View Full Version : Shower & bathtub Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17
  1. setting deck height for deck mount tub fixture
  2. Crooked plumbing
  3. Extending shower drain barell
  4. replacing galvanized pipes??
  5. Seamless Shower Stall
  6. Help with shower remodel
  7. How to define a slow drain.
  8. Old shower / compression faucet leak?
  9. HELP! Major price differences in remodel quotes
  10. Anyone know how to fix this drain stop
  11. Mustee shower pan
  12. Shower pan install - over plywood or tile?
  13. Shower pressure low
  14. clearence in front of tub
  15. Shower head drips, even with diverter open
  16. Valve for knob lever compatible with rotating handle?
  17. Cartridge for single handle Am.Std
  18. Valve Replacement Help for a Fiberglass Shower Kit
  19. shower faucet back flow problem?
  20. Tension In Copper Tubing
  21. Very little cold water coming out of shower.
  22. Crack in Fiberglass Tub
  23. Grohe diverter problem
  24. Tust around tub flange/drain
  25. shower leak in condo - who to call and help?
  26. Removing Shower Tile Cleanly
  27. Shower Pressure
  28. Union brand bathtub faucet?
  29. Jacuzzi tub faucet mounting
  30. Rusting behind caulk on outside seam of tub
  31. 1 3/4" bathtub drain
  32. I need help with a bathtub/shower faucet.
  33. Light fixture above the shower
  34. Crack in Shower Wall
  35. Caulking question
  36. shower remodel - old shower supply is PVC/replace with CPVC
  37. Mystery Mixing Valve---can anyone identify?
  38. Pulsing dribble from tub spout??????????
  39. Mysterious Shower Leak
  40. kolher tub tile edge and finish
  41. Handle Replacement options
  42. Shower Faucet Control Valve positioning
  43. Shower drain modification
  44. Avoiding an S-TRAP
  45. how do i remove this price pfister handle?
  46. Instruction sheet
  47. Broken drain lever
  48. kenmore clothes dryer does not run
  49. 3 peice shower surround
  50. Steam shower Construction
  51. Replacing Trim and using old Moen Valve
  52. Intermittent low shower pressure after installing new mixer
  53. Help with Kohler lift and turn tub drain
  54. Bath/shower faucet cant' be installed on centerline
  55. New Upstairs tub installation
  56. Installing new tub??
  57. Low Shower Flow but good pressure ?
  58. Please recommend a quality replacement diverter spout
  59. 1 11/16 bathtub drain
  60. Tub Repair
  61. Replacing Rubber Gasket
  62. Moen to Price Pfister
  63. 1980 Delta Single Handle Shower Leak
  64. Tub drain shoe leak
  65. Pegasus Pressure Balance Valve
  66. sliding clawfoot tub
  67. Lead tub drain
  68. Wish I'd known this...
  69. Bath fan:PVC ductwork?
  70. wet walls
  71. Rust around overflow hole in tub
  72. Frameless Shower Enclosure
  73. Changing Moen Bath faucets
  74. Solvent weld tub drains
  75. can the shower valve be in a different place?
  76. RedGard before tiling?
  77. Shower Diverter on Valve Trim or Spout?
  78. Rusty water from new handshower installation
  79. Shower Valve Recommendations
  80. AFD tub better for 2x8 joists?
  81. crooked tub spout
  82. Frameless shower kit w/ tile walls
  83. No hot water on second floor
  84. 'old' tub spout adaptor?
  85. Alcove stud wall coverings not covered by surround?
  86. Bathtub faucet drip
  87. Pfister Water Running
  88. Hot/Cold Reversed
  89. tub help
  90. choosing a the right tub
  91. LaToscana Morgana faucets
  92. Grohe rough-in valve, but shower head only
  93. help needed with grohe wax cartridge install
  94. Kohler or American Standard Bathtub?
  95. Tub/shower options
  96. shower pan creaks
  97. Rotted studs
  98. Pipe Hammering - How Should I Fix?
  99. Leaning Tub
  100. Schluter-Kerdi shower install needed
  101. Help with tub conversion...
  102. Bathroom Drywall
  103. Can't find the leak source
  104. Leak in KWC Shower Rough valve
  105. A tiny bit of rust in a new CI tub
  106. bathroom fan
  107. Oval Plastic Overflow Cover for Am Std Tub
  108. Which rough-in valve?
  109. Refinish Fiberglass Spa Tub
  110. Duct tape inside faucet cartridge and faucet ID
  111. HELP shower pan leak
  112. Mansfield and Mirolin color match
  113. GROHE - Thermostatic Valve Layout - help?
  114. Shower & Toilet Flush - Pressure Question
  115. Need advice on caluking shower enclosure.
  116. Other options for whirlpool surround?
  117. Stumped! What is it?
  118. Tub install question.....
  119. American Standard Diverter Removal
  120. Water in corner
  121. Tile or Glass Block First?
  122. Tub replacement with 'dropin' water jet tub
  123. Installing Delta drain, help!
  124. need shower parts
  125. Questions about travertine
  126. walk-in bathtubs
  127. Need Advice on Shower Faucet
  128. Need advice on installing tub faucets
  129. Tub overflow/drain?
  130. Which is better -single shower or separate valves?
  131. Tub creek/noise
  132. Help! My remodel tub surround popped apart!
  133. Single handle shoer/tub faucet no hot water
  134. Acrylic tub-shower, why or why not?
  135. Clawfoot tub refinish
  136. Removing silicone screw up.
  137. Caulk or grout?
  138. Finding part number for 1991 Grohe Metro E cartridge
  139. new tub and shower faucet rough-in
  140. Old Delta Faucet
  141. How can I increase the temp of my Mix-it valve.
  142. Kohler K-304
  143. Hot water pressure lowers when another faucet opens.
  144. Hot water question
  145. broken drain lever redux
  146. Need help with tub drain please
  147. Shower Plumbing Question
  148. partially blocked hot water to shower
  149. Sealing the tub deck
  150. Waste Drain assembly for Clawfoot Tub
  151. How to remove shower valve stem?
  152. American Standard Mod. 2425 L Install
  153. Shower - drain smell and stain
  154. turning off water requires careful "tuning" of the faucet
  155. Tub deck clearance....
  156. Cast Iron & Galvanized Pipe Rusted Connection
  157. Oooops on shower tile and shower faucet install
  158. Shower Drain
  159. Yet another Showerhead post
  160. Issue with the Installation of a Price Pfister shower valve body
  161. Can't remove "bonnet" to replace cartridge!
  162. help converting leaking delta 1500 to newer 1700
  163. bathroom faucet and kitchen faucet have low pressure
  164. Kohler Tub Spout Shower Diverter Leaks
  165. Shower/tub temp. not hot enough
  166. Valves & Fixtures
  167. Tub Diverter Rough-In Question
  168. Anyone ever seen a warped Americast tub?
  169. Problem with lukewarm temp on Pegasus 1/4 turn 1 handle shower/tub
  170. Problem with Eljer 3 Knob Shower Controls
  171. Can't find drain under tile for a planned bathroom
  172. single, moen; not getting hot water!!! plz help
  173. Nibco Stem for washroom tub
  174. Moen Kingsley Rough in valve
  175. Pex Plumbling
  176. Building a shower pan
  177. unremovable bathtub handles
  178. Extra part?
  179. Tub drain plunger jammed! Helpful ideas?
  180. Need help with crane single-handle bathtub faucet
  181. Need some advice on replacing a "shower kit"
  182. Does entire shower stud wall need to be pressure treated?
  183. Missing Part for Grohe 34-436 Thermostat Shower Valve
  184. Very slow drip...must I do something?
  185. Old Am Std Tub/Shower Valve
  186. need some garden tub plug removal help
  187. Can a water trap be replaced without tearing up the entire tile floor?
  188. Jetted tub shooting water
  189. Handshower/Shower Head Recommendations
  190. Frameless Shower Walls - Header Question
  191. Wall Saturated
  192. slow shower drain
  193. low hot water pressure
  194. First time taking a bath in the tub and they leak!! ....
  195. Bathtub/Shower Faucet leaks, getting bad
  196. bathtub spout leaks
  197. HELP - Broken Pipe Under Tile
  198. HELP - Broken Pipe Under Tile
  199. Shower Cold/Lukewarm - Sink Hot?
  200. New Tub Drain Slurping
  201. Building a shower ??
  202. Broke the shower pipe changing the head
  203. Old three-handle faucet
  204. simple shower rough-in question
  205. Handheld Shower/diff manufacturer valve and Trim
  206. Urgent - No Water - Moen Cartridge Stuck
  207. Hansgrohe Handheld setup
  208. Bad Sterling Mixing Valve in Shower
  209. Grohe Geneva Thermostat not hot enough
  210. A Waterless Tub!
  211. Can't remove trim from Kohler shower faucet
  212. Help! How much damage did I do?
  213. Delta shower valve leak
  214. Help! Leaky Grohe Model 34-436
  215. Steam shower unit suggestions, Wasauna?
  216. Shower Help! PLEASE!!
  217. Need to boost pressure
  218. help repairing shower valves
  219. Cracks in shower
  220. Removing fiberglass one piece shower and replacing with something.
  221. URINE smell in shower!
  222. Leaking shower
  223. INSIDE wall of tub/shower enclosure leaks
  224. Special Tub Overflow part - What's it called?
  225. Valley Shower Handle Cartridge
  226. Shower Faucet Identification
  227. Shower Faucet Seat
  228. Which tub/shower to install
  229. Alcove tub rough in
  230. old shower drain (circa 1975)
  231. 3 ways shower diverter- Latoscana by Paini?
  232. Help Please-BY Pass Shower Door Manufacturers
  233. Stuck trying to fix a shower faucet handle/valve
  234. how to level floor for bathtub install
  235. salamander pump please help!
  236. Clawfoot tub-feet falling off
  237. Cutting drain pipe for new shower
  238. Leaking Shower Drain
  239. Id this valve please?
  240. Can I use a PVC j-bend to galvanized?
  241. Shower Valve Recommendation
  242. GE Silicone, PolySeamSeal, or Polyurethane Caulk for Tub Surround?
  243. Fiberglass Tub Shower Combo
  244. Mixit bath
  245. New bath- slow tub drain
  246. Plumbing for shower with two heads
  247. Plumbing Kohler water tile body sprays
  248. Tub drains slowly when full and stopper closed
  249. Symmons temptrol shower valve problem - hard to turn hadle
  250. rough in
