- Gas versus Electric WH?
- Keep replacing top thermostat. Works for a day. Wiring right?
- Canted Control Valve on new GE water heater from HD...Buy it or not?
- Where to find Magnesium Anodes for 50 Gal Gas GE/Rheem? Model PG50T9A....Thanks!
- GFI adding WH
- adding a light switch to GFI protected circuit
- Hot water coming through cold water line
- Multiple Hot Water Heaters
- GE electric water heater, lower element not in use?
- Voltage at elements & other questions
- Recommended Oil Furnace/Boiler Temp?
- Water heater gas control magnet assembly
- Oil leak in water heater burner..
- Metered gas use
- Honeywell AM-1 Thermostatic Mixing Valves. ( water heater tempering )
- Water heater sizing help
- Connecting water tank to 1" trunk
- All Over the Map Hot Water Heater Questions
- Rheem XR90 Series water heater
- Ruud40 gallon Gas Hot Water Heater
- 2 Expansion Tanks
- Leaking Water Heater From Relief Valve
- Forced Air Heating
- Any water heaters with built-in exchanger?
- Power vent water heater question
- Code: Minimum Hot Water Capacity Replacement
- we bought a reliance 606 water heater on 10-05-2011 and the pilot wont stay on.
- Water Heater In-Line Pump
- 120V 20 Gallon Electric has me stumped.
- Will Water Heater Wiring Overheat with External Insulation?
- Urgent - No hot water
- burner won't stay lit
- Corrosion in newly installed water heater
- Hot Water in Cold Water Supply
- Electric WH T&P Valve
- Hybrid v. tankless v. electric
- water heater not working
- What next? Just replaced a well used 8yr old "builder grade" gas water heater ....
- Marathon should the lower element run all the time
- Problem with AO smith Promax water heater.
- Wet insulation on new Bradford White water heater a big problem?
- New Hot Water tank Leak or Condensation? AO Smith GCV 50 300 ProMax
- Gas leak on control valve unit
- Expansion tank on HWD system
- Does Pressure balanced Fixtures make Mixing valves obsolete?
- Two questions re: 75 gallon WH replacement
- aluminum hydroxide
- Nuisance electric water heater over temp trip
- What size water heater needed for Jacuzzi?
- Reliable brands?
- Flame out at Vent Opening
- Ceiling vent grate near water heater firestop.
- Rheem Fury warranty period
- Replacing air scoop
- Prophylactic Water Heater Replacement?
- How to tell is water heater elements are ok
- Need a new water heater
