View Full Version : Shower & bathtub Forum & Blog
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25
  1. Looking for discontinued shower valve trim
  2. Cost to Remodel 7 Ft x 8 Ft Hallway Bathroom (410 Cu Ft) -- only $22,000
  3. what is the best shower pan installation
  4. American Standard shower valve 0061 and 0073
  5. Help with Kohler Mistos Install
  6. Moen Faucet model
  7. How to get cast iron tub into alcove and can it sit on 3/4" plywood?
  8. Praying someone finds this helpful
  9. Additional knob/valve inside shower wall
  10. Toenail Anchoring of Swanstone Shower Pan and/or Kohler Cast Iron Tub
  11. Tub on subfloor?
  12. Drain Trip Lever with right-left movement
  13. Commercial Steam Shower Requirements - Perm Ratings
  14. Basement Bathtub, one piece, or cast with one piece surround, Brand preferences
  15. Bottom of shower drain broke out?
  16. Recommendations for the average intelligence tile setting homeowner: Shower edition
  17. shower to tub drain issue ( 1 1/2 to 2 p-trap)
  18. Black particles in bath hot water only
  19. Suggested Brands to replace 1977 American Standard BR Fixtures
  20. A very basic question about shower heads
  21. Need seriouse help with my diverter valve trim
  22. Seeking advice on used jacuzzi tub for new bathroom
  23. 1900"s crawfoot tub Mueller faucets
  24. Checking the date codes and testing your thin-set before using it. "The Idiot Test"
  25. Thermostatic valve - Only cold water, valve does not call for hot water
  26. Drop in frame for whirlpool
  27. Odd faucet stem help
  28. Double vanity plumbing options
  29. What size socket for Moen pushbutton diverter?
  30. american standard leaking shower cartridge.
  31. Drop-in surround
  32. Help Identifying This Tub Spout?
  33. Delta Thermostatic Shower Valve response time
  34. Pipes above my shower faucet
  35. Tub install queston.
  36. Curbless Shower
  37. Mystery shower valve?
  38. Hansgrohe handshower leaking. Correct vacuum breaker?
  39. Shower valve identification
  40. Problems with Americast Princeton tub
  41. Delta Faucet R10000-PX Universal MultiChoice Universal Rough-In Valve
  42. Help! My Sterling shower leaks!
  43. Price Pfister Roman Tub rough valve
  44. Kohler Roman tub faucet identification
  45. Help with Identifying Tub Faucet Brand/Model
  46. Pocket door hardware : What's hot and what's not - a look at some premium hardware...
  47. multi head shower rough-in?
  48. Can't pry off Grohe single handle!
  49. Need help identifying shower hardware
  50. Help identify 3 handle tub fixture from 1950s?
  51. Conversion of Instant tank-less gas water boiler to a tanked one !
  52. Removing Grohe Tub Faucet Handles
  53. What is this shower cartridge?
  54. Help! old shower valve, unknown design/manufacturer
  55. Moen tub cartridge?
  56. Moen DN8001CH handheld shower
  57. Installing new tub fixtures help please
  58. What type of shower valve do I have? Moen Posi-Temp
  59. Moen 1225
  60. Top Remoldeling Guides for 2012 - Houzz.com list
  61. Overflow gasket wrong taper for old tub
  62. does anyone know this shower valve?
  63. Anyone know this shower valve?
  64. Separate hot and cold water valves
  65. Help identify this shower valve, please
  66. Moen M Pact 3330 vs Hansgrohe Ibox
  67. Plaster Ground in the way
  68. Quality of Acrylux - any updates?
  69. determining valve model
  70. Drain and vent question
  71. Grohflex rough-in box but want to use 3 port diverter
  72. Just replaced Moen posi temp 1222 cartridge and it leaks
  73. Price Pfister Old Shower Tub Set
  74. Tuscany Navona shower with no cold water at all
  75. Hansgrohe PB shower valve (Brand New) passing cold water at valve full closed
  76. Proper Way To Level Sterling Accord Shower In Mobile Home
  77. Bath Overflow drain Gasket issue
  78. Leaking Shower Pan that has now stopped leaking
  79. Tub Drain and Floor Joist
  80. Kohler K-1348 Vigora System III Whirlpool Tub Issues with Neck/Back Jets Not Working
  81. Shower valve mystery
  82. Acrylic shower Base ( cold 36x60
  83. waterproofing under tub
  84. Delay before water turns on in stall shower
  85. Shower mixing valve
  86. Kohler k9132 Shower drain
  87. Non-centered drain and Kerdi system
  88. Bathroom remodel - "hybrid" tub with two nailing flanges and two formed sides?
  89. Clattering pipes shower
  90. Calling Delta Experts: Do I have a 1500 or 1700 Series Shower Faucet/Trim Kit?
  91. Need Advice for new shower Pan
  92. Bath tub advice
  93. Fittings for Shower arm
  94. Need help replacing leaky shower
  95. american standard mixing valve need skematic
  96. Kerdi Shower Question
  97. What barrier should I use between concrete slab and mortar pre-slope?
  98. Another Kerdi Shower Question or two...
  99. Moen Drop Ell Installation.
  100. Hardie Primer before installing Kerdi
  101. Oddly attached water pipes in tub/shower
  102. Dripping faucet - Barclay diverter old style spigot
  103. high pitch whining in shower
  104. Delta Shower Valve with Temperature Knob
  105. Cleaning off mineral deposits
  106. Vanity drain fittings for remodeled bathroom
  107. stuck tub stem seat- what size screw extractor to buy
  108. Most rationale approach to multiple showerheads, and bodysprays?
  109. Kohler Moxie Shower head. Music in your shower
  110. Tub Spout Pipe Type
  111. Single handle Grohe shower valve
  112. Help Identifying American Standard Shower Faucet
  113. Shower has weak stream, not sure what to do
  114. No cold water coming out of shower/tub
  115. shower mixing valve, metal or not?
  116. 1970's Delta single handle bath valve, springs, seats.........very confused......
  117. to clarify: Delta TPR type seat, is it the right one for the old valve?
  118. Do the springs in a Delta single lever unit have to be replaced if still good?
  119. This has turned into a mess.......can't tighten dome enough
  120. old faucet handles
  121. Cold Water Trickles out in Tub
  122. leaking tub spouts after power outage
  123. Kerdi Membrane VS Mapei Aqua Defense
  124. Steam Shower base options
  125. New Artos-Westover shower thermo valve - no hot water
  126. Drain Pipe Question for Oatey No-Calk Drain - Height, Stability, etc.
  127. Does this shower rough in look ok?
  128. Connecting water lines to a faucet with a non-tapered thread
  129. Delta R10000-UNBXHF Multichoice Universal Shower Only Valve Body
  130. Leveling a self leveling Jacuzzi
  131. Plumb between two fixed points
  132. Bathtub reccommendations?
  133. Shower-pipe to Shower-head adapter?
  134. Wye in bathtub overflow
  135. None Slip shower floor surface
  136. Above the Floor Rough Bathtub Support
  137. identify the brand?
  138. What's up with my shower drain?
  139. Question about wall mounted tub filler.
  140. Bathtub insulation?
  141. Repair PVC shower pan liner?
  142. Raise showerhead
  143. Shower Pan confusion stand up shower make over questions
  144. How to increase water pressure/flow in showerheads
  145. Quick question on leveling sub floor for Schluter Shower. Between plys or on top?
  146. Shower stall refresh process
  147. newbie tub (tile) install question
  148. 3/4 inch supply line to master bath, but 1/2 inch line at shower valve?
  149. Hey!!!! a new shower...
  150. what Brand faucet is this?
  151. Do I need a vapor barrier?
  152. Shower drain gasket is too large for 2" drain pipe, what to do?
  153. Please help identify this shower valve trim
  154. Grohe Allure Collection
  155. new moen shower valve won't shut fully off
  156. Shower pan base
  157. Help identifying a shower valve
  158. Vacuum breaker on hand held shower with dual check valve?
  159. Shower Drain Workaround
  160. Which heated floor? Suntouch of Flextherm, or other?
  161. Zero Threshold Doorless Shower with Trench Drain - what to use? Durable?
  162. No cold water in shower
  163. leaking tub
  164. looking for this part or conversion for it
  165. Shower valve question.
  166. Single handle shower water turns off after turning 180 degrees
  167. Hera Tile & Stone in San Jose, Ca.
  168. Subfloor
  169. Bath tub drain and overflow
  170. PEX in shower & whirlpool
  171. 54" tubs
  172. A new rough-in valve thats deeper than the old
  173. Need help with shower valve cartridge replacement
  174. How do I remove flange on shower valve
  175. Stubborn American Standard shower valve leak
  176. Kohler K-11748 Kohler Push button diverter Ever used/installed this? Vry few Reviews
  177. Insulation below Copper Bathtub
  178. Roman Tub hand held sprayer leak potential
  179. Help in selecting a window for a tiled INTERIOR shower wall.
  180. Shower Diverter in-wall valve question + Cartridge question
  181. Acrylic vs Enameled Steel bathtub
  182. Installing Ditra with Pre-Mixed Ardex AF 207 over wood subfloors
  183. Riobel iShower
  184. How to Clean & Sterilize "Whirlpool" style Tub Pipes and Jets ?
  185. Help identify this roman tub faucet hardware manufacturer please
  186. Problem adding shower to clawfoot
  187. HELP!!! I'm about to give up!! Need a 60x30 tub.
  188. PEX or PVC - which is more sensitive to caulks, flashings and sealants
  189. Replacing 1950s tub fixture -- advice on selection and installation
  190. Extra support for cast iron tub
  191. mini shower/toilet waterproof
  192. Help identifying bathroom faucet brand
  193. Jacuzzi Primo soaking tub vs. Sterling Ensemble?
  194. Shower and Handspray Valve
  195. Grohe 34126 thermostatic valve problem
  196. Structo lite for base of whirlpool
  197. Plumbing two new valves 1 head each into existing shower stall.
  198. Do Noble Niches Have The Bottom Shelf Slope Built Into Them?
  199. Faucets & Other Plumbing Parts at Big Box Stores
  200. Water Pressure to Shower Head in Tub/Shower is Low
  201. Shluter floor pan question.
  202. Adjust Temp on HJ-40 cartridge?
  203. Having issues with acrylic bathtubs - on my third tub and still problems
  204. Kerdi membrane install question.
  205. Water problem at tub.
  206. Help With Identifying Shower Valve Stem and Maker
  207. Can I hydro ban a schluter presloped shower pan? And other stuff.
  208. Can anyone identify this single handle shower cartridge?
  209. Please help identify shower diverter valve
  210. S-trapped on plumbing code
  211. Vibration when shower on
  212. Help, bad odour coming from shower drain
  213. Moen Roman Tub replacement cartridge
  214. 2 piece or 3 shower with surrond
  215. Tub surround question
  216. White, wax paper like residue in Moen cartridge
  217. "Temporary" Shower?
  218. Shower and Bath Same Wall
  219. FIBEROCK Tile Backerboard vs HardieBacker Cement Board
  220. Aquabrass Thermostatic Shower Adjustment HELP
  221. Removing Shower Drain Problem
  222. shower trim compatibility question
  223. Moen shower/tub valve leaking from stem when water is on
  224. Hansgrohe ThermoBalance II
  225. Hiring a bathroom renovation contractor - Top Ten Questions to ask!
  226. Tub drain location for p-trap under shoe.
  227. Grout
  228. Recognize this faucet?
  229. Searching for Alcove Tub Shower Compatible Enclosure Components
  230. Install Alcove Bathtub with no front skirt
  231. Laticrete thinsets
  232. American Standard transfer or diverter valve?
  233. 3 handle shower Diverter stem wont come off.
  234. tub drain thru joist layout
  235. Handling ground water in a basement shower - water in rough in location hole.
  236. Need help with a Price Pfister shower faucet.
  237. need help with Whirlpool tub
  238. Tile to Carpet Transition - A look at the best options for your home?
  239. Help finding product name and manufacturer for a newer "hidden" shower drain product
  240. Price Pfister diverter valve
  241. New tub -- under 300 bucks
  242. Gap between shower pan and studs
  243. Kohler Villager being used in a basement bath remodel, drain and trap in concrete
  244. Framing for an under mount tub installation
  245. Bathroom fan vent path when joists are parallel to wall?
  246. Advice for installing a shower base with an offset drain
  247. Free standing basin style bathtub with no access to connect drain tail pipe trap
  248. FREE Tile Council of North America Handbooks (TCNA)
  249. Need to replace one-piece fiberglass shower/tub unit
  250. My curbless steam shower project
