View Full Version : Water Softener Forum, problems, installation and reviews
Pages : [1] 2 3
  1. Water Softener systems?
  2. water softener advice please
  3. Culligan Mark 812 Water Conditioner - Time to replace?
  4. Kinetico Model no. 30 Problems
  5. Kenmore water softener
  6. electromagnetic water softener (descaler)
  7. Best Home Water Softener System & PEX or CPVC?
  8. Culligan Water Softener Shaking/Vibrating Loudly
  9. Calcium buildup in water heater
  10. Should air check valve in Autotrol 255 be full of water or air?
  11. Water softeners?
  12. Installing Water Softener
  13. Softner wants to regenerate every night
  14. Catalytic and/or magnetic water contitioners/softeners
  15. Kinetico Softener-50 HELP!!
  16. Water Softener Maintenance
  17. kinetico water softener problem
  18. What to do with hard, hard water?
  19. water mineral content
  20. What about Northstar softeners?
  21. bubbles in water
  22. Sump pump or ?
  23. Hydrocare HC38 Thoughts???
  24. Water softener question
  25. Stinky water, high iron, need softener and overwhelmed
  26. Boogers in my Kinetico Softener
  27. Water softner install
  28. Salt Build Up Around Water Softener?
  29. Resin in Backwash? Is this normal?
  30. Water Treatment Salt Buildup
  31. brine softwater problem
  32. Fleck 5600sxt
  33. Can you ID this softener?
  34. Can you ID this softener?
  35. kinetico model 30 help
  36. How Often?
  37. Kinetico 2100s Water Softner - HELP!!!
  38. Fleck 5600 water softener makes noise
  39. Well Water Problems, Please help!
  40. Salt free softeners
  41. Water softener dischage line
  42. Water softener salt and water level
  43. GE Smart Water Softener
  44. Kinetico softener head rebuild with pics
  45. Water Softener Recommendations
  46. Water Softener Self installation
  47. Moving my Kinetico System??
  48. Need soft water
  49. Water Softener CPVC Installation
  50. Brine Tank Question
  51. Gary or Someone Please help, resin in drinking water
  52. Kenmore Ultrasoft 200
  53. Will a water softener solve our problem?
  54. Old School Culligan Softener Rebuild...
  55. Water Softener and RO System Question
  56. Kenmore 150
  57. Kinetico Q237?
  58. Help programming my Clack WS-1 (salt dose?)
  59. New well completed -- Please review water test results
  60. Water softeners and Wells
  61. Watermate water conditioner problem
  62. Acid neutralizer question
  63. Extreme potassium in water, Kinetco system
  64. Neutralizer backwash HELP.
  65. clack ws1 orphan
  66. Hard water, slow salt
  67. Kinetico Model 60 Connections
  68. Softener Selection Help
  69. Recommend Water Filter (not softener)
  70. kenmore flooded brine tank HELP!
  71. cycle times for my fleck 5600se
  72. Technetic 1000
  73. Gallon setting for Kinetico meter softener
  74. AQUAFINE AQUA II 20u
  75. filter system help
  76. Kinetico Sulfur Guard vs. Culligan Iron-Cleer/Gold Softner
  77. Kinetico Sulfur Guard vs. Culligan Iron-Cleer
  78. New resin for model 60
  79. fleck 5600 valve
  80. Kinetico #60 replacement head?
  81. pros/cons of Filox filter before or after softener?
  82. salt for Aquafine Aqua 2 water softener
  83. Recommendations for high flow pre- and post- filter cansisters?
  84. How to give softener a thorough cleaning for iron and bacteria?
  85. Need help clarifying brine tank valve function
  86. Clack WS-1 backwash problem
  87. Resin in Screens
  88. constant water from discharge
  89. Converting from Potassium to Sodium
  90. Kinetico problem's
  91. Culligan softener problem
  92. Arsenxnp experience
  93. water softener recommendation for 3/3 condo
  94. Slow Brine fill on new Fleck 7000SXT
  95. Softner Recomendation
  96. Softener Tank Media Quanity
  97. Salt Taste in Water After Regen
  98. Kinnetico Softener Questions - Tannin, Etc.
  99. Kenmore no brine draw
  100. kinetico 30 need help
  101. Fleck 5600
  102. Gravel Bed Question
  103. Softeners, resin, and iron removal
  104. Questions about water softener choice...
  105. Fleck 3600 - brine tank flooding
  106. Help with installing Kinetico Model 60 in MY house.
  107. Check my math plz
  108. water filter help/selection
  109. Help! Leaking resin tank
  110. restart a model 30
  111. How to remove Rainsoft
  112. Softener Component Spec
  113. looking for a 2nd opinion
  114. kinetico Woes
  115. Manganese problem
  116. Softener is plumbed to only hot water.
  117. Red water residue question
  118. Water Pressure during regen
  119. Fleck 9000 settings question
  120. Clack WS1 EE Programming
  121. Kinetico
  122. Installation of softener with well
  123. Water heater problem/water softner?
  124. Culligan Medalist Softener Brine Refill Cycle
  125. DIY or PROFESSIONAL?
  126. I need flow switch recommendation
  127. General Ionics greensand filter parts
  128. Clack WS1 salty water problem
  129. Hey Gary
  130. What does everyone think of this softner/filter
  131. Sears Intellisoft 420 Series
  132. Test for salt/sodium levels in water
  133. sulfur and high Ph two different systems which to choose
  134. disinfect? Unused for a year, water brown
  135. Water softener produces rusty water
  136. Iron Bacteria
  137. Do I need a new Softener - Have Kinetico?
  138. Air Injector problem
  139. Aquarium
  140. Compare Fleck softeners
  141. kinetico water softener
  142. Dosing Water Softener
  143. Culligan Mark 812 stuck in regeneration
  144. Pre or Post Brine Tank Fill
  145. Kinetico valve tune-up
  146. Need a Water Softner! Which One?
  147. Iron Or What???
  148. chlorine injection for sulfur bacteria
  149. Clack WS-1 Parts
  150. New water softener - no drain
  151. Fleck 9100 Metered Twin Tank Water Softener - 24,000 Grain
  152. Water coming out of 'overflow' in brine tank
  153. General Resin questions
  154. Macclean W/S pressure tank leaking
  155. New Water softener, but still have white residue in water
  156. Maximum time between regens with clear water iron
  157. I have issues!
  158. Need help with Gross Alpha
  159. Help with a water (ph?) filter...
  160. Need help setting up used Kinetico
  161. Sears softener not regenerating
  162. Old Sears Water Filter
  163. How do I rebed my culligan filter?
  164. renting vs buying
  165. Kenmore Water Softener - Discharging via Overflow Line
  166. Kenmore water softner: Water going in drain pipe continuously
  167. How do i set-up my clack ws1.25?
  168. Technetic 1000
  169. How to determine proper bed depth
  170. New House, Shared Well, Iron and H2S
  171. Vortech Distributor
  172. Outside Backwash Drain
  173. Where does my softener drain go?
  174. Removed a water softener system
  175. MortonŽ System SaverŽ II
  176. Got a quote from Kinetico, looking for other options
  177. Clack WS1 not metering
  178. culligan Medallist will not regenerate
  179. low water pressure after insall
  180. 'Water Right Sanitizer Series ' water softener AWP-SE2
  181. water softener is not pumping water into brine tank.
  182. Identifying control valves
  183. I have a leak.....we're going down!
  184. Update from Gen Resin Questions SST-60
  185. Not strictly water softner, but
  186. Water Softener With A Septic System OK or Not OK
  187. Softener system for new home - ATTN GARY
  188. Old softener maintenance?
  189. I have a new softner but???
  190. Gary is the man!!
  191. Not using salt
  192. Replacing an old water softener system
  193. Brine tank filling up with too much water
  194. What is the best salt...???
  195. Clack WS 1 programming PLEASE HELP
  196. Aquafine Aqua2
  197. Air Injector question again vs Mazzi Injector
  198. recycle used resin?
  199. Water Hammer?
  200. New home / iron filter
  201. softener introducting air into my water lines
  202. GE 460i advice
  203. Culligan Iron Cleer problems.....
  204. New homeowner...existing water softerner...no manual...not regenerating
  205. Kinetico 60: Repair, Rebuild, or Replace?
  206. Help with Water Softener Discharge Point
  207. Well water building up calcium deposits.........
  208. Black sediment coming from Water Softener
  209. Culligan Mark 812
  210. What's your take on salt-free softeners?
  211. Fleck 2510 Salt Dose
  212. No soft water after filter change on a Kinetico
  213. Clack WS1 EE settings
  214. Water Softener with RO and Ph (acid) Neutralizer Install Help
  215. DIY question - water softener and sodium filters
  216. Kenetico 60 water discharge
  217. Please help me choose a softener for a well with iron
  218. green sand filter
  219. New Reverse Osmosis tank
  220. Fleck 5600SE settings
  221. Do I need a softener with an RO filter if I have a well? tried to read through...
  222. ISOBAR Automatic Filter Control Valve & R/O advice
  223. Losing my resin out the drain hose.
  224. Frequency of regeneration
  225. No drain near softener - looking for idaes
  226. Kenmore Ultrasoft 425 Err3 Code
  227. Dialing in my Fleck
  228. Softener Outside
  229. 1950-60 era Peerless softener has quit softening
  230. Air in lines
  231. Can Anybody Here Read Water Test Results? Need Help Deciding on Water Softner Type.
  232. Is there any way to tell a water softeners capacity by tank size?
  233. Water softener drain connect to kitchen sink?
  234. 1-1/4" PEX, is a DIY install possible?
  235. Northstar water softener
  236. ABC's of how a water softener system works-
  237. iron problems
  238. smartwater not drawing brine
  239. IONICS 3210 programming.
  240. Fleck 8500 control performs intermittently
  241. Need help to settle a wager: Culligan vs Fleck, Clack, etc.
  242. Kenmore 350 water softener leaking at O-ring
  243. Does SST-60 Resin solve this problem?
  244. Culligan water softener stuck on regeneration
  245. Remove Iron from pipes
  246. Water softener selection help
  247. Help..Broken micro-switch tab, twice
  248. Help-About ready to jump off a Bridge!!!
  249. Arsenic removal
  250. Water Softener ruining my hot water tank????
