View Full Version : Shower & bathtub Forum
- Tile surround vs. Shower Walls
- BEFORE I buy new tub/shower trim - some questions
- pink cast iron bath tub - color changable?
- Please Help With Shower Surround ASAP !!
- Help! how to take off old Gopher tub Faucet handles
- Shower has hot but no cold water.
- Please identify the valve
- HELP !!! What Brand is this shower faucet ? Sayco?
- How to use single handle shower
- Sweat connections near Moen Exacttemp valves
- Can someone suggest a good shower valve and explain pressure balance vs thermostatic
- What do these Product features" mean?
- Need help finding the right Shower Valve Socket
- Water pressure issue in tub faucet
- Securing a freestanding faucet
- Moen Valve won't stop dripping
- How to take out Moen Single handle rotary shower.
- question about possible worn gasket behind bathtub overflow plate
- shower enclosure for clawfoot bathtub
- Pressure Dropped in shower head, not tub faucet
- Replacing shower valves
- how to get water out of copper pipe to solder it properly
- Need help finding a replacement shower/tub combo unit
- How to judge tightness of threaded connections
- How critical is valve to spout measurement?
- Replace/upgrade stem on old shower
- help with showerhead selection for angled wall mount
- Water flowing from Kohler Whirlpool Air Inlet
- Single Lever Shower Valve Ultra sensitive and difficult to adjust temperature
- Whirlpool bath problem
- Metal verses Non-Metalic tub spout
- Rough Plumbing-Bath to Shower Conversion HELP
- Which shower arm adaptor
- Grohe grohmix cartridge 47 025 - missing trim and handle, how is it adjusted???
- Is an above floor drain my only solution?
- Choices for a Shower Remodeling Plate
- Pressure Test required for steam line?
- Moen 94543 Diverter Removal
- shower and tub water at the same time
- Wet Room - Mounting Toilet Flange?
- Where to find 48"x48" double threshold acrylic shower base??
- Need urgent help with Grohtherm 3000 thermo fittings
- Shower pan drain removal help
- Glitch in Delta 17xx Shower control valve install
- Grohmix Shower valve not regulating temperature
- Glass Block advice
- Silicone for Sterling tub strainer?
- Getting strainer off Oatey shower drain
- Custom Size Shower Bases
- Sink vs Bath Tub valve question.
- how do I save the sink -- siliconed to laminate
- Bathtub Outlet Nozzle Too Short!
- modify bathtub only to shower/bath combo
- Shower Enclosure has hole in it, possible fix or have to replace
- Why I Think Americast Tubs Are Junk
- Faucets, Showerheads, and Aerators
- Steel Tubs - life span?
- caulking not holding
- Unstable shower pipe
- Delta 142913 - Problem: Water keep running even when its off
- Cultured Marble Shower Base Install
- Leaking Delta bathrub spout
- Raised outlet bathtub
- ‘wetroom’ shower by grinding down slab?
- Can you check my DWV rough-in?
- Grohe 34 126 Installation
- Roman Tub Faucets
- PermaHeat Bath Heater
- Fixing old grout w/ small bits chipped out - is there a wipe-on sealer/filler?
- 1/2" copper to 1/2" pex
- Help name old delta model
- Small bathroom blues
- Deck Mounted Hand Shower
- Whirlpool tub used with deck mount tub filler and hand shower
- Tub Shower Stem Interchangeability
- tub spout just spins - can't remove and leaks
- shower -- silicone or caulk recommended?
- looking for tub and surround
- Ideal Standard R1120 Rough Valve
- Keeney "Foot Lok" removal for cleaning
- shower stall faucet and door requirements
- Replacing Bathroom Drain Pipe
- Poor water pressure with new tub/shower set......HELP!
- American Standard shower faucet identification
- Tub Spout Not Flush
- Recommendation for a shower control valve
- covert three handler shower faucet to one handler
- New Laundry Vent
- Size of ledger for Kohler Villager cast iron tub?
- Adding holes in a Cast Iron Bathtub
- Leaking shower handle
- Tub Drain Not Watertight?
- Can anyone identify this shower cartridge?
- Toto Nexus and Trilogy High efficiency shower heads - your experience?
- Any ideas on how to maximize this shower configuration?
- help to id make/model
- Delta Monitor Leak
- Recirculating Shower
- sterling accord
- New Moen Banbury bath faucet drips
- Need advice: removing bathtub plunger
- Any problems with this bathroom layout?
- Whistling Tub Faucet
- Shower heads, water pressure and usage Question
- Kohler Hourglass 30
- Help find a replacement handle/faceplate for Price Pfister Shower Valve.
- If you could choose...
- tub spout
- (another) Seeking bathtub choice advice (thread)
- short tub drain
- Is SERIN Bathtub by American Standard comfortable?
- Which is better for shower surround? Durock or Hardibacker?
- glass block in shower area
- Do you want to Raindance?
- Replacing Moentrol shower control
- possible to dry behind shower tiles?
- Looking for "short" tub filler
- Old tile floor under new tub?
- Americast tubs summary
- Moen Vertical Spa
- converting from 2 handle to 1 handle...
- No hot water from Moen shower faucet
- Crane tup spout won't turn
- Speakman Lavatory faucet trouble identifying valve stem.
- Price Pfister brass acrylic 3 handle shower. Can it be replaced with original?
- Freestanding bubble tub
- Any leads on how to find this backer plate?
- Tub sizing advice
- Copper drain pipe for tub
- Danco Replacement 80993 Question
- Banging pipe in shower
- Looking for old Price Pfister single handle cartridge
- lasko vs aquaglass vs hamilton
- Moen A7250RB Drop Ell pipe nipple length
- Need help identifying a Roman faucet, Price Pfister
- Any reason not to paint over water resistant drywall in shower?
- How to Replace a Delta Pull Down Diverter Tub Spout.
- "hammer arrestors" on tub/shower mixing valve & a question about PP 0x8 valves
- Help with I.D. of this shower faucet, for parts?
- Best grout sealant?
- NO hot water
- Help: Hear toilet flushing and smell poo through shower.
- Steam Shower
- Sub floor sequencing
- two showers whinning (or loud hum) on startup, then stop
- 60x30 cast iron tub with apron?
- Need Help identifying cartridge
- Spa Shower pressure..question?
- bathtub refinishing
- tiling the ceiling
- Sterling Ensemble how much mortar?
- Advice / Suggestions needed for handheld shower bar offset.
- From wall to wall it's 58 1/2" - Is this a 60" tub?
- Is there a California building code stipulating minimum distance from tub to toilet?
- tub fill faucet on a vertical wall
- Can someone ID this valve and help me fix it? Danze 5020-57
- Tub Surround Remodel Question/Concerns
- In MA plumbing code, is there something called the "barrel test" for shower interior?
- Tub Drain removal ?
- Best Caulk for Preventing Mold and Mildew Growth
- 1/2 inch Hardibacker with no vapor barrier ... oops
- Bathtub comparison
- I'm thinking about this tub..
- Shower faucet without plaster ground
- Bathtub drain - relocating
- Is replacing the Shower Pan the only way?
- Shower head & Sink fixture recommendations?
- Replacemnt stems hard to find in California
- Can I tile and/or install a mortar bed directly over polystyrene (solid) insulation?
- How can I stop noisy shower pan?
- Where are all the pages for this forum?
- Shower stall reviews?
- leveling a tub
- Pop-up stopper for a 2" drain Ell
- Shower head flow restrictor blocks all flow??
- Trip Lever for 1940's tub
- Chinese fixed their pipe threader for shower arms
- Need info on bathtubs, please.
- Building New Shower Pans
- Price Pfister shower stall handle
- 'Glass shower stall and drain on slab floor
- Can anyone tell me what brand of trim is compatible with this diverter valve?
- Tub Drain Layout Opinions
- Rectangular shower rod help, please.
- Who is giving out this online advice? Are they a worker or a salesman.
- Anyone used Mauicast steel/porcelain finish/insulated for sound tub by Bootzcast?
- replacing Moen bath/shower trim
- Slip Nuts vs. Welded PVC
- Shower drain problem
- 58" Bathtub?
- Need to replace shower head mount for slide bar
- Shower panel with filter?
- Delta Monitor 1800 dripping
- moving cast iron tub
- Securing Oatey 42213 tile drain
- Help Temporary Fixing Low Spot in Fiberglass Shower
- drywall over old plaster
- Another basement tub drain question
- elizabthan cllassics toilets and pedestal sinks
- Moen Cartridge U-shaped Pin Question
- Shower drains slowly
- Please help with Kohler K304 shower valve
- pressure balance valves, flow rate and pipe diameters
- Cannot remove shower valve stem - no bonnet nut, only threads?
- Help with identity of 3 valve shower diverter system
- clawfoot tub water supply - flex?
- Standard Bathtub Spout does not fit
- Best caulking for acrylic shower base
- Shower recommendations
- Silicone Coulping to PVC Male Adapter?
- What is this?
- Confused By Diverter Valve Instructions
- Bathtub Replacement -- Go with Corner Tub or 54" Tub?
- Pressure-balancing Moen shower-tub valve releasing hot water in the "cold" position
- remodeling basement shower
- Another clawfoot faucet question
- problem screwing new handle onto Moentrol valve body / cartridge
- Diverter valve (3-valve system) not turning as many revolutions as it used to.
- Why is there a slab under my shower?
- ID roman tub faucet?
- Fixing a Veritek shower pan installed without mortar bed?
- Tub Spout Height
- Rough Plumbing for Delta multiple shower heads in Tub/Shower?
- Cast Iron, Acrylic, Americast or Bootzcast?
- How's my plumber doing?
- pressure balancing loop for 4 sprays
- ASTM D3309 - why was it withdrawn?
- Help! Please..we are out of town
- Downstairs apt bath water flow noise
- Old American Standard bathtub/shower faucet leaking
- Plug for testing the pan liner in the shower base??
- Stuck set screw in Moen shower faucet
- Bathtub faucet leaking
- Shower basin cast into a new slab?
- Are there alternatives for a Neo-Angle Corner Shower?
- Anyone used Gerber valves and trim kits for home baths/shower?
- bathtub faucet turns on by itself
- Design, connecting shower and washing machine drain to the same sewer pipe.
- Indian guy needs some advice
- Question about setting tub in mortar bed
- Dripping Shower Head when tub is being filled!
- Shower/Tub loses pressure as hot water temp increases
- Delta Three-Handled Faucet
- bth and shower
- Water supply and pressure with Kohler Rite Temp valve.
- Tub cleaner
- Need help identifying sink fixtures.
- Installing Glass Shower Door and Fixed Panel
- new bathroom and laundry room being done by contractor
