View Full Version : Toilet Forum discussions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29
  1. which toto ...[numbers]do i need .?
  2. Toilet clog question
  3. Corner toilets?
  4. Cadet Pro update
  5. Need 2 New Toilets
  6. cracked Toto Promenade tank
  7. Toilet Decision
  8. Bad plumber or what??
  9. Gerber Avalanche 1.28 vs 1.6 gpf
  10. Supply valve too close
  11. Toto Drake flush
  12. Toilet flange dilemma
  13. American standard 4040 replacement tank
  14. No clogs? Toto Drake Sanigloss?
  15. Kohler Portrait or Toto Promeade?
  16. LIXIL (INAX parent) acquires American Standard Brands
  17. Gerber toilets: Keep or replace?
  18. Toilet to Septic tank issues
  19. Urinal Flush Valves
  20. Toto Ultramax II (1.28 GPF) Fill Valve issue? (Noise but no leaks?)
  21. Cast iron toile flange cemented...How do I proceed
  22. Converting Floor mounted toilet to wall hung
  23. Toto Unifit Installation, wax ring too thick?
  24. Toto Toilet seat recommendation
  25. Cadert 3 Flowise flashing in trapway
  26. Toilet gaming technology targets urinal boredom
  27. Request mercy - need serious advice.
  28. Can't decide
  29. Recommendations please: 10" rough, ~15" bowl height, powerful flush (have kids)
  30. wall hung Duravit toilet
  31. Replacement tank for American Standard 4028
  32. Toto Drake 1.28 GPF ST743 is running
  33. KOHLER Aqua Piston Flush Valve
  34. Briggs/Case 6011 toilet needs fixing
  35. A toto toilet for an old home with many kids
  36. Toto drake ii or ultramax ii?
  37. Toilet Repair Kit
  38. Toto Nexus sticky flush
  39. Cleaning a toto toilet with sanagloss?
  40. Toto Drake II 1 GPF color and part confusion
  41. Help connecting a PVC toilet flange to an existing brass drain
  42. Simple installation of toilet fill valve, either Korky or fluidmaster
  43. Rear "cut out" specs for different Toto Aquia Models
  44. Mid-priced Toilet, 10" Rough: Kohler or Am Standard?
  45. 14" ri toto
  46. Toto wall hung problem
  47. 1.28 gpf standard?
  48. Toilet tank overflow NO CLOG
  49. Can you mess up a Unifit install?
  50. Request suggestions for senior-on-budget toilet replacement
  51. Toto toilet bought through Home Depot
  52. Any update on the Delta Prelude's? Performance, fit-n-finish, etc?
  53. how to fill gap in concrete around pvc drain?
  54. Flange diameter too wide / Wax ring problem
  55. Porcher Archive one-piece performance
  56. 9-3/4 rough-in
  57. recommendation for compact skirted toilet
  58. Thoroughly boggled
  59. Plaster of Paris Toilet Base -- Who Uses It?
  60. Brand new AS Champion 4 - need to hold down lever to flush...even then not powerful
  61. Help identifying this Kohler toilet
  62. What am I looking at?
  63. Need Advice on Toto Toilet Selection
  64. Installing Toto Carlyle II - water supply
  65. Need 10" RI, preferably round w "taller" seat
  66. Flapper Flop
  67. Round Toilet Seat Dimensions
  68. American Standard H2Option
  69. One or two wax rings?
  70. Water hammer...I think??
  71. Kohler Wellworth & Memoirs toilet help
  72. case toilet 3200/6000
  73. Leaking New Toto Drale II C454CEFG
  74. Toilet Flange Install
  75. My New Toto Drale II C454CEFG just clogged up
  76. Need to Repair Lead Closet Flange but the Pipe is Crooked!
  77. Help! Sewer smell coming from toilet every time its flushed - all toilets in house
  78. Loud vibrational noise from toilet occurring irregularly
  79. Inside of toilet PVC pipe has cut marks - an issue?
  80. Ultramax II: The Same, Only Different?
  81. Moving toilet 1-2 inches
  82. Toilet water filling tank issue
  83. Portland raises stink about toilet ‘knockoff’
  84. Delayed flush lever
  85. Horrible pee smell coming from toilet bowl please help
  86. Toilet Water supply line in rubbed oil finish
  87. A Big Thud after flushing toilet
  88. Buying a Toto Drake CST744SL; Best Replacement Fill Valve?
  89. Toto CST744S#01 Toilet Question
  90. Kohler Cimarron Question
  91. Replacing closet flange, disaster of fittings
  92. Where can I get a blue toilet?
  93. What to do with a leaking Mansfield 160
  94. What's next for leaking toilet
  95. Rough-in sizes
  96. iPotty, an holder for your iPhone
  97. Correct tank-to-bowl gasket for American Standard Cadet 2 toilet?
  98. What causes was seals to fail when they don't rock?
  99. Kohler canister flush valve question
  100. Sold on Toto but have limited space
  101. External vs Internal Cast Iron pipe closet flange
  102. Reponse to Kohler Cimarron Help.
  103. New TOTO Connelly and ECO Drake and Ultramax II 1G
  104. Toto Drake II tank leak - help me confirm conclusion, please
  105. Toilet help! DIY Fixes, if possible
  106. Vespin II & Bemis NextStep seats
  107. Overcharge?
  108. Fluidmaster 400A Consumer Review
  109. Toilet not fully flushing
  110. Purchased Toto Drake II but discovered I only have 10" rough in
  111. Toto Sanagloss finish doesn't look right, am I crazy?
  112. Next Step toilet seat for a skirted toilet
  113. Drake II Choice and Color
  114. Kohler Adair vs Cimarron 1 piece toilets.
  115. Creaking wall hung
  116. Loud noise like a thundering "waterfall" after neighbour flush
  117. Need toilet 24" long or less - any suggestions?
  118. Toto C744EF.10-01 & ST743S-01 Tank Type B fill valve Question.
  119. Dual Flush System with (Stock ones that come with toilet)
  120. Leaky Toilet but I can't figure out where it's coming from. Help?
  121. Rocking Toilet
  122. Afraid contractor will mess up a Toto Unifit install...need advice.
  123. Toto Promenade + baseboard radiator... mismatch
  124. Toto toilet dripping but can't find leak
  125. Where to get White Diamond Bowl Cleaner?
  126. Lead closet bend doesn't reach floor
  127. Styrofoam in tank
  128. Back to Back Installation Opinions wanted
  129. Is the Toto Drake II better than the Toto Drake?
  130. Kohler Trip Lever P/N 87220
  131. Toilet leaks from bottom after installing new tank kit.
  132. help identifying toto toilet
  133. flush problems on american standard wall hung toilet with tank.
  134. TOTO Entrada, CST244EF
  135. Moderate Floor Damage - Needs Repair?
  136. Kohler Highline dual flush
  137. replacing 2-piece cast iron toilet flange
  138. 10" versus 12" toilet - what have I got?
  139. Is there a decent Flapper MOD for the Rialto
  140. Can anyone recommend a toilet that has a true 14 inch rough in?
  141. Stubborn Toilet Requires 2 Flushes
  142. Insulated Tank for Toto Drake II
  143. Korky instead of TSU39 fill valve?
  144. Did I get a 10" rough-in when I didn't need one?
  145. Kohler Cimarron (Class 5) vs TOTO Drake 1.6 (G-MAX)
  146. Best wax ring for Drake 2 = ??
  147. Where to find the "Water Depth from the Rim" for Toto toilets
  148. Help with 11" rough in - which toilet?
  149. Glacier Bay Toilet - Manufacturers defects
  150. Back to back installations of toilets
  151. Which Toto to buy? MS604114CEFG-01 Ultramax II? MS854114SL-01? Other?
  152. Toilet Leak Issues
  153. Toto Aquia Temporary Install on Concrete Floor
  154. Minimum wax ring thickness
  155. Soiree Install Issue...don't think it will work! Please help.
  156. Toto Drake Round, Elongated, ADA MaP Testing Differences
  157. Replace Toto fill valve BEFORE it fails?
  158. Toto Ultramax II 1.28gpf vs. 1gpf
  159. OT: Removing Spray Foam from Porcelain
  160. What is a Contractor Grade Drake???
  161. Dipping my waters into the *Kaboom* setup
  162. Wall hung toilet gasket
  163. flush the toilet upstairs and a loud noise
  164. Duravit Metro flush valve leak
  165. 3/8 versus 1/2 Supply Valve
  166. Happy D toilet WALL (rear/horizontal) outlet model installation
  167. Gerber Maxwell 21-418 - any good? bowl: 21-728 tank: 28-490
  168. Need unusual toilet with 20" rough-in
  169. weird toilet
  170. Need toilet with gap between floor base and wall
  171. Where to find a Universal Rundle tank?
  172. New toliets Ultramax II
  173. Need tank-to-bowl gasket for 1954 Case ? Toilet
  174. Small Bubbles forming in toilet bowls and tanks
  175. Just an idea.... modifications of UniFit adapter.
  176. Issue with Aquia flush
  177. Old Triangle Eljer Tank Needs New Bowl
  178. Multiple problems after replacing fill and flush valve
  179. Question for Terry or the other Pro's...Guinevere Wall clearance
  180. Kohler Kingston vs Zurn Wall Mount vs TOTO Wall Mount vs American Standard Afwall
  181. Loud bang from toilet
  182. Future toilets, a cool video
  183. HELP New Drake II keeps plugging up
  184. Toto Aquia Leaking - New Install
  185. CST454CEFG-01 tank
  186. Argentina bidet question and floor drain
  187. Slow toilet, Eljer, 3" flush valve
  188. Puzzle pot
  189. American Standard Champion 4 VS Champion 4 Max
  190. Toilet Flange too High
  191. help, limited space in bathroom, need short toilet
  192. Flapper
  193. Toto washlet S300e question
  194. Guinevere Toto toilet - too tight space creating problems - ideas to fix welcome! Pl
  195. Intermittent Toilet Mystery Leak
  196. Toto Drake II tank - are they now only shipping the 1gpf tank?
  197. ominous cracking noise tightening down Toto Eco-Drake tank
  198. Bill Gates can't build a toilet
  199. Toilet Bowl Drips water back down into sewer pipe
  200. Mirabelle MIRGA241WH "Galatia" One Piece Toilet
  201. Length of stiff but flexible plastic pipe prevents bowl scratching by metal snake
  202. TOTO Ultramax 2 with bidet seat vs Kohler Gabrielle K-3825
  203. Slow leak Different location
  204. Toilet Phantom Flushing
  205. Kohler Rialto toilet 1984
  206. toto toilet runs loud after flush
  207. INAX toilets? TOTO Supreme? Coway bidet seat?
  208. Caulking recommendations, toilet- travertine stone floor
  209. Caroma - Which model
  210. Another closet flange, closet bend question
  211. Unusual stickiness?
  212. Kohler Memoirs 12" toilet - 10" old toilet. Help ?
  213. Toto Drake Cleaning
  214. Water supply not left of center (TOTO toilet) with skirt
  215. Volume of flush
  216. Change Toto flush valve for more water?
  217. Chronic toilet backup... including Toto Drake
  218. Fluidmaster 400A problems!
  219. Toilet Repair - How to Proceed
  220. Cadet PRO Elongated Toilet 10" Rough-In 1.6gpf
  221. Sterling Windham Toilet Review. 402215
  222. Crane Drexel Elongated Toilet Seat
  223. HUGE thanks to Terry and these forums
  224. Gerber 28-790 leaking from fill valve
  225. Help with tile and flange
  226. Bidet seat choices and water supply
  227. New Toilet install Toilet flange too low and question on pipe diameter
  228. Question about closet flange:
  229. A toilet invention
  230. Noisy Main Stack pipe
  231. Cracket Closet Flange Repair Options
  232. Question about wall-hung Maris. Geberit and TOTO carriers
  233. Vintage Crane Siwelclo 1935 toilet repair - need help
  234. Wax ring vs. Fernco FTS-3
  235. Need Help Please! Trying to locate a Case #5160 ballcock (aka #41 Blue Label)
  236. Best bang for the buck skirted toilet with push button style flush?
  237. After flushing water won't go down
  238. Plastic bolts too tight
  239. Is this a bowl defect (New Toto Promenade 1.6 round)
  240. Replaced fill valve, no water fills in tank.
  241. Help me find a toilet, round bowl and comfort height.
  242. Uneven toilet flange
  243. Input on "Toilet Anywhere"
  244. How to remove TOTO Ultramax flapper. THU096
  245. Toto Ultramax fill valve won't shut off
  246. Is there a way to replace closet bolt without removing the toilet?
  247. Toto Dual flush - not filling
  248. Toto Ryohan
  249. Old toilet replacement. Looks less than 10 inch rough in
  250. Assembled Height not height than 26 1/2" inches
