View Full Version : Irrigation / Sprinkler Forum
Pages : [1] 2 3
  1. Sprinkler pump with pressure tank
  2. Backflow Preventer Sizing
  3. Inline Backflow Preventer - Plumbing Supply in Seattle?
  4. Sprinkler Air Vacuum breaker vs Pressure vacuum breaker
  5. copper to pvc
  6. Irragation well pump pressure goes up and down
  7. next project. Rust treatment for irrigation
  8. Wilkins PVB leaking bonnet
  9. Can't find a Toro part
  10. OK For Irrigation System To Bypass Pressure Tank?
  11. Jet Pump or Sprinkler Pump?
  12. Low pressure cutoff.
  13. Drip irrigation of groundcover
  14. Frying Transformers...
  15. Pressure Reducing Valve Making Noise
  16. Severe water hammer/slow close valves
  17. Sprinkler Manifold
  18. powering sprinklers from hose
  19. Anyone familiar with Weathermatic valves?
  20. water accumulation
  21. Pressure Tank vs. Pitless Adaptor
  22. pressure tank yes or no
  23. Which CONTROLLER is "best" ??
  24. drain tile around swimming pool
  25. toilet "noise"
  26. Low angle nozzles
  27. What size air compressor is necessary?
  28. backflow device overflow
  29. pressure releif valve
  30. Water Hammer
  31. Rainmaker Sprinkler
  32. large acre drip tape application
  33. private irr water service
  34. irragation
  35. sprinkler job
  36. Help needed please.
  37. Goulds GT10 and Pressure Tank
  38. Rainbird Troubleshoot
  39. Spring Turn On
  40. Watts Series 800M4QT Anti-Siphon Pressure Vacuum Breaker Cap Leaking
  41. Normally closed PSR?
  42. Turning on sprinkler system in spring
  43. Pump ?
  44. Irragation from river
  45. How Lock Out Supply Valve for Winter (Rental)
  46. Moving outdoor faucet
  47. Backflow valves
  48. Need Advice
  49. Pressure Drops When Sprinkler Zone Changes
  50. Pump Question
  51. Acid the way to go ?
  52. All stations watering at once
  53. Irrigation Pumps
  54. Sprinkler conversion question?
  55. Sprinklers run out of water..need help
  56. Backflow vs low flow hose?
  57. New construction / help with main size
  58. Lawn Sprinkler System
  59. new to sprinklers systems
  60. pipe noise
  61. Finding a valve box
  62. pump won't shut off
  63. Difficulty adding new zones
  64. Anyone using any ET based sprinkler controllers?
  65. Toro Mini 8 sprinkler head will not rotate
  66. Weathermatic controllers???
  67. how does electric sprinkler valve work?
  68. Should valves leak water when used normally?
  69. where to find repair kit?
  70. Toro valve help
  71. PUMP built in pressure shut off switch
  72. help! h2o shooting out of anti-siphon
  73. Pipe Noise??? HELP
  74. Help with well configuration for sprinkler & hydrant
  75. Anti-Siphon Overflowing!
  76. No pressure to sprinklers
  77. HELP! Newbie w/sprinkler problem
  78. Pop up sprinklers
  79. Need Help With Sprinkler System
  80. Finding where our leak is.
  81. Help with vacuum breaker
  82. Sprinkler Pump Wiring
  83. Irrigation System Problems
  84. Irrigation Pump Problem
  85. House plumbing chatters when used w/ irrigation on
  86. station won't shut off
  87. Help with sprinkler pump and main line for irrigation
  88. Lake Pump problems, best system design?
  89. I have 3 zones that are not working...
  90. popups or rotors
  91. Main lines running from the street
  92. Sprinkler System Leak
  93. sprinkler system project
  94. more zones wanted, no more wires
  95. Sprinklers spraying way too far.
  96. drip line setup
  97. Solution for recycled water
  98. Good general overview?
  99. Backflow output
  100. Sprinkler water lines
  101. Backflow removal necessary?
  102. Noise from PVB
  103. Job Pricing sprinkler system
  104. Blow out pricing
  105. How to set up plumbing for a horse farm
  106. Can I use two controllers in one system
  107. pop up sprinkler
  108. pop-up sprinker flooding
  109. Pop Up Sprinkler diagnosis help needed!
  110. Richdel valve leaks
  111. New home sprinkler system
  112. Finding Valves
  113. Sprinkler Head Question
  114. Sprinkler Timer
  115. Sprinklers not popping up
  116. Sta-rite lawn pump
  117. Central control valve location, pros and cons?
  118. Irrigation help
  119. water lawn from lake
  120. Design Problems
  121. Pump cycles too much
  122. outdoor hot tub ? Brainteaser
  123. Water Just Stopped
  124. several station on at once
  125. Zone and head question
  126. How to start my sprinkler system for the Spring?
  127. Sprinklers Not Shutting Off
  128. Watermain Size
  129. Err on My ICC Controller
  130. pipe size question
  131. Repair Old Toro Rotors
  132. Dog chewed wires-did she fry the valves?
  133. Help Please, new house sprinkler problems...
  134. Hunter Sprinklers
  135. HELP! Wierd things are happening
  136. Too much water in a small space
  137. finding GPM for flow test
  138. 2 Valves on one zone?
  139. Disabling individual sprinkler heads
  140. Copper or CPVC??
  141. Wiring AMT Pump
  142. Low pressure at zone 4
  143. Sprinklers turning on and off sporadicly.
  144. water master 57116
  145. A strange problem with Rainbird system
  146. How to adjust zones on controller
  147. heads are not popping up, need help
  148. Drainage System
  149. Is this a pressure release valve?
  150. pump for random use
  151. Strange behavior - must be spring
  152. Main Water Valve is shooting water
  153. breaker breaker 911
  154. Rainbird sprinklers sometimes comes on. Please help.
  155. Pressure tank or not
  156. Using Sump pit and pump for lawn irrigation
  157. which 'wilkins' check valve should I use?
  158. Valve will not close
  159. Winterizing question
  160. Locating automatic sprinkler control valves
  161. 12VDC solenoids?
  162. off topic question
  163. Fixed two leaks, but no water coming out.
  164. How to check for leaks in Automatic Sprinkler system
  165. Accidentally punctured pvc... standard solution doesn't seem feasible
  166. Pre-installed irrigation tie-in?
  167. village won't allow me
  168. Thoughts on auto-drains
  169. 2nd meter
  170. Backflow preventer. Basic questions
  171. Pipe union and teflon tape
  172. Hunter SRR Remote Failure??
  173. PVB testing
  174. Water Master drip system that won't stop running
  175. Need sprinkler valve help
  176. Wiring for a 1HP Irrigation Well/Pump
  177. Now what???
  178. Moving an inground sprinkler head
  179. Starting up sprinkler repair
  180. Heads "ooze" water after cycle ends
  181. Rainbird Drip Manifold Leak
  182. water pressure drops when changing zones and wont come back up to normal
  183. Rushing Water Noise
  184. fuuny pipe or larger diameter risers-does it matter
  185. I have a broken Hunter head...Help
  186. Is a check valve sufficient for backflow prevention?
  187. Four zones not working since startup
  188. Replacement cover for impact head
  189. Depth of poly? Depth of drip line?
  190. Perforated down spout tubing
  191. Automatic Sprinkler Lateral Pipe Size Reduction
  192. 2 out of 4 zones suddenly don't work
  193. Crazy looking for leak
  194. Cracked Ecterior Pipe
  195. Taking sprinklers off line
  196. Proper order of irrigation components
  197. Antisiphon valves downstream of reduced pressure backflow device
  198. Irrigation Pump Installation
  199. Suggestions to Secure a Valve Box from theft
  200. Wire mystery
  201. Correct Pump to draw water from lake
  202. Gutter Screens
  203. no pressure
  204. Filter screen?
  205. Rainbird ISM-9 error code
  206. 12 volt DC/Solar pump
  207. Unknown line
  208. Hunter Pro-C LCD malfunction
  209. 2 cut-off valves?
  210. Manually opening the valves won't turn on sprinklers
  211. Fountain leaking at PVC pipe/cement joint
  212. Sprinkler pump won't prime
  213. Sprinkler valve noise
  214. Gutter runoff retention
  215. No water from Hunter Pro C
  216. Connection Leaking on Frost Free Faucet
  217. Valves will not close
  218. Sprinkler valve diaphragm might be bad
  219. water running noise
  220. Special heads for low pressure situations?
  221. Burned Up Controller
  222. 2 Controllers - Rain Sensor?
  223. Blank display on irrigation controller
  224. Hydrotek 1114
  225. replacing irritrol transformer
  226. Follow up to low pressure thread, lots of new data...
  227. Controller recommendations
  228. 4 of the 6 zone won't work
  229. Zones not working - Where are the valves?
  230. how many hose bibs
  231. copper pipe questions
  232. low water pressure supply
  233. Yet another water pressure question...
  234. pressure pumps
  235. Galvanized > Poly fitting question
  236. weather smart irrigation
  237. Pressure relief valve questions
  238. Lawn Genie R706
  239. Air Compressor Quick Connector
  240. Irrigation classes
  241. Auto Sprinkler Valve Problem
  242. How to winterize sprinkler pump
  243. zone valve stays on
  244. Cycle Stop Valve
  245. Saddle tees for irrigation?
  246. Valve Stuck Open Question
  247. extraction of foot valve
  248. Compressor CFM - HELP!
  249. Sprinkler valves
  250. Controller Problems
