View Full Version : Shower & bathtub Forum
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. Need MORE help on my tub drain please
  2. Shower faucet drip a lot while showering
  3. Replacing a seat??
  4. Shower Problem
  5. Kohler Bath Drain Popup Stuck HELP :-(
  6. Shower/ tub leak
  7. tub and shower inserts
  8. Best way to level floor/tub?
  9. Balsa wood "Anti-flex" floor construction - Aker tub
  10. Bathtub Spigot Pipe Rusted to the Elbow
  11. small chip in acrylic tub
  12. Bathtub drain woes
  13. problem with shower
  14. Shower Valve Question
  15. Tub and shower drain
  16. Swanstone Shell Shower -- any opinions?
  17. Pressure balance on roman filler with hand shower?
  18. Sewer Gas
  19. Sweating shower valve with small leak
  20. Low pressure from shower head AND faucet!!
  21. iron cast bath tub
  22. Shower pan leakage???
  23. Shower drain mis-aligned
  24. Best bathtub
  25. Shower vent problem during bath remodel
  26. Kohler Diverter Question
  27. Moen Shower Cartridge Removal Tool
  28. Drain plan for new tub..pics
  29. Tub-Shower with Cap~Dome~Top Choice?
  30. Tub faucet still leaking
  31. Clawfoot Tub Pros and Cons?!
  32. Whirlpool tub install
  33. kohler "popup-less" tub
  34. Thermastatic vs. Pressure Balanced
  35. Shower pipe question
  36. Long, Deep, Narrow Whirlpool
  37. Looking for a certain kind of caulk.
  38. Need Suggestions to Repair Crack in Greenboard
  39. made stupid mistake!!!!!!!!!!!!!!!
  40. tub drain
  41. Tub leaks from around the drain. It caused adjoining wall to get soggy.
  42. ABS Compression fitting to Brass tub drain
  43. Meon or Delta Tub and Shower Faucet?
  44. Bathtub spigot
  45. Grohe 34.124 Rough-In Valve Installation
  46. Americast or cast iron tub?
  47. Need help on how to remove Shower pan drain.
  48. 1/8" backerboard gap? Really?
  49. Help! Question on bath remodel - tub sizing
  50. Shower drain and tee
  51. any idea????
  52. Removing tub spout and drain
  53. Gurgling Tub
  54. Shower restoration
  55. Does a 66" x 30" acrylic tub exist?
  56. Looking for a 46" Shower Base
  57. Shower Drain Location
  58. bath/shower combination
  59. Installing body jets in shower
  60. leaking shower
  61. Plumbing experts, I need your help on two faucets!
  62. Plastic tub overlay?
  63. pre-formed shower niches
  64. Old shower (30+ years?) valve replacement w/ pictures
  65. SouixChief hammer arresters?
  66. help,shower getrs cold and I still have hot water
  67. Flip-flopped body assembly
  68. slip fit diverter spout?
  69. Thermostatically controlled valve questions
  70. Fixed but not Solved
  71. Terrazzo Shower Base Installation
  72. Shower Base options ???
  73. Tile Shower Rookie
  74. Shower/Tub temperature
  75. Which MODEL shower valve???
  76. Shower Drain Dilemma
  77. Door for Kohler Sonata Shower
  78. disassemble a tub faucet
  79. Can crooked shower arm be straightened after tile?
  80. converting hot cold controls to single unit
  81. What is your favorite faucet?
  82. Oxygenics Shower Head anyone here ever use?
  83. Cast Iron Soaking Tub Recommendations
  84. I need wide caulk!
  85. Advice on replacing bathrub/tile with fiberglass
  86. shower base installation
  87. Pressure problem
  88. Bathtub mixing valve?
  89. Bathtub Comparison
  90. Please help my scalding skin!
  91. Please check the poll
  92. Installing pressure balance valve/system
  93. Simple bathtub faucet repair
  94. help cutting in a temporary shower
  95. pipe replacement question...
  96. what to use on new walls
  97. Delta Monitor Install...Need Help
  98. K-9132 Drain Assembly Install Question
  99. Shower from hell
  100. Reasonable size hole for putting in tub trap?
  101. Preferred Config. for Rough Valve Inlet/Outlet
  102. Tub shoe washer/gasket
  103. new shower head squeal
  104. ASAP! Disconecting waste drain
  105. Tub Spout Seal
  106. Shower head leak
  107. Another dumb ques.
  108. Bath Tub Drain Removal
  109. leaking between tub faucet and wall when shower is on - HELP pls!
  110. New drop in whirlpool CRACKING!!!!
  111. Hammer arrestor question
  112. Distance From Drain Pipe To Tile
  113. Surface mount shower control?
  114. drop in tub used as a shower too?
  115. NoMix Replacement for Mixet Valve
  116. 3 handle shower head configuation woes
  117. Shower Drain over Floor Joist
  118. Shower leak
  119. Diverter Valve Issues?
  120. 50's Tub Plumbing
  121. Another Hammer arrestor question
  122. Temptrol shower leak
  123. Grohmix Tub Shower Valve Problems
  124. Please help with faucet installation
  125. Installing Durock for Shower Wall
  126. New Shower Arm will not tighten
  127. Shower Pipe Installation
  128. moen stop/check valves
  129. Are deep bathtubs made anymore?
  130. installing existing bathtub?
  131. Bathtub & Tile Reglazing
  132. Change from 1/2 to 3/4 valve
  133. large diameter (7 inch ) escutcheon/shower faucet chrome plate
  134. Grohe Rainshower Shower Arm - Too Long- Where to Get Right Nipple?
  135. Bacteria or sewer smell
  136. Showerhead pipe faces up after remodel
  137. Replacing a "Mix-it" Cartridge
  138. Kohler shower faucet stem removal
  139. Shower floor cracked
  140. 2 shower heads
  141. The wall behind the tub.
  142. bath room wall fiber glass cleaner
  143. Replacing a DAL Shower head
  144. Leaking shower faucet
  145. Need Moen drain plug
  146. Glass Shower Enclosures
  147. Shower problem
  148. Americast or Vickrell or ???
  149. shower drain weephole cleaning?
  150. Swanstone Shower Pan Creaking
  151. can I plumb shower drain to cast iron soil myself?
  152. What could be the reason..
  153. Bathtub Enclosure for odd shaped tub
  154. Old Delta Shower Attachment
  155. master shower leak at one corner
  156. problems with kohler Rite-Temp shower valve
  157. oldest shower i've ever seen
  158. walkin shower/bathroom
  159. Leaky Shower
  160. Shower Stop-Check Valve Leaks at Screw
  161. Can I vent New bathroom vent into dryer vent line?
  162. basic tub question, but big help for me!
  163. lift bucket style drain won't stay closed
  164. Bath Tub/Shower Installation
  165. jetted tub install
  166. changing shower enclosure
  167. Our shower fixture looks good but doesn't work!
  168. old tub---what is this mechanism and how to fix?
  169. prob diagnosed, still need advice
  170. Repair or replace Swanstone tub wall?
  171. Tub spout question
  172. what is the max distance from p-trap to vent?
  173. Grohe Shower Valve Installation
  174. broken shower PVC drain pipe
  175. Need help with shower drain removal
  176. shower engages when filling tub.
  177. a very stuck tub spout
  178. Loose Moen fixture
  179. Slow drain, now no drain
  180. Shower has sewer gas when the water runs
  181. HELP! Can't get bathtub drain fixture removed
  182. building a tub enclosure on an unlevel floor
  183. Water dumping on floor - Uneven Tub?
  184. Does anyone have the same problem with hot water line?
  185. Does a drain come with bath hardware?
  186. Showerhead leak
  187. Low Water Flow into Tub
  188. Replacing old tub with new. How to?
  189. "Push button" bathtub drain
  190. Tearing out Fiberglass tub insert
  191. Fiberglass tub surround
  192. Spout Leak
  193. Sizing of Shower Nipples
  194. Question about fiberglass tub repair
  195. Drain for Jacuzzi Espree 6060 corner?
  196. Shower Diverter Stem Fell Out
  197. Faucet Handles will not come off
  198. Leaky tub drain
  199. valve seat is stuck
  200. Need hints on unscrewing Grohe nylon stem extension
  201. Replaced tub, building shifted
  202. Shower Drain & Pan Questions
  203. Shower Valve Size
  204. Shower Drain Too High
  205. how to deal with sloped tile flange in tub
  206. diverter valve vibrates
  207. changed mixet cartridge = low water pressure?
  208. Water backup in tubs and toilets when running washing machine, please help!!!
  209. Installation of new Tub/Shower Unit
  210. Trip drain lever doesn't stay up
  211. Problems with Installation of Fiberglass Shower Pan
  212. Plumbing Idiot
  213. Please help with my shower rebuild
  214. Brass Drain or Plastic?
  215. Tub Spout Installation Problem
  216. Leak in basement under tub
  217. outdoor shower
  218. glass block enclosure for tub
  219. Shower valve Question
  220. water not warm enough
  221. Mixet Hot/cold Reversed?
  222. Silicone Won't Stick
  223. Shower Spout/Diverter Removal
  224. Extension Kit for Trim?
  225. Jacuzzi Mixer Valve
  226. Shower Tub/Eclosure OK To Paint?
  227. Very little hot water pressure in stall shower...
  228. Tub Spourt with Front Diverter
  229. Replace Tub Drain without removing bathtub and without back access
  230. Wall placement around shower drain hole
  231. Identifying a Cast Iron Tub
  232. Is ABS the best to replace my galvanized DRAINS?
  233. Need help installing a new tub/shower faucet.
  234. Hole in Porcelain Tub Drain
  235. Refurbishing a cast iron tub
  236. a cludge!!!
  237. New shower install DWV questions
  238. Tub faucet and shower head location?
  239. Symmons Temptrol Model A Shower Valve
  240. need help regarding whirlpool faucet
  241. help with tub and shower faucet
  242. Symmons Temptrol Handle Removal ??
  243. ranell
  244. Owens/Corning 46" x 34" Shower Base
  245. OK to sweat a threaded valve connection?
  246. Is 1 1/2" drain pipe ok for shower drain? and 2nd floor P-trap question...
  247. Shower base
  248. Tub P-Trap
  249. flushing a tankless water heter
  250. Changing trim to whirlpool tub
