View Full Version : Shower & bathtub Forum & Blog
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27
  1. shower temp mixing valve question
  2. Greenboard Okay For Tub Surround?
  3. replacing shower faucets and head
  4. Question about drop in tub installation in a 3 wall alcove.
  5. HELP!! Veritek pan with full frameless glass panel & door issue/question...
  6. Tub install question
  7. WHat should we do about our tub?
  8. Tub Surround Options for waterproofing.
  9. Shower Drain Horizontal Before Trap?
  10. Basement Shower Install
  11. Cracked Tub
  12. Short Bathtubs? (57")
  13. Shower Valve Supply Confusion - GPM/Rate of Flow
  14. Looking for a quality 66" x 32" tub to replace an old cast iron job. Ideas?
  15. passport ensemble jacuzzi tub
  16. Tuscany Brass anti scald pressure balance fixture.
  17. Need help Identifying faucet
  18. Need help in finding a Acrylic 60x32x15 Alacove bathtub..or do they make 15" height
  19. Should I get another Americast tub?
  20. Help! Need to update 1992 gold Delta 600 shower trim to polished nickel or chrome!!
  21. Crazy things that pass inspections.
  22. Delta and Tankless HWH Solutions
  23. Shower Make and Model ID
  24. Kohler Bancroft Bathtub Drain and Delta Bath/Shower Rough in Valve
  25. Does drinking water cause UTI'S"
  26. Replacement bathtub for 60x30 alcove
  27. tub drain linkage assembly not stopping water
  28. Evidence of moisture through the back of backer board
  29. new home buyer with a cracked tub
  30. Jacuzzi project...
  31. Fiberglass shower pan...install using no nails?
  32. Installing a Kohler Rite-Temp bath & shower valve, K-304
  33. New Shower - Leaking Drain?
  34. Grout or Caulk at Tile corners?
  35. How can I cut tile/cement board floor already installed?
  36. Aqua Source 10" Rainmaker 143600 Flow Rate?
  37. Old Alternative Methods Caveat - Old Plumbing Code (Custom Showers)
  38. No cold water in single valve shower!
  39. Moen handle problem!!
  40. Shower/tub diverter
  41. Convert shower to bath - tricky space
  42. Delta Select Cartridge or System ID HELP!!!
  43. Powers e700 series shower faucets?
  44. Access panel for Roman Tub Faucet?
  45. Advice for new construction bath/shower thermostatic valves & handles
  46. Basement Bathtub Question
  47. Turning my garden tub into a shower
  48. Grohe Shower fixture with diverter valve
  49. Bathtub replacement
  50. Schluter's Line Drain - A closer look at the new linear shower drain from Schluter
  51. This should be an easy Delta question for you guys!
  52. Delta RP17453 Single spout tub diverter
  53. Newbie Faucet Identification
  54. Master Bath Jacuzzi Tub Operation
  55. Drop-in Tub Overflow Interference Question
  56. lasco jacuzzi
  57. Deepest 30" tub?
  58. Shower lighting question?
  59. new trim for dated Delta 600 series Shower Fixture
  60. Building 2 curbless doorless showers, need advice
  61. Pocket Door Behind a Shower Wall
  62. A "quick setting thinset mortar" ok for bedding acrylic tub?
  63. Bathtub conundrum
  64. Leaky Tub Faucet + Low Shower Head Hot Water Pressure
  65. roughing in a clawfoot tub
  66. Repurposing a 3-way diverter valve
  67. Shower leak in wall - mold present, how bad? General repair advice?
  68. Installing Kohler Shower Drain Gasket
  69. Help needed to identify mixer cartridge
  70. Installing multiple fixtures in a loop
  71. American Standard Deep Soak Drain
  72. Newbie question: Grout or Caulk in shower stall
  73. Stem Removal Tool
  74. mobile home shower leak behind wall
  75. dangerous bathroom leak
  76. Bathroom Diverter nightmare....
  77. quick question for the pros from a rookie CBU what does that stand for?
  78. What would you put in your 'Forever House' under porcelain tile in your bathroom
  79. Delta Universal Shower/Tub Valve Body Rough-in : Capped tub nipple question
  80. Moisture in bathroom
  81. Which Brand for Ease of Installation: Shower/Bath Remodel
  82. Shower drain PVC pipe coating?
  83. Identify Shower Valve/Stem
  84. Orange Mold in a Schluter Systems Kerdi Shower - Linear Trench Drain
  85. American Standard shower handles: removal and ID
  86. Removing Grohe volume control extension on faucet handles
  87. Reliable Tub/Drain Overflow Units - Which brands are reliable
  88. Waste Overflow options & installation
  89. Which valves
  90. Trim options for a Moen 3372 valve diverter
  91. Preventing "Shower shock"
  92. Shower Valve Replacement for American Standard N 1130-1
  93. HELP Identifying a older Delta tub/shower faucet maybe 1988 timeframe
  94. Quick question about Hardiboard
  95. Help Me Choose Plumbing For My New Shower
  96. Sterling faucet need for tub
  97. Neo Angle Shower advice needed... Where to put shower head or 2 maybe? MASTER
  98. Long Shower hose needed
  99. offset shower pan connection.
  100. Fixing a leaking toilet - Kohler Saile K-3564 ( West Vancouver Repair )
  101. Drain leak from floor flex?
  102. Grout Cracking and Water Leaking into shower pan
  103. Seeking top quality multi-setting hand-held shower nozzle
  104. Anyone have or know the quality of an American Acrylic Bath tub?
  105. Variable flow volume control with a 2.5 GPM head
  106. Thermostatic valve operation; is the hot or the cold or both controlled?
  107. Fixing Kohler Bath and Shower Values
  108. Leaking Shower after Replacing Stems
  109. Clarion products?
  110. slim profile toilets
  111. Waltec / Flotrol diverter problem
  112. pfister 3 handle shower replacement
  113. Single person shower to double person shower
  114. Squeaky Hansgrohe shower valve
  115. Creaking Americast tub
  116. Aqualine Shower Knob Replacement
  117. Reversing tub drain- how much can I add to existing drain pipe?
  118. Tub Drain Hair Trap
  119. Help me identify this shower knob please
  120. Doan Bath Remodel
  121. Two piece tub/shower install in narrow room
  122. Bathtub installation -- order of installation (end pony wall, tub, heated floor)?
  123. Sayco shower leaking - cannot remove handles
  124. IAPMO Research and Testing - Certificate of Listing
  125. 3" Tub drain replacement
  126. Name of diverter manufacturer
  127. Bathtub/shower drip
  128. Troubleshooting two simultaneously failing old Grohe 35251 shower valves
  129. Shower Arm for 1950's House
  130. Is the Tub Steel or Cast Iron?
  131. New Soaker Tub Option/Drain Waste Concerns
  132. Insulation in ceiling between bathrooms?
  133. Shower Faucet Valve
  134. 1950s Crane Tub/Shower Problem
  135. Shower Spa water flow problem
  136. Is this a can of worms?
  137. Single lever shower faucet won't turn to the left.
  138. Replacing tub with shower stall
  139. Freestanding tub faucet connection advise
  140. Easy Question
  141. Kohler acrylic bathtubs- are they the same from HD vs. plumbing store?
  142. Drain removal question
  143. Shower faucet cartridge identification
  144. Waterproofing a free standing tub surround. A look at various waterproofing options.
  145. handheld shower with regular shower head
  146. Which shower raincan to get?
  147. Yet Another 3 Handle Tub/Shower Diverter Question
  148. shower faucet knob and handle are hard to turn
  149. Shower makeover
  150. drain and overflow hole size and compatability of tub waste /drain
  151. Odor in bathroom
  152. No water from my tub/shower
  153. Drywall or greenboard above shower stall?
  154. Can you help me identify shower handle valves before I smash my walls open?
  155. Rubber Gasket Around Tub
  156. Maax?? how good?
  157. Pebble shower floor
  158. Moen Posi-Temp 1222B Shower Cartridge
  159. Humming Noise from whirlpool tub
  160. Question about plumbing a Riobel thermostatic valve - Help!
  161. Help identify specific Delta model numbers for shower & tub
  162. Diverter spout leaks when water is off
  163. Water dribbles out of shower head when filling the tub with diverter down
  164. Bathtub Diverter Spout & Threaded Copper
  165. Shower handles
  166. wall leaking on other side of shower
  167. Gap at Tile/Tub
  168. Tiled shower leaking in basement
  169. Add bathtub - second floor remodel
  170. I hate caulking the tub!
  171. How to repair/replace this Delta stem?
  172. The best foam for under a bath tub.
  173. Americast Tub is making a crunching and squeaking noise
  174. custom shower
  175. Jetted Tub Installation
  176. Curved Shower rod installation on tile....
  177. Toto Toilet / Sink and Swanstone Veritek Bath
  178. Scald Protector
  179. Bathroom Reno - should I keep my old tub?
  180. Showerhead prssure is much lower after returning from vacation
  181. Shower/tub faucet hot water pressure
  182. Replacing Cast Iron Shower Drain / P-Trap & Replacing with ABS
  183. Custom shower pan question
  184. Shower Curb / Custom Shower Questions
  185. I just need a really good shower/hand held.
  186. Leaking Delta shower faucet
  187. Tub spout replacement recommendation and upkeep?
  188. Two 2" drains or One 3" drain
  189. multi-choice universal valve
  190. Americast Tub trapped water in floor?
  191. Zoey's 3 valve shower leaking
  192. Basement bathroom remodel; tub insulation, heating/cooling?
  193. Odd sized showerhead connector
  194. Tub/Shower Sliding Door Leak
  195. How do you disconnect Tub filler with diverter spout
  196. Walk in Showers - No Doors
  197. Running 2 shower heads in shower only can I just use tub out on delta?
  198. Elbow With Low Heel Inlet to connect Tub & Sepperate Shower
  199. New Tub Drains Slowly
  200. basement shower drain
  201. Cracked Cast Iron Stack or junction between toilet and shower
  202. Fitting new showerhead to odd-sized (old?) elbow
  203. Has anyone build tub enclosure for kohler 5-ft mendota cast iron bath tub?
  204. Shower Pan Leak
  205. shower bottom grout replacement
  206. What whites best match Kohler white?
  207. ErgonoMIX Concept - A revolutionary invention in the field of single handle mixer fau
  208. Shower w/ 3 divertor valves
  209. Help to Start Sanitary Business...
  210. Basement Bathroom - Shower Recommendations?
  211. showerhead on ball shower arm fell off - and can't find correct o-rings for it
  212. any help would be appreciated on Valley shower faucet
  213. Tile Tub/Shower Leak
  214. Shower Head wont fit on shower arm
  215. Frameless sliding glass doors leaking
  216. Shower drain grates
  217. Pop-Up Drain Assembly question
  218. Bathtub Big Trap is too low in basement ceiling
  219. Shower leak, identifying type
  220. Leak in 1958 shower enclosure:
  221. Maax vs Aquatic tubs and showers?
  222. Porcelain surface eaten up in bathtub...
  223. Help! Is shower trim wrong in all 3 bathrooms?!
  224. Delta monitor 17 series tub spout won't screw in adapter
  225. Does anyone know about the integrity of the Dreamline Shower Stall?
  226. Delta R1000 installation question.
  227. 1920's shower mixer - American Standard Re Nu ? B201 or B202
  228. Foot Lok Stop Tub Drain
  229. Elusive Shower Leak
  230. adjust flow rate on Symmons safetymix'ette' series II shower valve
  231. Stuck Tub Spout & Drain Flange
  232. Basement trap under bathtub
  233. Getting a standard 5" tub through RO
  234. Help for leaking shower valve - Model?
  235. Changing shower tub trim and need help! Powers 410 Hydroguard
  236. Bathtub Drain
  237. Install Tub Shower Combo without Tub Filler
  238. Schedule 40 pvc through basement concrete slab
  239. Delta Monitor Shower Valves and Takagi tankless heater problems
  240. Leaky shower faucet, drain that doesn't shut off and improvement in shower control
  241. plumbers grease in showerhead
  242. Looking for 1990's Delta Faucet Handle
  243. Removing Shower Stall Drain
  244. a Kitchen into a Bathroom: Drain Question
  245. canada and showerstalls
  246. Shower Drain Issue
  247. Grohe Grohsafe 35015 Universal Pressure Balance Rough - In Valve
  248. Help!! Clawfoot Tub Wall Faucet Plumbing!
  249. How are ya'll attacking the ceiling
  250. what is rule of thumb for bathtub sliding door height?
