View Full Version : Shower & bathtub Forum & Blog
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25
  1. A "While I'm In There..." Question
  2. adjusting the shower head angle
  3. Replacing Shower and Tub Valve Set - Questions
  4. Tub molding
  5. Broken Valve stems, need to replace! Help!
  6. Shower handles are m.i.a.
  7. A wet wall - too often wet from leaks in highrise apartments above me.
  8. Looking for good quality fiberglass/acrylic shower base and sliding doors
  9. Maximum number of shower heads on a inch and half plumbing drain line
  10. Trying to figure out who made shower trim/valve
  11. Best course of action (bathroom sink)
  12. Couple Tub Surround Questions
  13. Can anyone identify these faucets
  14. Tub Stopper ID
  15. Tub spigot
  16. Shower Doors Kohler vs Sterling
  17. Uggg...Leak around tub valve..
  18. shower head diverter valve
  19. What to put under my bathroom tile??
  20. What is the best kind of bathtub waste/overflow drain? So confused!!!
  21. Bath tub waste & overflow drain installation.
  22. Delta Multichoice univeral valve with stops
  23. Can anyone identify this?
  24. Replacing a Cast Iron tub drain.
  25. Looking to purchase a Delta 600 shower faucet unit
  26. Help finding replacement parts for Crane brand shower stems.
  27. Jacuzzi Water Rainbow fill spout and valves
  28. Duel shower heads
  29. pull and turn drain removal
  30. Time hot water takes to reach shower....
  31. Tub Drain Retrofit
  32. Replacing Valve Stem Question
  33. Kohler K-401 Valve questions
  34. bathroom remodel
  35. Bathroom vent fans and ducting
  36. More tub spigot questions...
  37. hot water tap issue
  38. A few questions before I get started on my Kerdi Shower
  39. Color match Jacuzzi Oyster
  40. Drain locations for channel drains
  41. Tile-In Bathtub
  42. Control mounted on bathtub to operate Jacuzzi motor
  43. Removing Shower Tiles
  44. New tub/shower trim and valve...now tub spout only drips...
  45. recs for shower heads?
  46. How to remove an Ann Sacks shower cartridge?
  47. Testing the overflow on your bathroom tub. A four year old saves the day!
  48. can't find this shower valve cartridge-see pics
  49. New bath tub with shower -- water flows off back ledge to the floor
  50. bathtub faucet help
  51. Shower Pan squeaks
  52. Low flow from hot water tub faucet
  53. Working on older shower
  54. Installing a new Moen 1220 cartridge
  55. Plumbing a new shower
  56. Inspector is requiring shower Isolation Valve...
  57. covering joint where sheet vinyl floor meets tiled shower curb
  58. Old Style Delta tub and shower valve?
  59. Shower valve that's easiest to install in block construction
  60. Hansgrohe temperature decrease
  61. Schon bathtubs & faucet
  62. Danco diverter stem problem
  63. Shower-only valve/faucet/trim
  64. Whirlpool tub - able to retrofit a heater of a floor model?
  65. Any ideas to fix rust spot on bathtub?
  66. Kerdi Drain Adapter
  67. Aqua Glass One Piece Tub
  68. Grohe Single-handle intermittent leak
  69. New bathroom reno fan leaking
  70. changing shower control valve
  71. Shower Valve Help
  72. Help identifying shower unit
  73. old mildew
  74. Delta 1400 series leak
  75. Tub drain leaking
  76. Installing New Bathtub
  77. Bathtub drain slip nut
  78. help identifying single handle mixing valve- no hot water
  79. Help Identify an older shower assy fom my childhood days for use in my current home?
  80. Shower diverter stem fell out
  81. Adding Shower to Existing Roman Tub set up...
  82. Shower Glass Block Wall
  83. How to turn a corner garden tub into a shower?
  84. Fiberglass Shower Drain Removal
  85. ID Help?
  86. Multiple Elbows on Spout Outlet
  87. Is American Standard "Americast" tub good?
  88. Preventing rust at holes in metal tubs
  89. How to remove or change old rotating shower head with wide connection?
  90. trouble with bathtub
  91. Need help to take this Price Pfister faucet apart
  92. Question About Removing Bathtub Skirt
  93. Help to find the brand single handle bath tub and shower faucet
  94. shower drain not flushed with tiles
  95. Shower pressure suddenly lower one day
  96. Anyone familiar with this drain setup?
  97. Possible shower pan leak in sunken tub/shower
  98. Sterling Accord Vikrell Tub - High Gloss? Is Sterling white really a light biscuit?
  99. Extend a shower drain with a snap-in strainer?
  100. height of shower stall...
  101. material for shower stall ceiling...
  102. Does Kohler build whirlpools in USA or abroad (Mexico)?
  103. is whirlpooltuboutlet.com a trusted site for whirlpool purchases?
  104. Is an in-line heater essential for a whirlpool?
  105. shower drain forSterling 48" shower surround
  106. Choosing the best Grout for your shower renovation
  107. Several questions on bathtub faucet replacement
  108. Flies from Bottom of Toilet...
  109. Shower stalls: Maxx, Sterling, Lasco, etc.
  110. delta diverter
  111. Dornbracht MEM Pressure balanced valve trim with integral diverter problem
  112. Jacuzzi Bathtub - Low Jet Pressure
  113. kohler seafoam green memoirs toilet
  114. How do I locate tub filler controls and spout at opposite ends of my soaking tub?
  115. how to level an EXISTING cast iron tub
  116. Mixing Kerdi and mortar beds in new shower
  117. Cast Iron Tub, Mortar bedding required?
  118. Bifold Shower Door For Stall Sized Shower 40.25" Wide
  119. hot water is missing
  120. Kohler DTV System
  121. Installing new whirlpool tub - test or mortar bed first?
  122. Installing Hot Soak Tub - access panel questions
  123. Question on installing a Signa Jacuzzi Soaker Tub
  124. Installing heated floor on plywood base
  125. tiling gap between backerboard and tub
  126. Need help to remove Kohler tub's lift and turn drain stopper
  127. Need to find a 6" OC shower tub valve replacement
  128. Shower valves run hot only in the last few degrees of rotation
  129. bathtub to shower conversion
  130. Copper pipe too short to install tub spout!
  131. Replacement for small bathtubs
  132. steam shower - steam generator recommendations
  133. Water backing up
  134. Looking for a good quality tub that's less than $400...
  135. Can You Identify this Faucet Brand? Price Pfister faucet with a "C" spout
  136. Comments - STERLING PLUMBING (KOHLER) ACCORD SEATED SHOWER STALL
  137. Water coming back up air valves in jetted bathtub?? Causing leak??/
  138. Moen Models? Posi-Temp
  139. A question about possible frozen pipes .....
  140. Valve ID Help, Peerless which was Delta's DTY line
  141. Help with Tub Purchase
  142. What suggestions on replacing basement bathtub shower?
  143. Jacuzzi whirlpool bath
  144. Woke up today, shower has only warm water, low pressure - all the other faucets fine
  145. Jado three handle tub/shower setup options
  146. Use of 1/4 inch Hardie backer board on tub surround
  147. tiled and heated shower
  148. senior tub replacement
  149. Fitting a 6' tub in a 5' bathroom?
  150. tile redi shower pans Current comments/opinions/ experiences
  151. Can vinyl sweep at bottom of glass door be replaced?
  152. Replacing very old tub spout
  153. Mixet valve crossover
  154. Which way is Faucet supposed to turn
  155. Help Removing Moen Part from Tub/Shower Valve (picture included)
  156. Question on Replacing Aquasource Shower Head Cartridge
  157. What clear silicone for around glass shower door do you recommend?
  158. Roman tub and wall shower compatibility - HELP!
  159. Vinyl glazing around glass piece that is "side light" to shower door
  160. Inconsistant hot water to one of two upstairs bathroom showers.
  161. Mildew inside shower handle
  162. Single lever shower valve leaking...through the metal !!!
  163. Exactly how much does "all" mean when removing old silicone
  164. Shower Heads & Switching between them
  165. Screws in shower drain
  166. Has anyone seen a corner tub installed like this
  167. What size surround for a 32 inch tub?
  168. Identify Shower/Tub Diverter and Stems
  169. Prefab Shower pans: Comments?
  170. Quick question on glass framed pivoting shower door hardware question
  171. Need to install waterless p trap from hepvo help
  172. Has anyone seen a tub installed like this?
  173. Pls Help Identify Shower/Tub Trim Model/Valve
  174. Recommendation for old cast iron tub
  175. What effects would pressure treated wood have on copper plumbing pipes - they touch!
  176. Please Help. Drain Installation for Tile Shower
  177. Need to caulk under-mount sink?
  178. Leaking bathtub
  179. Bathtub install floor height
  180. is there a market for a whirpool motor & in-line heater?
  181. Replacing shower head arm
  182. Safer: Electric Space Heater Or Bathroom Heater/Exhaust Vent
  183. Remove shower stall and install tub.
  184. clawfoot shower combo
  185. New shower pan on pre-sloped concrete
  186. Grohe Pressure Balancing Rough-In Valve
  187. Kerdi Wicking
  188. blue bath tub,wall, and shower curtain
  189. Need help with shower valve replacement
  190. tub spout - stange adapter
  191. Tile over tile in a shower
  192. Could my new pressure balance valve be reducing my water pressure?
  193. Caulking a 2-piece acrylic tub shower
  194. Bathtub handles spin - replace handles? Cartridges? Stems?
  195. Need to Replace Bathtub
  196. Bathtub made out of tile?
  197. New bathtub install in basement
  198. Basment Bathtub vent question
  199. low pressure from new valve/diverter
  200. Shower remodel
  201. 6 inch crackin new plastic tub
  202. Air jet Tub and Mortar Support?
  203. Ceiling tub filler
  204. Got a new water heater and now the shower is messed up
  205. Building a barrier free bathroom - AKW Tuff Form or Linear Shower Drain
  206. How to open Moentrol Balancing Spool?
  207. bathtub recommendations americast, bootzcast, acrylic, or cast iron
  208. Sewer backs up in my bathtub
  209. Leveling a Jacuzzi Tru-Level™ Shower Base
  210. Anyone bought anything from Tub Connection?
  211. hand held shower unit
  212. advice on fixing diverter valve
  213. Greasing the Grohe 47.050 cartridge for Grotherm 34.122 thermostatic shower valve
  214. Water coming out tub spout when supplied - whether on or off
  215. Can I update or replace this 20-year-old American Standard Shower/Tub Faucet?
  216. Are there any USA Cast Iron Tub Manufacturers
  217. Wiring for steam generator control
  218. FreeStyle Linear Drain Installation & shower pan prep, etc.
  219. Bathtub water is damaging adjacent wall
  220. Tub drain rusting out
  221. small puddle a big problem or a non problem?
  222. avoiding hanging concrete board and waterproofing a regular wall for a shower instead
  223. How to patch small holes in shower pan?
  224. Delta shower hammaring
  225. Frozen Toilet Pipes
  226. New tub for a 29X60 alcove
  227. Correct P-Trap From ShowerTub?
  228. What cfm vent fan?
  229. Newbie Tub Surround mess up
  230. P-trap in bathroom vanity
  231. Stupid Shower Question
  232. Two simple questions about threaded nipples
  233. New shower valve, no hot water?
  234. Bathtub hot water faucet - no water comes out
  235. tub p-trap, to replace or not?
  236. Shower/tub combo with a tiled apron
  237. Bathroom accessories and ready to tile niches
  238. moen shower problem
  239. Indentification of Tub Shower Faceplate and etc
  240. water diverter
  241. Removing and installing wall to wall tubs?
  242. Can mosaic tiles go on the floor?
  243. 1/2 " Kohler K-679 thermostatic valve good enough flow ?
  244. Common tub spout sealing question
  245. ID of tub/shower fixture
  246. Cracking noises from PVC pipes
  247. What tub did YOU install?
  248. Removing American Standard Shower Cartridge
  249. Sealing a tub drain flange
  250. Tub and Shower Fixture Configuration
