinishing and Tub Cutting for Handicap
- Question about the Symmons Temptrol Valve
- Does Kohler make oversize Escutcheons?
- Swanstone Neo Shower Floor & High Gloss Walls
- Drain removal 47 yr old bathtub
- American Standard diverter
- Delta Faucet Repair
- Odd Diverter Spout?
- Does diverter location matter?
- Tub Overflow with no way to mount cover
- Water coming out of shower head
- one piece verses a three or four piece shower/bath unit
- Shower Door Seal
- Shower/Bath - Are Kohler one piece units better than the Sterling mulit-piece units
- Tile Shower Drain Height
- minimal deck mount mixer
- can't get old drain out of tub...
- Tub P Trap Height
- Drop-in Jacuzzi situation
- Toilet and shower connection
- Corroded Tub Drain
- shower drain smells bad... plus...
- How to remove Sears shower diverter
- tiled roman tub mess
- Insulation & moisture barrier needed in SoCal?
- shower valve hard to close
- Extremely Tight Danco Stems - How to?
- HELP - My Shower Water Temp & Pressure....
- Soldering question for new shower faucet
- One piece fiberglass bath tub leaking to floor below
- Connection ABS drain directly to cast iron pipe
- Moen, Moen, moan . . .
- How much mortar base
- Shower Pan set in mortar
- knocking and shut offs...
- Old Crane Stopper Linkage -- Down the Drain?
- 1st leaky Shower, need help.
- frozen shower arm
- replaced 1964 shower/tub faucets,now shower water pressure down significantly
- Best Enameled Cast Iron Tub? TOTO?
- Replacing Basement shower with Bath (Drain problems)
- Help! leaking Shower on concrete slab
- "slip fit" spigot with an interupt is leaking past the o-ring and into the wall
- Building our FIRST custom showerpan...need ADVICE!!!
- Replacement Tub Questions
- Bath Fitters Acrylic Shower Unit
- What wall board surface under tile in shower?
- Geberit Integrated Cascading Tub Filler and Bath Waste/Overflow
- Grohesafe 35 253 Valve Install
- plumbing problems
- Tiled access doors
- Bathtub valve position
- cast iron shower drain
- replacetubforshower
- Common diverter problem with a twist
- Shower enclosure leak issue
- Shower - leaking water through wall tile?
- custom shower door jamb ideas
- Help! Replacing Cast Iron in 90 Year old house
- Bathroom tub/shower leaking into basement
- valve for shower/tub...
