- a Kitchen into a Bathroom: Drain Question
- canada and showerstalls
- Shower Drain Issue
- Grohe Grohsafe 35015 Universal Pressure Balance Rough - In Valve
- Help!! Clawfoot Tub Wall Faucet Plumbing!
- How are ya'll attacking the ceiling
- what is rule of thumb for bathtub sliding door height?
- Minimum stud spacing for Delta/Pex shower controller??
- Need to Fill and Redrill Frameless Shower Door Mounting Holes
- Removing tile (and messed up toilet)
- Leaky Tub drain and rough fiberglass
- Showerhead stem stuck
- Thermostatic valve max temp
- Uneven fiberglass Tub
- Hard to turn shower hot and cold Kolher 1/4 turn valve stems
- Broken screw on overflow pipe
- Vintage Price Pfister Replacement Parts & How To Identify Model / Part?
- Hardibacker install around bath tub
- Mirolin Eleganza tub surround / Tucson
- Alcove tub tiling
- Kerdi and RedGuard?
- PVC shower pan liner causing me trouble - help?
- Shawn Oldenoff demonstrates the new tubs and showers
- Soft copper for shower line?
- Installing cement board behind my shower
- Kohler 401 Mixing Valve Cartridge Repair or Replace?
- Shower to tub conversion?
- Irregular grout
- Problem with Grohe Grohmix Thermo valve?
- Effectiveness of drain water heat recovery systems (power pipe)???
- Thermostatic shower system 1/2" enough or need 3/4"??
- Standyne shower single water control leak
- Hand Held Shower Head Jumps when water turned on
- Does a half bath in place of a shower adds value to the house?
- Type S Mortar bed for tub
- Can't remove bathtub shoe gasket
- Confused about requirements for frameless shower door & panel
- Bathtub Support / Leveling
- American Standard shower escutcheon trim
- New basement bathtub question
- Walk-in bathtub reversed drain
- Replacing tub/shower handle & cover plate
- Push Style Sink Stoppers - Which are the better brands?
- Hidden stub-out for shower drain?
- Key step to fix the Price Pfister bath diverter stem
- 2010 ADA Standards for Accessible Design - Bathroom and Shower Codes
- Home warranty blues- Leaking bathtub
- Shower and hand held 3/4 valve
- How to wire in volume control with the Thermasol steam shower control unit?
- No hot water in unused shower
- Key Step to fix TWO Price Pfister Bathtub Diverter Stems - Update 12-05-11
- Where does the P-trap go?
- Drain Volume
- Need advice on best way to redo drain for walk in shower
- Absolute Newbie wants to fix own Grohe 33 625 shower faucet - good idea? bad idea?
- which waterproofing system for new shower?
- AquaSource faucet = No water coming out
- shower stall drain - replace one part ?
- Fiberglass/acrylic tub cracked. any advice?
- Kohler Bathtub Faucet Installation
- installing new tub
- Kohler Shower Door Install question.
- Shower Panel-fittings question
- Old Shower Diverter
- Can I Use Any Thin Set With Kerdi? The ICC-ES Evaluation Report On Kerdi Says You Can
- Tub Spout extension???? Help!
- Guesstimate of tub replacement?
- Modifying Bathtub Drain and Overflow Kit
- Name this cartridge?
- Shower glass....to the ceiling or not!
- best hand-held shower head with good presuure...
- Still struggling to find shower leak:
- How much should the water level drop in a Kerdi Shower flood test?
- Chipped Shower tile --> What to do
- Mixet Cartridge Leaking
- Help - Tub / shower install 58.5" rough opening!!!
- shower only rough in valve
- Replacing a Delta 1300 series with a 1700 series
- What kind of faucet is this?
- bathtub liner problem
- How to Remove Temperature Handle on Delta Monitor
- shower mixing valves intentionally restricted?
- Crane (OEM) tub tap - H & C tabs - keep popping off!
- Kerdi Water Closet Kit - How to stop your toilet from scratching your floors.
- setting kohler acrylic tub
- 2" shower trap
- Mixing valve theory
- Mortar Cement for Fiberglass (Sterling Accord) Tub
- Shower caulk bubbling up -
- tub pipe drainage
- Bathroom Fixture Hunt
- Swanstone Fit Flow Drain
- Strange stopper in bathtub drain
- Another Shower drain to tub drain conversion
- tub spout nipple
- Mortar bed under 1-piece Aquaglass fiberglass tub/shower
- 20+ years Shower Valve
- Home-brew Linear Drain Cavity/Connection advice request
- Recommended shower install materials??
- Dare I put a wood window in a shower wet wall
- Gerber Single Lever Tub / Shower Combo
- Finishing Shower Insert
- Heat Recovery Unit for shower
- Bathroom upgrade - shower mixing valve question -
- Bad Faucet Seat
- How to move shower drain 2" without increasing the height of the drain
- What is the proper way on *stubbing* our plumbing RO
- drain for added bathtub - remodel
- Old shower floor missing grout
- Linear Shower Drains - Function and Style
- pressure balanced vs thermostatic valves (1/2 inch vs 3/4 inch)
- Tub drain and bath tub liner
- CBU above tub
- Hansgrohe Help!
- Identify Shower Valve
- leak checking new bathtub drains
- need to ID tub/shower valve...plz Price Pfister 0X8-310A
- Bathroom Remodeling - Inexpensive Vanitys
- Best brand/material for bathtub?
- Clogged Shower Trap creating big problems
- A curious newbie and a valve
- No-Barrier Shower Base/Receptor/Stall
- What is the best rain shower head?
- shower cartridge identification help
- Installing LASCO shower stall with Oatey No-Calk drain
- Installing a Shower Panel
- Drain Spout
- Stems replaced, shower still drips. Old American Standard stems.
- Cast Iron install in Vancouver
- Northern Michigan UNheated Cottage - Freeze Risk for WHIRLPOOL TUB??
- delta shower rough valve installation
- clawfoot tub width and drain location
- why did the plumber do this?
- Help identify tub valves and unstick the shower diverter
- Maax versus Americh
- replace or keep old shower pan ?
- Kohler Tub and Shower Facuet issues
- Moen shower valve moans
- Mysterious Shower leak
- Brass waste/overflow: Recommendations??
- Drain plumbing for Steam Shower
- Oatey "no-caulk" drain leaking in shower w/ acrylic pan
- Bathroom Remodel: Tub Drain and Plumbing Problems
- Delta shower valve repair
- custom sized tub??
- Archer tub by Kohler
- testing plumbing during shower remodel
- opinions on bath tub and basin stopper designs?
- basement shower drain
- Shower Bench Ideas - Using Glass and Light (LED) by Christa Young of TY Designs
- A Squeege worth posting
- Moen Shower-Tub Faucet Installed Wrong???
- Please help me with bathroom shower plumbing/layout questions!
- Need help with installing a new shower
- Need major help with Delta 3 way diverter and 3 way cartridge
- Need help id'ing and removing bath/shower cartridge
- Need help with new bathtub handles!
- Shower Drain Size and Code
- Tips to removing old Tub Faucet / Diverter
- Hot Water Heater Questions
- neo door part
- Overflow leak?
- HELP! What to do with cast iron(?) shower drain
- Total Gut - Shower advice needed
- What Shower Setup Do I Have??? (Pics)
- Replacement Drain Kit (non-standard??)
- Tub Spout Leaks When Shower In Use
- Complete bathroom remodel
- Temperature Control valve
- Miscut Shower Pan Liner - Can I Patch?
- How do I remove an old acrylic neo-angle shower (3 piece)?
- Wrong morter mix on pre pitch
- Very intermittent brief loss of shower pressure
- Unfinished Bathroom
- Hot water leaks from tub spout during showers
- Acrylic Shower Pan Installation (MAAX)
- Vikrell tub cracked today after 8 months
- what is the name of this item for shower?
- Quikcrete Sand/Topping Mix--should I add more sand?
- Commercial shower rod?
- Water pressure on shower - any way to measure?
- Pre slope and water leak test
- On off pushbutton for power to tub
- Type of insulation for new shower. Vapor barrier?
- What Brand is my Roman Faucet?
- How to remove ledge from Hydro Swirl jetted tub Model 7248 without breaking it?
- What Brand/Model is this Shower Handle? Price Pfister
- Re-Grouting a Stall Shower
- MOEN Bathtub faucet is leaking....not sure what to do
- Converting from tub to shower - Drain questions
- Kohler shower caukless adaptor tricks?
- tile shower stall leaking - seems to be grout help!
- How do I remove shower handle cap from this Price Pfister?
- Mystery shower valve, Price Pfister
- Should I use a wood post in this bath situation?
- Bolt-up shower drain?
- leaking bathtub on second floor
- nasty old rusting nails
- Symmons right hand diverter?
- Bathtub?
- New Tub?Shower Installation
- supply lines for new shower
- City of Palo Alto rejects any drywall in wet areas - suggestions for backing?
- We are tearing out old tub and tile surround.
- Preslope under cultured marble base?
- new tub, weird flange
- EBBE Square drain adapter kit for Insta-Set cast iron drain, for hot mopping?
- Shower Valves and Tankless water heater
- Americast Princeton Tub - leveling
- Problem with leaking bathtub sealing
- Thermostatic shower valves
- Acrylic Surround Compatibility
- Grout Sealing Question
- Schluter Kerdi Membrane Source?
- share your opinion on the best shower drain
- bathtub overflow configuration?
- Help for Kohler Valve Configuration for 3 showering Options?
- Stuck
- Please help us fix a stuck Kohler tub stopper and shower diverter
- calling John Bridge. Q for him?
- L or 90 degree shower curtain rods
- Pasco shower liner and preformed corners
- old faucet probably circa 1950
- "Leveling mud" for Kohler K-1978 shower receptor
- Hansgrohe Thermostatic Shower Cartridge
- Discussing tile methods
- Marks on tile from Regrout Job
- porcher reprise cartridge removal- diy or plumber?
- Parts for A-S Re Nu Shower Valve, model R1400?
- Fire Blocking (Fire Stopping) a tub in a Vancouver multi family apartment building
- Help required to fix an Economy Tub Filler with Handshower and missing leg pieces
- Installing mosaic tile with a linear drain - SICIS ( Colibri Mosaic Collection)
- How to install an undermount sink to your bathroom counter top.
- noisy tubs
- Wall-mount tub filler
- tub glass door recommends, trackless?
- Standing Water, Slow Drain in new tub install
- Grohe shower check valves
- Connecting your IPhone or Blackberry to your shower's sound system - Bluetooth WiFi
- Hot/Cold Reversed on Moen Single Handle Shower Knob
- ShowerHead and Body Jets Recommendations
- Roughing in Shower Valve w/ no Mounting
- reduce size of cutout in cultured marble shower to match new valve trim plate gasket
- Explanation of integral overflow on American Standard Princeton tub
- Shower valve / mixer recommendations
- preferred waterproof barrier for tile tub surround
- kerdi shower base with liquid waterproofing on the wall
- 1st time on Forum/Concrete in a Toilet Pipe
- Cold water on bath/shower is possessed!
- overflow cover was pulled away from the tub wall but screw still very tight
