View Full Version : Shower & bathtub Forum
Pages :
10
11
12
13]
14
15
16
17
- Pegasus 700-481
- Help With Shower and Tub Drain/Vent
- Fiberglass tub/stall problems
- 1948 parts - Help!
- price pfisher shower valve
- Need help today
- Leaking Shower
- repack double handle mongrel shower valves
- Replaced Moen shower cartidge... still leaking
- Concrete around ptrap to complete tub install
- Grohe shower volume valves & levers
- Access Panel. New Shower Valves
- Vacuum breaker on deck mount hand held shower
- price pfisher shower head
- Drain won't seal to Tub
- Difficult to turn shower handle
- 2 shower heads that drip
- Need to Rough in Shower Drain in Preexisting Joist Frame
- Need help with shower valve cartridge replacement
- New shower install questions
- Installing jacuzzi 6060 whirlpool bath
- Moving tub drain
- Tub drain moving
- Shower arm broke off..nut stripped?
- Porcelain Tile cleaner
- Repair leaking Delta shower valve
- American Standard Cadet Model 1674/1675
- Delta cartridge problems
- small tub
- Non Standard Shower Head Replacement
- Delta Single Handle Shower Faucet - Leaking Profusely
- How to install a shower arm correctly
- Mud bed supporting Sterling tub question
- Moen shower valve install problems
- Bath Tub Materials
- Bathtub leaking to downstairs
- Newbie hoping for help with Kohler trim replacement
- Leaking Shower Drain *With Pictures*
- Thermostatic always hot
- Upstairs tub drain leak
- Do they make tub drains that go straight down from the drain instead of the overflow?
- Remove Old Gerber Tub Drain
- 70 year old spout in tub
- Tub Drain Install ????
- Older Moen Faucet
- Seeking: 5' Rectangular Tub w/ Tile Flange, No Apron. Suggestions?
- More grohe thermostatic trouble
- Stuck valve stem seat
- Body spray draining
- Hot water knob HARD TO TURN
- Shower p trap
- replace tub or refinish?
- How to vent bathroom fan when you get 2 feet of snow on your roof
- moen shower valve problem
- Air Intake Knob
- Weak water pressure
- Moen - hot & cold reversed
- Can't use hand held shower hands free...
- Problem tub drain removal
- How to adjust hot/cold w new shower head
- Removing a Watco Bath Tub Drain
- Help identifying old shower fixture
- Removing Price Pfister Tub Spout
- Tiling in New Tub
- Unable to remove control handles/lever
- Bradley-Cole Shower Cartridge
- Removing a Bathtub Spigot
- Removing Faucet Handle
- Smell from Shower Drain
- Bath and shower set installation
- Retiling Bathroom Walls
- Bathtubs for New Rental Duplex
- Replacing spring and neoprene seats
- Caulk on sterling surround?
- Black particles in bath water??
- New Faucet Drips After Shut Off
- installing bathtub
- no glue abs connection
- New Tub - is my contractor trying to pull one over on me?
- Tub Basket Replacement Question
- Lost water pressure in tub/shower
- Kohler tub set problem
- Cast Iron bathtub, install in very tight space????
- Shower Valves
- Placing a new tub in existing 60 inch space.
- Shower waste
- Leaky Single handle shower/tub faucet
- Failed joint at shower head
- Can't budge old moen handles/skirts
- Help, caulking around bathtub is NOT drying.
- Acrylic Bathtub Installation Help
- Three Piece Tub Surround Installation
- Shower goes cold...
- Bathtub Drain Problems
- Tile-in Soaker..3flange..NO APRON. need one.
- Toto vs. Kohler Cast Iron Tub
- Problem with new tub installation
- Jetted Tub Installation Question
- HELP! Trying to change Old Price Pfister Avante
- Unusual Shower Leakage
- Can't Remove Shower Drain -- Part of Shower Pan? (pics)
- Basement Rough In
- Help - novice to plumbing - diverter not working?
- Oatey No-Calk Drain
- Shower pan cracks radiating from drain
- How to put the mortar bed under a bathtub
- Shower question, Delta T18 series, good or not?
- Jacuzzi Tub Noise
- Cement board or DensShield??
- Shower drain question
- Diverter water staying on problem
- Help no plumber an the water is staying on
- Cast Iron Shower Drain Replacement (Slab)
- Walk-in Shower
- "totally" frameless sliding shower doors
- Marble tub drain
- Showerhead/Handshower/Tub Filler Combo Question
- Finishes on Plumbing Fixtures
- Identity and help on removal of handles
- Low Hot water pressure only in shower & tub
- Stuck button on jetted tub
- Shower Floor bed
- Leaking tub spout
- old shower pipe thread
- Bathtub plumbing
- Melting or degrading shower drain
- Help plumbing a walk in shower please?
- downspout still has water coming out
- Showerhead feed above tile line?
- Bathroom remodel. Couple Questions.
- Porcelain, Fiberglass, and Acylic bathtub repair problems.
- Bathtub walls
- Plumbers - Valve Choice for replacement valves.
- Help I 've got the hot and cold reversed
- Question about shower drains..
- showerhead ball joint
- Another question.
- No Hot Water
- Shower gradually loses pressure
- Acrylic Tub Installation
- Shower make-over
- pentagonal shower -- valve placement
- new shower water supply layout
- Water under shower floor
- Why does my Moen Kitchen faucet have rust under it ?
- Issues with Moen 3-function valve install
- Moen shower faucet attachment - confusion!
- Need to learn how to replace a shower valve and faucet
- Whirlpool Tub Motor Replacement?
- Hot Water Pressure problem only in my shower.
- Delex replacement handle
- Cable Drain Replacement
- Shower head extention
- Pressure problems too! After water heater install...
- Shower questions
- Mixet Single Handle Cartridge Still Leaking
- Need some shower doors
- Tub/Shower COLD Water Pressure
- Tub Spout Rough In
- Shower Ceiling
- Victoria and Albert tub, and freestanding faucet/shower valve.
- Leak around Jetted tub drain
- Mortar bed for whirlpool
- Want higher shower pressure
- Filler Unit Available Between Tile and Shower Eschutcheon
- Advice on building shower with lead pan - nyc code
- Tub Drain Test Plug?
- Removal of Bathtub Drain Piece
- Ideas on rotted window in shower
- Help me identify and upgrade old Price Pfister 3 handle tub/shower
- Will this idea work for double vanity drain?
- Strange change in shower/tub water pressure
- bathroom drains
- 1/2" vs. 3/8" water supply question.
- Mortar Bed for Acrylic Bathtub
- Shower Pan, Slab, and Cultured Marble
- Help! Where do you mount elbow for handheld shower?
- undermount bathtub recommendation?
- Bathroom exhaust fan ducting
- Missing mortar bed for tub
- Confused about mortar under tubs...
- 60" x 42" bathtubs with large base? (Replacing a tub-shower)
- cast iron drain
- Converting tile shower to bathtub
- whirlpool overflow install problem
- Tub Surround Installer in NYC
- Caulking behind Three Piece Mirolin Shower
- A-S Lifetime Drian install
- Tub Drain Lever
- new shower stems still leaking
- Tub/Shower Valve Height
- no cold water from shower
- Electric Showers
- Moen Posi-Temp valve adjusts by itself
- Tub/Shower Overflow "Extra" Pipe
- Does this Tub have a Mortar Bed?
- Trying to Fit a Specific Shower Need
- Shower Head/Spout Leaks after remodel
- Acryline air jet tubs?
- Small Bathroom Shower woes!
- Bathtub caulking problems
- Shower body Rough-in
- ceiling leak
- Remodeling bathroom, long post...
- down spout to shower problem
- Installing shower stall on slab foundation
- Kohler Memoirs Neo Angle Shower problems
- Bathroom Exhaust Fan in Angled Ceiling?
- Trip Lever Drain for Americast Tub
- Best cleaner/technique to use to clean a acrylic tub
- EasyBoard
- Smell in one shower only and only with hot water
- Can granite be installed on the ceiling of a sauna?
- tub in a shower pan?
- Older Moen Push-Pull?
- Building a Shower Pan - Recommended Mortar Mix?
- Need Mfg name
- American standard single shower install
- Thinset or something else to replace tiles...
- Can I repair/ reuse old mortar bed on tub surround
- Need shower enclosure for narrow area 24W x 40 L?
- Help! Can't identify brand
- fiberglass good enough?
- Old shower knob leaks
- Apron Support for Sterling tub kit
- Poor Water Flow After Replacing Stems
- Shower/Tub Fixture Help
- Tiling shower
- Shower layout / joist interference
- What's your favorite shower pan material?
- Shower Drain
- Lower Bathtub Needed---HELP!!!
- Bypass Tub/Shower Door w/radius corners?
- Drain Plug - Metric Thread???
- Back up in my shower
- Removing Tub Spout
- Replacing Shower Faucet Handle
- Mortar bed Question
- Tub Spout w/Backsplash - Need Help!
- How to split supply line to go to shower and bath
- How do I tighten down tub faucets if the tile wont allow access?
- Single-Handle Bath faucets without drain
- Can I fix an Alsons 4923 3-way diverter?
- mystery shower fixture brand?
- Leaking terrazzo shower base drain seal
- faucets, valves, fittings for standard tub/shower to roman tub/shower
- Shower Trouble!!!
- cant remove the mechanis for the tub drain!! HELP
- new Am Std cartridge leaks...replaced still leaks
- Bathtub drain & cleanout plate
