View Full Version : Shower & bathtub Forum & Blog
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27
  1. bath overflow
  2. Tub installation Help needed ASAP...
  3. Tub drain plunger broken off
  4. Water coming up from shower drain
  5. Just wondering, why is tub drain line smaller
  6. drop in tub deck
  7. Yet another shower drain issue ...
  8. leaky shower door with slate tile
  9. Tiling flange question
  10. Slipper/Clawfoot tub drain
  11. luke warm water
  12. Shower Remodel
  13. Adding a Shower to Roman Tub
  14. Master shower water does not heat up
  15. Bathtub's ledger edge length
  16. Only lukewarm water in tub and shower
  17. Americast Tub Question/Worries
  18. Help with tub shower install
  19. Thought I had my Moen fixed, and then. . .
  20. American Standard Diverter Problems
  21. American Standard Diverter Problems
  22. Moen Vertial SPA 243
  23. shower ceiling question
  24. Need help - lying plumber left me with a severely crippled system
  25. tub to shower
  26. New shower won't work.
  27. blocked hot water inlet on grohmix 34 434 thermostatic shower mixer
  28. vanity clearance
  29. caulking tub surround
  30. Bathroom reno. dilemma
  31. bathtub drain question
  32. Price Pfister series 8 Shower valve question
  33. Updating shower trim
  34. shower drain in basement
  35. Need Grohmix expert, temp prob
  36. Rough-in hand held layout/height
  37. Updating shower in basement
  38. Why The Dirt Under Bathtub?
  39. Hot water issue in master
  40. Re-route line to shower head?
  41. Toto bathtub - need help quick
  42. ADA Shower Remodel
  43. Another Delta Monitor 1500 Upgrade Question
  44. Help needed for 5 x 8 Bathroom Remodel
  45. Disconnecting outdoor plumbing?
  46. Handshower Wall Union Height??
  47. Showerhead problem this week
  48. shower arm ring thing
  49. Shower hose to deck mounted spout
  50. unseen tub leak
  51. Replacement Glass Shower stall seals
  52. plumbers putty on fiberglass/acrylic tub
  53. Shower valve shut-offs necessary?
  54. Shower master valve leaks
  55. Swanstone Shower Pan - Problems?
  56. Need tub shower surround
  57. Shower / Tub Selector Leak?
  58. Basement tub dap out question
  59. Help quick before I loose my tenant!!! Need a hot water solution fast!!
  60. Lasco 48ACTRI Alcove question Rough Opening
  61. shower faucet recommendation
  62. Is replacing a deck mounted tub spout easy?
  63. Does anybody know "American Standard" date code????
  64. Toilet relocation
  65. Shower Install -- How Downsize Existing Drain Hole Siize
  66. Water main is off but I still have a drip from my tub spout
  67. Drywall around shower walls question
  68. Repairing old greenboard and drywall shower wall
  69. tub drain questions and pic
  70. Need help identifying this faucet for a replacement
  71. symmons temptrol seat tools
  72. Tub Overflow Drain Issue
  73. Removing stuck handle from Moentrol Shower Body
  74. Cast Iron Shower Drain Disintegrated
  75. whirlool tub leak help!
  76. Threaded tub spout question
  77. shower drain question
  78. basement shower remodel
  79. attic addition draining
  80. Symmons Valves
  81. 1929 bath/shower controls - save them?
  82. bathtub and shower on one p-trap?
  83. Sterling Accord Installation
  84. Spa tub vent critical distance
  85. Soaker tub install
  86. Tiling around a Stering tub?
  87. Bathtub Drain Assembly Install When No Access?
  88. Moen Digital Valves
  89. A friend did an install.....
  90. Hansgrohe new Thermistor Cartridge - Serious Buzzing during mixing
  91. Offset Tub Overflow, Plus Narrow Tub
  92. shower pan question
  93. basement tub
  94. bath remodel curbless shower layout
  95. Moen Vertical Spa
  96. Kohler Stem Extension
  97. Should I caulk the back of a shower valve escutcheon?
  98. Shower valves
  99. Flooring strip along shower
  100. Looking for 2 person bath with shower.
  101. what to use, grout or concrete mortor or ???
  102. help with shower valve selection
  103. Handling A Heavy Terrazzo Shower Pan
  104. ASB Firenze Tub from Home Depot
  105. Pressure Balancing Loop
  106. Shower Valve Replacement
  107. help with dysfunctional shower...
  108. Question about shower base
  109. Copper pipe length into tub spout?
  110. Level a drop in tub
  111. SanSiro Tub
  112. need opinion of what to do on the wall above shower unit
  113. Replacing shower fixtures. Numerous questions
  114. How does drain assembly get mounted in vessel sink - pictures
  115. Help with bath/shower valve body
  116. Moen shower valve woes.
  117. Water hammer - faulty valve?
  118. setting shower receptor in concrete question
  119. Shower Diverter or Three Volume Controls?
  120. Opinions (good/bad) on Laurel Mountain or American Standard Air Tubs
  121. Dripping Delta single handle shower head
  122. Shower Suddenly Stopped Working
  123. Pedestal Bathtub Install
  124. Convert Slab Shower Stall to Level Floor for Steam Shower Unit
  125. leaking Moen shower valve installed about 1998
  126. stuck shower diverter stem, frozen, identify this?
  127. Replacement Delta 600 Series Valve
  128. Updating shower without destroying tile surround...help!
  129. leak in basement shower/tub
  130. Overflow drain--new bathtub
  131. Hardibacker and tile install questions - corners
  132. 60"x30" Alcove, tub options?
  133. PlumbersPutty--not for acrylic?
  134. Threaded Tub Spout Nipple
  135. Getting ready to install new tub-questions
  136. Removing shower handle
  137. Opinion on alcove extension (with illustration)
  138. Multiple Showerhead Question from Newbie
  139. Fire Hydrant Spa from Take a Shower is junk
  140. Question on installing tub drain kit
  141. Shower sometimes not hot
  142. Grohe diverter valve cover screw stripped
  143. Identifying Tub Shower cartridge, Source for the BNK7005
  144. Appropriate Backing for Shower
  145. Bathroom Exhaust Fan
  146. Shower arm extension?
  147. Grohe shower control cartridge
  148. Stumped Over Tub Drain Insert
  149. filtering showre head?
  150. What should I put under a one piece fiberglass shower?
  151. 3/4" supply to shower?
  152. Can I relocate the pump on my whirlpool tub?
  153. Tub valve leaking
  154. Radon
  155. Acrylic Tub - Wooden Base
  156. This may be a stupid question, but do I need to install shutoff valves for a shower?
  157. Moen "Shower only" no pressure problem
  158. New A/S cartridge leaks too. Could the problem be elsewhere?
  159. What's the bottom line on flow restriction for shower/bath tub
  160. Shower P-trap ontop of slab floor
  161. Basement Shower Remodel (with pictures)
  162. Tub Shoe Directly above Trap?
  163. Tub trap question
  164. What does a Twin Ell do that a tee cannot?
  165. Tub spout moves, doesn't seem secure...
  166. Enlarging my shower
  167. Bathtub plug frozen in place!!!
  168. Start-up for new shower install in basement, Square hole is cement floor. Do I close
  169. Problems with Kohler 304-KS-NA Bath and shower Rite-Temp Valve with stops
  170. Mounting Delta body sprays & wall mount shower spray on Sterling Accord tub wall
  171. Delta bath/shower valves "with stops". Not sure if I need "with stops" or not
  172. Temperature Settings on Moen Single Handle Tub/Shower Faucet
  173. Best shower valve--ranking companies from high to low
  174. Canada shower question--just wondering
  175. Leaking drain in fiberglass shower
  176. Trim and Stem Question
  177. shower drain question
  178. Best Soaker Tub
  179. American Standard Aquarian Shower Faucet ID / Trim replacement?
  180. Watco tub drains
  181. shower drain question
  182. New drain post/question
  183. Remove old Tub shower and add a new one
  184. Re-Using a Rough-In Valve
  185. Hardiebacker vs Greenboard
  186. Please Help ID Tub Stem
  187. Tile morter removal
  188. Shower valve and head/spout on opposite walls?
  189. Settting option for preformed shower pan
  190. Fiberglass shower base with compression drain
  191. retrofit shower floor questions
  192. New Tub & Drain Assembly
  193. Shower handle stem broken.
  194. What do I do with this old bathtub?!
  195. Tub and Shower Recommendations
  196. How much water can flow down a 2" pipe?
  197. Shower divertor mounted on interior of outside wall
  198. 2nd floor shower drain water level?
  199. Repairing a Delta Shower Faucet
  200. Draining 10 Gallons per minute
  201. Please help identify this classic fixture/setup
  202. Shower in the 2nd bathroom
  203. Wally's Steam Shower Bathroom Remodel
  204. Help understanding this shower setup
  205. Choosing the right pipe size for Dornbracht shower fixtures.
  206. When to convert from 2" to 1.5"
  207. speakman bathroom faucet
  208. Ondine Body spray head removal
  209. Thermobalance III with Kohler Handshower - vacuum breaker or check valve?
  210. Installing Kohler sliding glass shower door:
  211. steam shower units
  212. Jaclo: Any opinions or experience with Jaclo
  213. is hot bath tub popular in England or Germany and france ?
  214. Sterling Ensemble Shower -- A Few Questions
  215. Ledger board for a Cast iron tub?
  216. Acrylic Tub Drain Question
  217. shower diverter stem leaking - no biggie or repair needed?
  218. Rough-in for small bath
  219. Nickel parts for Moen Chateau 6990 Roman Tub Trim
  220. Replacement for American Standard Neo Angle Tub
  221. Installing Cultured Marble for a tub wall
  222. Rust in bathtub water, precursor to trouble?
  223. Cant get Kohler to change from bath to shower
  224. Concealed connections for a free standing tub
  225. Shower head flows whether tub spout diverter on or off - please help
  226. removing !&*#@$ shower handle
  227. New Body Spray Drips
  228. Replace drain basket in bathtub
  229. Sterling Accord Seams
  230. Best / Better Pop Up Drains
  231. what kinda wrench would help?
  232. Tub Drains -Trip Lever, Pop Up , Lift and Turn
  233. wedi vs kerdi system
  234. How to maneuver a deep tub into a tight space
  235. Need help identifying a Moen 1200 shower valve/cartridge
  236. Budget tub shopping questions.
  237. To Kohler (faucets) or not to Kohler...
  238. Water leaking from behind wall. Please help.
  239. Need good quality shower stall
  240. Drain slants and skirt is slightly bowed
  241. AquaSource Shower - How Does 'Flow Control' Cartridge Gear Inside Handle Adjust?
  242. Cracked Shower Top Fitting
  243. Moen Vertical Spa, when to change pipe diameter in multi-head shower
  244. Prefab shower drain installation - slab on grade
  245. Tile surround vs. Shower Walls
  246. BEFORE I buy new tub/shower trim - some questions
  247. pink cast iron bath tub - color changable?
  248. Please Help With Shower Surround ASAP !!
  249. Help! how to take off old Gopher tub Faucet handles
  250. Shower has hot but no cold water.
