- air gap built into Fleck 7000 drain?
- Fleck 7000 questions
- SST-60 Resin, Reducing salt, removing manganese and iron
- New guy. need help filtering iron. Screwed up my birm filter.
- Normal Softner Servicing?
- In Nh. friend with radon. needs water filter for radon
- Las Vegas Water Softener Selection
- Water Test - Iron Symptoms but no Iron
- Culligan N8 Custom Replacement
- Water Softener Advice
- 3 companies came to do tests, please advise on which softener
- Softener not softening?
- which water softener
- how do i adjust softener after loosing resin
- 7000SXT "stuck"
- Water Softener and RO Recommendation
- Clack Retention Tank Problem
- Is salt bridging mostly theoretical?
- Advice on which size softener
- completely overwhelmed
- Autotrol 460i problem
- days remaining Fleck 7000SXT?
- variable bringing
- Fleck 5600sxt, time change?
- culligan estate 2 water softner not working properly??
- Review of the new...Fleck 5800 valve
- Can I take a shower or use water during regeneration?
- Gary's "trick" and how effective is Iron Out?
- how to convert up flow AN to down flow
- New Filtration System Build
- Water softener Controller Bangs/Sloshes when well Shuts off
- Autotrol Iron Filter Problem
- ws-1 clack
- Filtered Well Water Overall Drinkability?
- Iron out question
- Good resin brands?
- System in new house
- Configuring a softener to a different size.
- Salt Dosage and Fleck 6700XTR, or any head for that matter
- New Whole house filtration
- routine maintenance, is cleaning of softener resin advisable?
- flow test after new softener
- Fleck Pentair 5800LXT first review
- Sour smell on laundry
- New boiler/indirect tank confusing water softener?
- Tannan issues two water softners ?????
- Tannin issues two water softners?? Sorry my first post is blank, don't know why.
- IE filter for Arsenic and Nitrates
- New Fleck 5600 - HELP!
- Iron and low Ph problem
- Need help identifying make and model of controller unit for troubleshooting
- New system setup, iron softener with KDF
- Iron Remover/Water Softener redesign
- Where to buy resin locally?
- Water Softener & Options Recommendations
- No regeneration?
- Bamboo Charcoal for filtration
- Waterboss finally puked....maybe?
- Difference in resin?
- My new Fleck 7000sxt
- 7000SXT 1.05" vs 32mm distributor pipe
- Programming a Fleck 7000 and Sanitizing
- Morton water softener
- Iron staining, Sulfur smell, water options
- Planning / Installing new softener, couple of quick questions
- Sediment filter questions
- Iron Bacteria
- Water softener problem, elevated copper in drinking water
- 2 questions
- clay in water. please help
- Hose-bib circuit between pressure tank and BIRM filter
- iron removal well water
- Got a Clack today - 2 questions so far
- Little iron still in water after brand new Softener installed
- Fleck 2500 control valve and help with softener maintenance
- valve between hose bib supply - softened and untreated
- Is the sizing on this OK and any comments on Aqua-pure softeners
- A couple of questions-- Fleck 7000
- Need advice for iron filter
- New Whole House Carbon Filter & Water Softener
- iron removal method question
- Fleck 7000SXT 32k Noise Troubleshooting and Programming
- Program help w/ Fleck 7000SXT as BW filter only
- I could use some input on my water softener situation.
- Clack WS1 type softener-no suction-have tried "everything"
- Kinetico Model 60 won't draw
- Tank fills up...
- Water softener startup
- Culligan Mark 100 needs repair
- Resin found in the drain discharge
- Culligan Ironcleer System failure
- Culligan water softener part # 01016351 leaking
- Mark 100 problem?
- On the horizon -
- 3/4 Inch Water Supply, 1 Inch Water Softner???
- New reverse osmosis system. Flow rate seems low. Please advise
- Canature Brand Brim Filter - Alternatives?
- Rain Soft Not Softening
- H2S, carbon and air input needed
- Sulpher Egg Smell from new Carbon Tank System?!?!?!?!
- Rapid Decrease In Water Pressure After Softener
- Water softener sizing and system selection?
- Isolating KDF-85 into another tank????
- New GE water softener not softening, the GPH meter is going full cycle in seconds
- Iron Filter/Water Softener need advice
- new softener question
- Buying a used water softener - bad idea?
- Softener discharge line... where to dump it?
- Salty Water - But only the HOT water ???
- Clack WS-1 stuck on "regen today"
- Where is the smell coming from??????
- how much carbon in 10 X 54 tank?
- Dumb water softener question, why does increasing the salt level lenthten regen time
- backwash Mangox filter from storage tank instead of well?
- an electronic way to test my water hardness using sodium instead of salt
- WS-1 with Hard Water and High Brine Level.
- Drain for Softener
- Which of These Two Softeners Would You Use?
- WSI-CI Clack Valve
- Iron, H2S, and other Problems with Existing Well Water Treatment System
- How do I remove BLFC from Fleck 6700XTR head?
- Fleck 6700XTR cycles seem incorrect
- Brand new Softener was working great not it's not. Any ideas
- Best place to buy Hach 5-B hardness test kit
- What is the best water softener....
- 1" PEX or 1" PVC when hooking up new softener?
- what size water softener should I get (twin,single, etc...) ?
- KDF Application
- media guard kdf 55 good or bad?
- Resin replacement mesh size
- WQA Books, DVD and Carl Davidson Video and Autotrol leftovers for sale ...
- Anyway to clean iron from inside of softener/resin?
- Can I replace the entire valve control on a Culligan mark 812?
- Water softner flowing backwards.
- hard water breakthrough on new system
- Help with Culligan Silver Series
- Need advice! New softener needed. Possible ripoff?
- water softener line clogged
- Iron Filter / Water Softener - how to choose
- Kinetico Model 60 Issue with Softness
- Time for softener/neutralizer system
- Clack Drain line constant drip
- Brown water morning after regeneration cycle
- Programming an 5600SXT for maximum effenciency
- Autotrol Performa Valve with a 460i control
- Gary Slusser and your webpage to determine efficiency settings idea.
- Clack WS1 Not Softening
- Help Turning on My Softener
- New water softener system awaiting installation, few questions.
- Culligan Medalist (8in) Settings - Too Many Regens
- Culligan Water Softener
- Fleck 5600SXT meter control valve questions.
- Cleaned the brine tank, Now no soft water?
- datasheet for Carbochem CA-10 resin?
- Fleck 7000 Variable Brining - Awesome?
- RO unit TDS ---- and yes the question is tied to a SOFTENER
- Ultra filtration systems
- Please help size water softener / carbon filter
- Water Softener RESERVE setting - a misnomer ?
- culligan estate 2 problems... water not soft
- How A Reverse Osmosis Permeate Pump Works
- 7000SXT rebuild tutorial
- Purchasing new softener + GAC - help sizing and general advice?
- salt concentration for 27 GPG hardness
- Iron and Hardness test kit suggestions
- Culligan shut off valve
- Clack WS1 Tutorial
- Culligan Mark 100 Stopped in Regenerant Draw Position
- Ionics IQ-0820 Softener -- Replace Resin without Hygene?
- small reverse osmosis sytem re-filter and permeate pump upgrade
- I did it, ordered some POU shower filters!
- 5000 ProFlo rebuild tutorial
- Rotten Egg Smell in Water
- Salty taste to water
- Water Softener Settings & Salt/Brine Grid Question.
- 7000SXT water softner system not working
- Over conservative salt efficiency and regeneration settings from old pros here!
- New fleck 7000 sxt questions
- Centaur Carbon Filter ?'s
- Recommendations on Acid Neutralizers
- GE GXSF40H Brine tank overflowing
- Template Assisted Crystals (TAC) Water Softeners
- Culligan Sulfur-Cleer Not Regenerating
- Bought home, need help with water softener
- Filox Iron Filter Installation Question
- whole house water filter
- AquaPure AWS200M brine tank refill?
- Need Help for setting up Fleck 2900S and Noise solution.
- fleck 5600 econominder
- Water softener buzz
- Problems with water softener, Kenmore
- Dead Culligan Estate 2 - How to remove & what's next?
- Fleck 5600/Foregin Pieces in Cylinder
- Culligan water softner continually recharges!
- Water Filtration Education
- Odd: Potassium Taste
- 750 gallons between regen cycles?
- GE Smartwater Softner
- Water Softener Drain Line
- Culligan Super S not pulling bleach
- Northstar - no soft water, replaced seals and rotor, about ready to give up
- Kinetico 2060 Water Softner
- Culligan Estate 2 not working automatically
- softner problems
- Odd Fleck 7000SXT configuration possible?
- Time for a new water softener system.
- "found a kinetico"
- Fleck valve questions
- Autotrol 255/440i water low flow and brine tank backing up
- Question on Fleck 7000 water softener 64k grin
- Need help in programming Fleck 7000sxt.
- Revisiting Water system and ready to buy. Please help with final decision
- no soft water
- Won't stop regenerating! Kinetico 2100 FOD filter head
- HELP - No Experience with Water Softeners
- Kenmore Series 300 Water Softener Float Valve assembly
- Installing new water treatment system
- Disadvantage to Over-sized Softener?
- At wits end with new Fleck 7000 stx!
- How to empty water softener? (Kenmore deluxe demand water softener 625)
- Fleck 7000 Installation Questions
- Fleck 7000SXT Carbon Filter - Extremely Loud Backwash & Rinse
- New well, professional water analysis ... need advice!
- Rainsoft AQB Series E
- Problem with neutralizer backwash cycle causing water overflow and spillage
- 7000sxt - Sizing For Now vs Sizing For the Future?? Rapidly Growing Family
- New 7000 SXT. Not sure about it.
- Testing Fleck 7000 flow meter advice?
- Well / Pond water system design
- Sizing on fleck 5600 softener
- sink tailpiece with bung for RO filter brine water. Quiet.
- Kenmore Ultra Soft 400 err 1 and major leaking
- Water Softener, I'm learning but still a bit confused....
- What softener do you recommend?
- Kenmore water softener problem; repair or replace?
- Can someone help me determine my needs?
- water softener continuously runs to drain ECR 3500 Ecowater
- New Clack Based Water Softener Not Pulling Brine on Recharge
- How Best to Replace Media (Birm) in Filter
- Adjusting BIRM Backwash Cycle for Well-Limited Water Flow
- Culligan medallist --high water ph after backwash
- Moving Into New House Need Advice
- Need help with picking the correct softener
- Help with Culligan Gold Series Metered 9" WS float
- Water softener choice
- Building a tannin filter
- fine mesh resin in 23 year old softener-problems!
- Newbie Looking for Softener: Where to start?
- Well water issues help
